Question about Canon NP 6050 Copier
E210 error turn off then on?
What do i need to do to solve problem?
    Sergeant:
  • 199 Answers
Replace small gear located in the inside of motor (lens drive assambly motor).
Posted on Feb 26, 2009
My plantronics ml10 password forgate
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 22, 2012 | Cell Phones
Error E210
If the Minolta copier change the transfer/separatoe corona wire(located under drum).Open and close front door.
Jan 06, 2012 | Office Equipment & Supplies
How to reformat sgh e210 to fix may camera
Dear Jamievince26,
The Samsung SGH e210 is a mobile phone with default software to use the integrated camera.
May I ask you to press the "Menu" button while in Iddle mode and choose the "Settings" menu. Once there search for an option called "Reset Settings" and proceed with it. This should revert any changes made to the phone.
If the issue does not solve once the reset has been applied, I advise you to contact the vendor who provided you with the phone as the camera could be faulty.
Regards,
Eddie Knight
Dec 28, 2010 | Samsung SGH-E210 Cellular Phone
Ive got e210 laser printerWhat cable conector do i need
You can connect the printer to your computer via a parallel cable or a USB cable. Here's the link to the Lexmark E210 User's Guide for your reference: http://bit.ly/aCoWdH. Thank you for choosing Lexmark.
Sep 01, 2010 | Lexmark E210 Laser Printer
All the lights are blinking on the Lexmark E210 when the printer is on.
All lights blinking could mean an error with the System Board (main board) You can also check the following link where it gives you more specific information.
http://bit.ly/ddF4dV
Jan 25, 2010 | Lexmark E210 Laser Printer
Error code E210 any ideas
Error E210 means - there is a problem with the lens position.
Under the glass there is a lens that moves to enlarge and reduce the copies. At switch on this has to find a home position. the error code means it has failed to do so. If you look at it is is driven by a belt. The drive pull for this can be seen through the glass. This becomes miss placed and is not driven correctly. Have a look and you will see has has come out of place. You may be able to take it apart and clean it up if not you will need a new drive assembly.
Jul 08, 2009 | Canon NP 6050 Copier
E210
Error 210 means that the printer scanner hasn't returned in its initial position.
You should see there http://en.allexperts.com/q/Repairing-Copiers-Faxes-1748/Danka-Copier-Canon-NP6551.htm , it may help you.
Feb 05, 2008 | Canon NP 6551 Black and White Copier
Canon NP 6050 Copier Logo
142 people viewed this question
old marine
old marine
