Question about Acer Computers>Laptops Aspire 5050 PC Notebook
My left hand click doesn't seem to work
The right hand click seems to be fine but the left hand doesn't seem to be working right..it takes a few clicks for it to work
  • RescueTechLA
    RescueTechLA May 11, 2010
    Sounds like your laptop's palmrest will need to be replaced.
    Anyone else have any other ideas? I've only seen this problem occur due to hardware troubles.
I have a 1996 Isuzu bighorn UBS69GW that has a starting issue the problem comes and goes and results in a clicking noise and an almost electrical buzzing sound if left for 20 min will start fine again
IT IS A SOLONOID ISSUE,NOT A RESET FUSE.GET A NEW ONE,YOU WILL BE OK.THERE IS A COPER DISK IN IT.ROTATES EVERYTIME YOU START.NOT GOOD CONNETION.CHANG THE SOLONOID,NOT THE THE STARTER.
Feb 20, 2012 | Isuzu Trooper Cars & Trucks
Suzuki gz 125cc wont start
On your left hand side, take off the front sprocket's cover and you will see an oval part bolted on the left crankcase with a wire running out of it right next to the stator's cover.Follow that wire and see if it is properly hooked on the harness.Unplug it from the harness and touch, the harness half part of it, to the chassis. Your neutral indicator should come on. If it doesn't, replace the indicator's bulb.If it does, then you need to replace that oval part which is the neutral switch
Feb 03, 2012 | Suzuki GZ 125 Marauder Motorcycles
I have an Acer Aspire One D260 and am having some trouble with the mousepad. I can move using the touchpad but cannot click anything by tapping or double tapping. Also the left mouse click is not working...
On your bottom right corner,seek akee_akee.gif or akee_akee.jpg >>>right click on it >>> setting >>> on TOUCH sections >>> TAPS >>> CHECKBOX the taps to click and taps and drags >>>apply >>> ok.
Note : if cant find any those icons >>> go to control panel >>> Pointing device >>> Mouse
Cheers
Aug 22, 2011 | Acer Aspire One D260 Netbook
Quickplay not work in win7 64!
Hello esamili, I'm sorry to say that Quickplay doesn't seem to be compatible in the 64 bit version of win7. you can try running the program in compatibility mode.
  • Right Click on the HP Quickplay Icon.
  • Left Click on properties.
  • Left click on Compatibility Tab.
  • In The compatibility mode Section click on the check box stating "Run this program in compatibility mode for:"
  • Left click on drop list.
  • Left Click on Windows Vista (Service Pack 2).
  • Aug 14, 2011 | HP ProBook 4510s Notebook
    The vx-1000 installed fine on to my laptop and the image/video side of things works fine but the microphone doesnt seem to be working? any solutions?
    Have you made your webcam mic the default mic ?
    Vista
    TEST SPEAKERS
    Right click on speaker icon in System Tray or from Control Panel
    Select "Playback Devices"
    The speaker icon ( checked as working) and volume level graph should be visible
    Right click on the volume graph and click "Test"
    Left hand speakers followed by right hand should be heard
    SET DEFAULT & TEST MIC
    Click "Recording" tab.
    To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
    In lower dropbox display "Use this device enable" click 'OK'
    Click "Levels" tab and ramp up sliders ( adjust to suit later)
    Return to "Recording". Test mic by speaking and make sure volume graph displays
    Restart computer
    Configure to chat program
    Jun 24, 2010 | Microsoft LifeCam VX-1000 Webcam
    Two buttons beneath touchpad are not working
    You should clean the button by opening the cover, realign it, and check if the button touches to the board.
    Nov 12, 2009 | Sony VAIO Notebook PC VGN-NS235J/W
    My canon pixma iP4300 printer wont take up the paper.I sounds to be working OK, but paper seems to start Ok on right hand side , but not left side, after sometime moving about 4inches , then twists, if it...
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    pow-e-r-29
    Jun 14, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Logitech mx lazer cordless rechargable mouse
    You are welcome. Just make sure to rate this issue to close it.
    Have a nice day.
    Jan 09, 2009 | Logitech Cordless Click! Mouse
    Acer Computers>Laptops Aspire 5050 PC Notebook Logo
    41 people viewed this question
    Brian Sullivan
    Brian Sullivan
    Mohammed Ebrahim M
    Mohammed Ebrahim M
