Question about LG WM-2277HW Front Load Washer
LG WM2277HS error code LE
I have a LG WM2277HS. I got the error code LE! I troed re-starting, removing clothes & I have tried unplugging it an still get the error after a couple of minutes. I have been looking and everyone keeps referring to the motor hall sensor? i can not find it to get the part # in the manual, nor can I find where I can purchase it. In my manual it shows the motor is under parts warranty for 7 yrs, would the sensor be covered? Also would there be any way to get instructions for install?
  • Anonymous Apr 11, 2009
    I have the very same problem. If I put a blanket or any heavy weight garmet into the washer I get an LE code. What I have had to do is to take all the wet clothes out of the dryer, dip the water in the dryer out. Run a cycle and then reload the clothes back into the dryer. Then sometimes it works and other times it gives me the LE error code all over again. Very frustrating to say the least.
  • 117 Answers
This is from the service manual for your washer. The hall sensor may be defective but you will need a technician to check out the other things listed here. The sensor is not covered for 7 years. Good luck
Go here to learn how to install ~ http://136.166.4.200/contents/Laundry/WM2432/WM2432xx_Service_Manual.pdf
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
Posted on Feb 25, 2009
I have an LG wm2277hs washer, started to flash LE code now it will not power up
Le error is a motor error code. The motor error could be caused by several things including : motor, bearings , rps sensor and wiring and in some cases all. continued use with this error could have taken out your mother board.
Dec 13, 2015 | LG Washing Machines
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
I've got an LE code on the front of my washer
This error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Jul 06, 2011 | LG WM2301HW Front Load Washer
I have a LG Tromm WM2277HS that just flashed the LE signal. We have had this for a couple years and never had a problem...what do I need to do to fix? I have unplugged but should I drain the unit as...
LE stands for a Lock Error and is to do with the hall sensor on the motor.
  • Unplug the Machine for 30 minutes, and plug back in. Try washing again.
Here is the replacement Hall Sensor: http://www.repairclinic.com/PartDetail/Motor-Sensor/1268238
Before you pull the motor apart to replace the hall sensor, first of all, check the wiring to the motor.
Unplug the motor, plug it back in and try the machine again.
  1. To replace the sensor, you will need to remove the back panel to access the motor.
  2. Take a 17 mm socket and remove the center bolt holding the rotor assembly.
  3. Pull the rotor straight out and place it off to the side.
  4. Take a 10 mm socket and remove the 6 bolts holding the stator assembly.
  5. On the inside of the stator assembly, you will find the motor sensor connected to a 5 wire connector.
  6. Remove the connector and replace the sensor.
  7. Reinstall everything back together and the unit should work fine.
You could also try this:
  1. Unplug machine
  2. Drain machine
  3. Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
  4. Plug in, power on, and run regular cycle and see if the error still comes up.
Feb 27, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Apr 13, 2010 | LG WM1814CW Front Load Washer
Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Sep 14, 2009 | Washing Machines
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
Lg wm2277hs
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
LE Code on control panel
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Dec 31, 2007 | Washing Machines
LG WM-2277HW Front Load Washer Logo
1,380 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
