Question about Dell Office Equipment & Supplies
Paper feed paper wont feed in my dell 944 printer
    Genius:
  • 2,035 Answers
Please follow these steps :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Feb 25, 2009
I have a printer dell 944 and I can,t print anything because of carrier is jam
remove all paper from printer look inside carrier with a flash light to see if something is obstructing paper flow
Jan 30, 2011 | Dell 944 All-In-One InkJet Printer
I have a Dell Printer 944 all in one and the paper keeps jamming, how can I fix this issue?
See where the jam is coming from and isolate the problem from there such as rollers dirty or damaged
Jun 16, 2010 | Dell 944 All-In-One InkJet Printer
Carrier is jammed dell printer all in one 944
check and clean the paper carrier and if it continues change the cartridge.
Nov 13, 2009 | Dell 944 All-In-One InkJet Printer
My dell 944 is misfeeding on the left side of the paper. How do I repair the device?
Check for foreign objects in the paper path (I did a lot of these and pulled everything from hair curlers to dead mice!), if it's not this then contact Lexmark for a replacement paper roller, this is a common problem with Lexmark printers (Dell just rebadge them).
Oct 30, 2009 | Dell 924 All-in-One InkJet Printer
My dell 960 wont feed paper and keeps giving me a message there is a paper jam... but I don't see any paper
Its a Hardware problme with the Printer..Printer needs to be get repaired or needs to be replaced
Feb 28, 2009 | Dell A960 All-In-One InkJet Printer
Paper wont feed in my dell 944 printer
Okay try these steps \:
Feb 25, 2009 | Dell 944 All-In-One InkJet Printer
Dell 944 carrier jam
THE CARRIER MAY HAVE A FINE PEACE OF PAPER STUCK IN THE FEEDER ROLLER OR IN THE ROLLER PANS, REMOVE EVERYTHING, GET A CAN OF AIR AND BLOW IT OUT GOOD AROUND WHERE THE PAPER FEED AND EXITS THE PRINTER, THE CARTRIDGE MAY MAYBE GETTING SNAGED ON THE PRINT HEAD ALSO. SHACK THE PRINTER UPSIDE DOWN TO GET ANY TYPE OF MATTERAIL IN THE MACHINE, IT CAN BE PAPER, PAPER CLIP, STAPLE, PENCIL, ERASER MATTERAIL,
INK BUILD UP ON THE ROLLERS, CHANGE THE TYPE OF PAPER YOU ARE USING, IT MIGHT BE CHEAP PAPER PRODUCTS, LABEL GUM STUCK INSIDE THE PRINTER HOUSING AND EVERY TIME YOU USE IT JAMS.
ROD
Feb 13, 2009 | Dell 944 All-In-One InkJet Printer
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
258 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
