Question about Acer Aspire 5600 Series 5630-6951 Laptop
My acer aspire 5600's dwd-rw doesn't work
In acer settings management it sais that the comp has none cd or dvd rw , and the comp delays a lot booting up maybe for the same reason. when I try to search for devices , the comp breaks down to the blue screen
    Sergeant:
  • 366 Answers
If you installed some multimedia sw it's possible you modified your register settings; it worked for me several time on different pcs;
  1. [Start] [Run] [Regedit]
  2. Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
  3. Key Name: {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. Value Data: [Delete All Value Data from UpperFilters and LowerFilters]Note: Do not delete the Key or the Multi-String Values. Delete only the data values.
  5. Exit Registry and Reboot
if The system did not have UpperFilters listed only LowerFilters, delete the LowerFilters and restarte the system - for your safety back up the registry beforeand to try!
Posted on Feb 25, 2009
ACER ax3470 boot
restart computer and push F12 then select DVD/CD bootable device then you can use it DVD
Jan 17, 2013 | Acer Aspire Ax3470 Desktop Pc Amd A6 3420...
Can't find my owners manual, what kind of DVD's would my Acer Aspire Z5700 use?
The Acer Aspire Z5700 Desktop Computer includes a slimline CD/DVD burner capable of burning the following media: CD-R, CD+R, CD-RW, CD+RW, DVD+R, DVD-R, DVD-RW, DVD+RW, DVD-R DL (double layer), and DVD+R DL (double layer).
Basically, this computer can burn to any type of recordable CD/DVD media except for BluRay.
If you find this solution helpful, please leave a positive rating!
Jun 21, 2011 | Acer Aspire Z5700 PC Desktop
How do I install install Windows 7 to my Acer aspire 5630
Purchase Win7 System Disc.
Power up laptop and go into BIOS setting the DVD/CD Rom as first boot device.
Place OS disk in drive and boot from disk
Navigate the menu and questions and there you have it. Windows 7 on your laptop.
Now, download all of the drivers as required from Acer.com.
Download Windows updates and resore any backup data files.
Hope that helps.
Dec 31, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Dvd want boot up
Go to the BIOS configuration and change the Startup Boot device order and set the CD/DVD first then the hard disk. You can change it back after if you wish.
Sep 18, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer 5102 with xp, It wont boot from cd.
Make the DVD your 1st option for booting. It's also your CD drive but is identified as the DVD RW. Once this is made your default (make sure you accept and save the change before exiting) with your installation disk in the drive, boot up and it will read off the disk and prepare your system for install. If your disk is bootable, this will work.
Dec 19, 2009 | Computers & Internet
Acer aspire l100 dvd problem
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
Feb 14, 2009 | Acer Aspire L100 PC Desktop
Acer Aspire 1690 DVD/CD-rom is not working
My cd/dvd rom dont work coz the drive has change to another one.I think take windows xp/vista/7/8 with an usb and inslat it. When windows finished installing try to format it because the dvd and cd rom are fixed . Thnx
Jan 16, 2009 | Acer (91.37H37.001) Internal DVD Drive
I need to obtain Acer erecovery software on CD/DVD
The eRecovery software should be installed on your computer and you can use it to burn the disks yourself.
Click Start, Programs, Acer Empowering Technology, Acer eRecovery Management.
The management windows will open.
At the bottom click on Burn Disk
Click Create Factory Default Disc - good idea to have this because it put the machine back to new state - warning, you will wipe out any existing data from the hard drive if you boot of this disk.
You can also burn a driver and application backup disk and a current system configuration backup
If you click on Backup on the bottom you have the choice of doing a full system backup,this is probably what will work best for you but I do recommend having a set of factory default available.
Sep 29, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Hello
The Bios should not be your problem and the MBR doesn't have anything to do if you didn't play with Windows installations or with any utility to create an image of your hard drive.
To understand where the problem is coming from:
- Ask someone to go to http://www.knoppix.org/ and download a Knoppix CD
- Create a bootable CD from the ISO downloaded
- Enter in your Laptop BIOS settings and change the first bootable device as the CD/DVD
- Insert the Knoppix CD and boot your Laptop
- Knoppix will start and ask boot:
- Just hit Enter
- When Knoppix has finished and it's running you will have a nice graphic interface
- click on the HD icon on the desktop and see if you can see your files, if not you have a bad Hard disk
- Knoppix has also a utility to test the memory too.
If you tryied to install another copy of Windows or you made an image using some software like Ghost, you have to:
- boot from a floppy disk (Download and create from here http://www.bootdisk.com/bootdisk.htm, I suggest Windows 98 SE)
- At the prompt type FDISK /MBR and press Enter
ATTENTION: If you type something different you may distroy all your files on your hard drive
Oct 16, 2007 | Computers & Internet
Acer Aspire 5600 Series 5630-6951 Laptop Logo
97 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
