Question about Riso RZ220 Duplicator
Paper Jams I have a Risograph RA 4200. The paper feeds in, but keeps on getting stuck at the top of the drum inside the machine or leaves the machine and just dangles on the edge.I've wiped down the drum and rollers inside with a soft cloth. Any suggestions?
    Problem Solver:
  • 19 Answers
I think you should make sure that you have a border at the top of the original so that the machine can peel the copies off the drum. or you can press the image shift button to -10 to give you this border
Posted on Mar 13, 2009
Clean with a soft cloth and alcool the Paper Sensors, specialy the paper sensor (one under the drum), and also the clean the stripper pad, Pickup roller, Scraper roller, Gide roller, Timing roller in the firts paper feed drive mechanism
If you need the manual instructions post a mail at:
Posted on Mar 02, 2009
Hp4200 duplexer paper jam
If it jams every time, remove the duplexer and look for a piece of paper on the metal plate as the paper feeds out of the duplexer and back into the machine. Also use a file folder to push any jammed paper out from inside the duplex module.
Mar 14, 2015 | HP LaserJet 4200 Printer
'paper jam' message - Printer not working!!
Clear all paper jams from the front and the back areas inside the printer. Then, turn off and restart. It should reset itself.
Aug 10, 2017 | Samsung SCX 4200 All-In-One Laser Printer
Re; fr3950EP machine, I moved the paper sideways 10mm, light gone out and machine won't start again, display panel just says check paper feed area
Pls, I have risograph FR3950EP
I need the full drum unit, computer interface card, master and inks of different colours. Kindly help me out. I am in
Nov 26, 2011 | Riso RZ220 Duplicator
I am having repeated paper jams in the rear door of y HP 4200. It occurs right when the paper hits the rollers to go into the outbin, and the paper stops and jams in the rear door area. I have to open...
It's been a while since I worked on a 4200. Will it print if you keep the back door open?
If yes, does it jam?
If yes, and it doesn't jam, replace the paper delivery assembly(RM1-0026-040CN)
Dec 23, 2010 | HP LaserJet 4200 Printer
My Brother MFC-9840CDW keeps jamming every time I print mailing labels. I've had it four 1.5 years with no trouble. The label gets stuck and I have to pull out the toner tray to fetch it. I also...
hello, sounds like there are many possible solutions for you machine, first with paper jamming, are labels going thru manual feed tray, or paper tray, it might be possible that mp feed roller needs cleaning or replacing. if paper tray, simple would be feed roller, clean or replace, if jams continue with normal paper from paper tray, the problem will be front door, i have yet to be able to repair paper jams when front door assembly fails. as far as colors, both drum and toner can cause this problem, if using 3rd party toner, this will also cause some color problems. sorry no real quick fix for this machine, i've tried.
Sep 24, 2010 | Brother MFC-9840CDW Laser Printer
Paper feed jams. feeds from lower tray, turns 180 deg. then jams. Single sheet feed is fine
while keeping the paper .. ensure that it is properly stacked... fan the paper and ensure that it is not stuck to each other.. also open the printer cover and see if any paper is stuck inside..
Try to open the rear access door ,and clean the paper roller with slightly damp lint free cloth
Aug 12, 2010 | Brother MFC-7820N Printer
Risograph rz220 paper not feeding
If paper is fluttering while feeding, what is actually happening is that the pressure solenoid doesn't activate. This is caused by paper dust on the paper sensor.
Take the drum out...notice the white guide roller on the left side inside the is held on with a white e-clip that can be removed by hand. The paper sensor sits just behind this roller. Remove with a phillips screwdriver and clean the sensor.
Feb 03, 2010 | Riso RZ220 Duplicator
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
MFC-7420 "Change Drum Soon" I have had this message for a while. I purchased a new drum. In the meantime the printer continues to print fine, except we have paper feed problems. Is the drum related to...
the only time i've seen the drum affect paper feeding is if paper jams in the drum unit. i would use your current drum until print quality decreases to an unacceptable level. it will not shut down, and you will not see a "change drum message." if your paper feed problem is centered around the cassette/paper pickup area, you can try cleaning your rollers with water and a soft rag, and also make sure your rear paper stopper in cassette isn't pressing too tightly against the rear of paper stack. best to leave 1/8" gap, otherwise paper will not lift properly to the rollers.
Apr 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
362 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
