Question about Bissell Upright Vacuum - The Pet Hair Eraser 1 ea Vacuum
Brush froze up and keeps breaking belts
The brush won't turn at all, the first belt was broken, replaced the belt and turned on the vacuum and within 30 seconds there was the smell of something burning and the belt was broken again. The brush never turned. I've tried to manually turn brush and it won't turn, it's frozen.
  • Anonymous Feb 26, 2009
    I have the same problem. I actually have a Bissell LiftOff....the exact same thing happened. The belt broke, I repaired it, and now the brush won't even turn. I can't even turn it manually.
  • ahmadmabdull Apr 06, 2009
    This is really frustrating because i do not believe there is a soluction besides this is a horrible product that Bissell
    expects you to replace every six months. I tried
    five belts all broke and a horrible smell is coming out.
    The brush wont turn and it is almost impossible to turn it by hand.
    Any ideas i would love to hear them?
  • 3 Answers
I had the same problem but I found that I had replaced belt incorrectly. After placing one end of belt around pully, it has to be run behind the "belt disengager" which looks like a 1/2" wide metal tab just past pulley. After placing belt correctly I had no more belt, burning smell or brush problems.
Posted on Jul 28, 2009
The brush on my Hoover Tempo self-propelled won't move
The bearings on the ends of the brushes can get clogged with things e.g. hair and this can cause the roller to seize.
Mar 02, 2017 | Hoover Vacuums
Bissell powerforce brush won't turn when powered
Hey, you may want to have check if the brush turns by hand without the belt in place. If the brush doesn't turn manually, you'll need to replace the brush.
Here's a quick link to the BISSELL website to assist you.
http://www.bissell.com/default.aspx?cid=ccsocial
Feb 12, 2013 | Vacuums
My vacuum has no suction
what is the model number? is the motor running? it the brush under it turning? is there a broken belt? Is the cannister or bag full? let me know these things...thanks
Jun 24, 2012 | Miele Vacuums
Brush doesn't turn all the time
The belt is worn out and you need to replace it. It's slipping and that's what you smell.
Nov 13, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
Brush won't turn
There is a good chance the belt is broken. The reason belts break is because the brush seizes up due to hair wrapping around tight at the ends of brush. Inspect closely with a flash light to check for this.
Aug 18, 2011 | Sebo X4 Bagged Upright Vacuum
Brush is not turning and water is not coming out when lever is squeezed
You may have a broken brush belt they break far too easily. Turn it over and look around the sides of the brush for a broken rubber belt.
Dec 08, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Old Hoover Convertible Upright U4109 keeps breaking belts. I just replaced the belts twice and both broke within 2 minutes.
Did you make sure the brush that the belt turns is free to move? Sometimes they get bound up and will not turn and as a result, the belts either burn or break. Remove the roller brush, clean the ends and remove any debris, lubricate the ends of the rollers where they are held by the stationary brackets and re-install with belt in correct position. Belt must be installed in the proper manner as well.
Sep 05, 2010 | Hoover Vacuums
I have a Dyson DC04 which is making a strong burning smell within a few seconds of switching on. Is this likely to be the motor and if so can it be replaced?
More likely it is the beater brush which is jammed and not turning. Turn the machine over and remove the bottom plate. Unhook the drive belt, then try to turn the beater brush--it is likely bound up with string, thread, and hair. Try turning the machine on once--if the motor spins and makes vacuum, it is probably ok. Remove the brush assembly and clean it of debris. Clean the end bearings with a Q tip and WD40 oil, then wipe clean with another Q tip. Oil the bearings with 3-1 or other light oil. Check the belt for a badly burned area--replace if necessary. Slide the new belt over the brush and motor shaft, then drop the brush with bearings into the case, and check rotation. If ok, replace the plate and test on your floor. Hope this helps!
May 16, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
The beater brush wont spin because the brush roll is always in the off position. Moving the carpet/hard switch doesn't turn it on.
Hello :
Try this please :
Switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
Or Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
Try this also please :
Things You'll Need: Phillips head #2 screwdriver Replacement belt for your vacuum model Spray lubricant, such as silicone spray or teflon lube.
1: Unplug the vacuum. Never work on an electrical appliance when it is plugged into an electrical outlet.
2: Turn the vacuum over and locate the plastic or metal plate that covers the rotating brush. Remove this plate.
Note: This plate is typically attached by a small number of Phillips head screws or by levers that turn and lock the plate in place. In either case, removing this plate is a simple task.
3:Identify the vacuum's rotating brush. This brush should have a black rubber belt wrapped around it, and stretched around the metal shaft of an electrical motor mounted somewhere toward the back of the vacuum.
4:Verify that the brush will rotate freely. Examine both ends of the brush to ensure that no threads, string, yarn, etc. have become wrapped around the ends and thus inhibited a free rotation.If there is foreign debris, remove the brush by sliding it up, away from the bottom of the vacuum. Remove the debris
5:Lubricate both ends of the rotating brush with the spray lubricant. Replace the brush into the grooves which hold it in place
Replace the existing belt on the brush assembly, or replace a broken belt with a new vacuum belt.
6:Verify that the brushes now turn freely when back in place and that the motor shaft turns as the brush rotor turns.
PLEASE DON'T FORGET TO RATE !
Apr 22, 2010 | Hoover U6630-900 WindTunnel Bagless...
Brush is not rotating and I get a smell from the
It might be the drive belt. If it is stretched, worn or broken it will not turn the brush roll. You can get replacement belts here:
Replacement Vacuum Belts
Nov 24, 2009 | Vacuums
Bissell Upright Vacuum - The Pet Hair Eraser 1 ea Vacuum Logo
768 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
