Question about E-Machines (T2958) PC Desktop
E-machine was working fine last night got up and it turns on but the monitor says check cable or power but all is ok.Computer wont display anything, can anyone help?
  • abaker4809 Feb 25, 2009
    I have purchase a video card and tired the monitor on another puter and it works but same problem when I hook it back to my computer even after the card.Also took out battery and then replaced it but no change.
    Called a computer repair place and they told me my mother board was bad is this true?
  • 565 Answers
Do a reset: Turn the computer and monitor off. Unplug the monitor video cable from the computer and unplug the monitor power cord from the wall outlet. Let it sit for 5 or 10 minutes. Plug everything back in, turn on the monitor, then start the computer. Sometimes that will work.
If you still have the same problem, try to borrow a known to be good monitor from somebody. If it works, then you know your monitor is bad.
It's also possible that your video circuitry is bad. If the monitor plugs straight into the motherboard (onboard video), then you'll need to purchase a video card and install it. Disable the onboard video first.
Posted on Feb 25, 2009
  • Bob
    Bob Feb 28, 2009
    Sorry I took so long to get back, just had a death in the family. Thanks for the positve feedback and taking the time to vote. Yes, it is possible that the mobo is bad. I would prefer to exhaust all possiblities before declaring the mobo dead though, for as u know, they aren't cheap. Probably better off buying a new computer for not much more than the price of a new mobo plus labor. Plus you'll get a better computer. Just need the tower.
    BobB
My HP L2335 Monitor wont display anything. I can literally turn it on (the led power light comes on and it turns green if plugged in and I can tell the backlight is on), but nothing will display no...
why not try a dead display on 2 machines 2 PCs
using only 1 data cable at a time why try to confuse it????????
the OSD must work, or the display is bad or the power supply to it is dead.
easy as apple pie.
the monitor has a tiny computer inside it (micro)
on mine, the data lines dead shows NO SIGNAL in the screen
every time you I power up my monitor with data cables pulled off.
best is to read the book for your monitor, and run all the tests it
tells you there,
Mar 13, 2017 | HP L2335 23 inch Monitor
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor was working fine last night but I think Microsoft did an update last night and i can't get the monitor to display. I get a check signal cable box that floats across the screen.Also do not have the...
Please unplug the monitor cable from the back panle of the cpu and replug it back again ensuring a tight connection.
this should take care of the problem.
Jan 22, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor dead
Check your power cables properly and make sure it is attached. Check your power button, maybe you have pressed the wrong one.
Jan 03, 2010 | Acer AL1916W 19" LCD Monitor
My monitor doesn't display anything, though it's receiving input from the CPU. I know that input is being received because the monitor status light is green, and times out (turns orange).
Same thing happened to me! Went to bed last night, everything was fine. Woke up today, orange light came on, no display, slight flickering seen, but that's it. Cables and cords are fine, tried unplugging and plugging it back in, NOTHING. Totally dead. I'm guess off to buy a new one today. Typical made-in-China JUNK.
Screen black
if monitor light is on, check the connecting data cable if it is ok then consult a technician.
Oct 28, 2008 | Computers & Internet
Monitor keeps blank even the power lLED is on green
Try replacin a new display card. If it is fine working.ok
If not try fixing for cold solder in the video section.
I suggest video section according your report the light green LED lighted that shows the power section is doing fine.
Apr 22, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
E-Machines (T2958) PC Desktop Logo
101 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
