Question about VeriFone Omni 3700
Can not get a charge to go through
I keep getting a message "hold call". After a minute or two it goes back to the menu screen.
What kind of terminal do you own? And who is your processor?
Posted on Feb 26, 2009
  • IrvRod Feb 26, 2009
    I can probally help email me at irvrod1114@yahoo.com
I keep getting the message "connecting to computer" on Samgsung SH100
Disconnect the camera, remove the battery and after a few moments reinsert the battery. Then switch on again.
When you charge the battery in the camera, the camera could think it is connected to a PC, because the USB cable is inserted. It could be you are using a USB cable, that not came with the camera. If the error keeps coming back buy an external (Universal) charger, to charge your battery. Modern universal charges can charge almost every camera battery on the market. In the long run, it is better for the camera and for the battery, when you charge in an external charger.
Keep the contacts clean with a dry cloth.
May 10, 2014 | Samsung Sh100 black 14.2mp 5x Zoom Digital...
"no informatin" message on screen
Try a hard reset first:
Unplug TV from power source and undo all cabling. Wait about 5 minutes and replug and redo cabling.
Please try this first and let me know how it goes..
May 24, 2008 | Samsung HP-T4254 42 in. Plasma Television
Keeps beeping and displaying approaching turn
The "Approaching Turn" message is coming from an active navigation on your device. To turn it off, press and hold on the left side of the bezel (GPS), then press the lap/reset/quit key to exit the compass screen. You should then be in the GPS menu. There should be an item in this menu titled "Stop XXXX" where XXXX is "Navigating", or "Back to Start", or something like that. Select that option, and it should stop the navigation, and eliminate the "Approaching Turn" messages.
Sep 29, 2013 | Garmin Forerunner 405 Handheld GPS...
The Leapster turns on and the sign in screen comes up but the touch screen does not work. Recalibrating does not work. Can't get past the sign in screen
How did you try recaibrating? I just fixed my son's Leapster 2 a few minutes ago. I read a couple different recalibration instructions and the one that works for the Leapster 2 is:
1-Hold down the (?) Hint button while turning on the system.
2-Keep holding it down until the Leapster menu shows up
3-Let it go and press the A button
4-Touch each crosshairs x with the pen tip
5-When it goes back to the menu screen, restart the unit
Jan 21, 2011 | LeapFrog Leapster 2 Learning System
Iphone 3GS- only get the apple loading screen.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Nov 29, 2009 | Apple iPhone 3G
Phone will not charge and screen keeps showing pineapple logo
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also,Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 23, 2009 | Apple iPhone Smartphone
Ipod shows sad face
Aye, my friend had this exact problem before i came along :-)
First: Reset your iPod by quickly moving the lock to lock position then back to unlock position, then hold the menu and center button down till the apple logo comes up. Then you can release the menu and center buttons.
Second: Plug your iPod into a power supply, such as the apple AC adapter. Wait till it shows that its charging. Once it shows that, unplug it, reset your iPod once more, then plug back in.
Third: Keep your iPod plugged in after the second reset for about 15-20 minutes. Come back, unplug it, and use it and see if it continues. If still continuing, plug it back in till its fully charged, or the equivalent.
After that, If that doesnt fix it, try contacting Apple Support here: http://www.apple.com/support/ipod/.
Hope I helped!
Jan 19, 2009 | Apple iPod MA446LL/A MP3 Player
I have a Sony TV KDF-E60a20 that keeps going black screened during use. It usually stays black for about 2-3 minutes and then comes back on. It is becoming more frequent.
this is usualy caused by exessive dust on circuit boards ,if the screen goes black and the sound stays on this may be your problem,beware tvs hold charge even when unpluged so would advise taking to shop hope this helps andy
Jun 22, 2008 | Televison & Video
Keeps going to refresh mode
This is the Panasonic Customer Service Answer:
you need to reset the unit to get it out of store mode sir
make sure the unit is on and we are not in any menu screens
press and hold the volume down button on the front panel
and ok on the remote at the same time until the words self check appears on the front of the screen
once self check is displayed unplug the unit from the wall for one minute
after one minute plug the unit back in and it will go back through first time setup
make sure you pick the home mode
Apr 19, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Stuck on connected screen after being unplugged
I just had this problem, the way to fix it is to hold down menu and the center button until the screen goes grey with an apple logo on it. Wait for a minute, and it should go back to the main menu screen.
Apr 14, 2008 | Audio Players & Recorders
Retail Supplies Logo
145 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
