Question about ASUS A3Ac Notebook
Problem connecting to wireless router
I have an asus a3a, i cant get it connected to my home network. I doesn't seem to seem to be searching for an available wireless connection.
i tried downloading the driver of the wireless console... didnt solve it.
  • station518 Feb 26, 2009
    solved it! I downloaded and installed the INTEL/PROset/wireless...
    i must have deleted the pre installed appplication/and or driver on my asus a3a.
    President:
  • 2,653 Answers
You probably have the wireless power turned off.
Check to see if there is a hard switch somewhere around the computer
Or something that looks like an antenna on your keyboard.
Let me know if you find it and what happens when you switch it on.
Best of luck!
--RescueTechLA
Posted on Feb 25, 2009
  • RescueTechLA
    RescueTechLA Feb 26, 2009
    Awesome.
    Take it easy.
  • RescueTechLA
    Awesome.
    Take it easy.
Cant connect my Asus eec pc 1001px net book to a wireless network. Window says were connected but wont connect
In this case, "connected" means that it can "talk" to the wireless router.
But, it does not mean that you have "authenticated" to the router, by entering an SSID and a password.
Apr 02, 2011 | ASUS Eee PC 1001PX (1001PXEU17BK) Netbook
Although my Asus once recognized my home wireless router, when Comcast sent us a new wireless router to use and a new home network was set up, my computer no longer was able to connect. I can access...
To connect to your wireless router, it needs the router's wireless settings configured and also the wireless cards in all the laptops and or computers needs to be configured with the router's wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 07, 2011 | ASUS Wireless (90-c1i010-00xay)
Can 't connect to the internet with my ASUS wl-167g I have an ASUS wl-167g wireless usb adapter on my Win7 Home Premium PC, with the latest ralink drivers. I can perfectly detect the wireless network my...
You need to enter the wireless key from your router once before the adapter will connect. The key is either on the label on the router or in the wireless section of the router.
May 04, 2017 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
Asus eee pc 900a wireless connection not working
I've experienced the same problem with my ASUS netbook. Uninstall the wireless hard - remove hardware in control panel, reboot the machine and allow it to auto find the adapter again. This should correct it. If there are still problems verify that you have the most current driver for the wireless adapter, either from Asus, or the wireless adapter chipset manufacturer (i.e. Intel, broadcomm, etc.)
Sep 01, 2009 | ASUS Eee 4G Notebook
My wireless lan
Try toggling the wireless ON/OFF with special function keys:
<FN> + <F2>
If no broadcast available, check your router's wireless configuration.
Jul 10, 2009 | ASUS Eee 4G Notebook
My asus laptop pro3 series version F3JC will not connect to or locate wireless network at home which uses d-link wireless router. laptop is running vista premium. it will connect if i use a wireless usb...
I have seen issues like this before , certain chipsets/drivers of wireless cards and routers just dont like each other.
We know your wireless card works just as we know your router works. Trick is to get them to play nice together. Unfortunately, there is no quick and easy way to do this, you will have to try different driver and firmware combos until you find one that works.
You can get dlink updates here
http://support.dlink.com/downloads/
And you can try these drivers here.
http://asus-drivers.blogspot.com/2009/01/asus-f3-f3jc-driver-download.html
One other thing you can try before messing around with drivers and firmware is changing the application you use for wireless. The default for your setup is probably Intel Proset. Try using the native Vista wireless manager and see if that does anything. to access that go to start , run , type in services.msc, scroll down to WLAN auto config. Double click on it and then click on start. If you still cant see your router, its time to start trying drivers and firmware.
Apr 07, 2009 | ASUS Air Notebook
I am not able to properly set up my network with an ASUS Wl-500B
Both routers need to be on the same IP scheme and subnet i.e. 192.168.0.X subnet 255.255.255.0. First, unplug the Asus router. Next, make sure you have connection to the internet by hooking directly to the Apple router. Once you've established a connection to the internet plug the Asus router into the Apple router but go LAN port to LAN port.
Mar 23, 2009 | ASUS WL-500B Wireless Router
Changed router settings and now unable to access the network and internet
Just reset the router (there should be a reset button somewhere on it) it will default to open system. Then go back in and select WEP with 64 or 128 bit security. Generate your KEY and next time it connects enter the KEY. You should be set to go!
Jul 28, 2008 | ASUS Computers & Internet
Cant connect my WL520GC wireless router
I am buying the ASUS 4G machine and have a USB router connecting to Vodaphone through the molbile network. Without installing Windows XP can I connect the wireless modem to the little computer. Cheers Nick W
May 23, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
HI Asus Eee
you may have another wireless connection other than your own set as automatic, or more than one connection in your settings of the same name, so right click on your network icon in your task bar or in network connections in device manager and select view all wireless connections, click on it and when all the connections show, highlght, delete all of them, then close the window.
Your notebook should now indicate that it found new wireless connections, click on the popup and select your connection name and click connect, at this point you will be asked to enter the passkey if you have security enabled.
Jan 12, 2008 | Computers & Internet
ASUS A3Ac Notebook Logo
181 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
