Question about DeLonghi 6707E Oil Filled Radiator Heater
Adjust Delonghi oil heater thermostat
Mom-in-law likes to put the temperature at the highest level (9) and leave the heater on. How do I readjust the thermostat so when she sets it at 9 it is really at only 5 or 6?
  • 686 Answers
You can't
Posted on Mar 01, 2009
POWER IS ON--LIGHT ON, BUT DOES NOT HEAT UP
Check to see if the heating element has continuity or if it is even receiving power.
Mar 05, 2016 | DeLonghi TRD0715T Oil Filled Radiator...
What do I do when the dishwasher is stuck on P2?
GENERAL INFO ERROR CODES PROBLEM PARTS SOLUTION E1 NOT ENOUGH WATER INLET VALVE CLEAN OR REPLACE E2 NOT DRAINING DRAIN PUMP KINKED HOSE--ADJUST HOSE TOO HIGH--ADJUST PUMP FAULTY--REPLACE E3 WATER TEMP TOO COOL THERMOSTAT STAT OPEN--REPLACE TIMER CONTACTS OPEN-- REPLACE HEATER OPEN--- REPLACE ABOVE FAULTS CAN ALSO CAUSE TIMER TO STALL(TIMER STOPS TO ALLOW HEATING OF WATER) TIMER WOULD STALL AT THE 2,5,7 AND 10 O'CLOCK POSITION E4 OVERFLOW SWITCH ACTIVATED CHECK FLOAT IS FREE CHECK LEVEL OF D/W SOAP- AMOUNT AND KIND WASHARM STUCK OR SPLIT E5 E6 & E7 TEMP SENSOR THERMOSTAT REPLACE ERROR CODES: DDW497W Problem Solution Error 1 Water supply is turned off Turn water supply on Detached / damaged pipe Replace / readjust pipe Low water pressure Requires min. 0.04Mpa water pressure Defective water fill valve Replace water fill valve Damaged or defective wiring Repair the wiring Defective pressure switch Replace pressure switch Heavy water usage elsewhere in home Use unit when water usage is at a minimum Defective electric control Replace electric control Error 2 Sump or filter is obstructed Clear the sump and filter Damaged/defective drain pump Repair or replace drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 3 Voltage is too low Minimum voltage of 198 V Damaged/ defective thermostat Replace the thermostat Damaged or defective wiring Repair the wiring NTC thermistor damaged/out of position Replace or readjust the thermistor Damaged/ defective heating element Replace the heating element Defective electric control Replace the electric control Error 4 Sump or filter is obstructed Clear the sump and filter Loose or damaged sump pump/drain pump Repair or replace sump pump/drain pump Drain hose is obstructed or detached Clear out/readjust drain hose/tighten clamps Defective pressure switch Replace pressure switch Loose heater element Tighten heater element mounting nuts Loose spray arm Tighten spray arm Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Defective Microswitch Replace microswitch Float- defective or not in the right position Reajust / replace float Error 5 Damaged/ defective power switch Replace power switch Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 6 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too low Temperature should be above -20? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric control Error 7 NTC thermistor damaged/out of position Replace or readjust the thermistor Temperature is too high Temperature should be below 120? Damaged or defective wiring Repair the wiring Defective electric control Replace the electric contr
Nov 27, 2014 | Danby DDW611WLED
Problem with thermostat
Try this. Do as you already did above, but this time turn the thermostat slightly clockwise till it comes on again, and leave it at that setting for a while. Does it control now?
Jan 01, 2014 | DeLonghi Heating & Cooling
Thermostat Problem
The thermostat may have failed even though the unit is new.
Can't increase the heat on the thermostat
Instructions1 On nearly every Honeywell thermostat, the heat setting can be increased by simply pressing the HEAT option or AUTO and using the arrow keys to adjust the setting higher or lower until the desired temperature is reached.
2 To set an automatic heating schedule for Wake, Leave, Return and Sleep, press the SCHEDULE button, then EDIT.
3 Select the current day and use arrows to select the time and temperature for Wake. For example, if you typically awake for work at 6:00 a.m. and want the heat to come on, use that as your Wake time and adjust the temperature to suit.
4 Select the day and use arrows to select the time and temperature for Leave. Since you will be leaving the home empty for several hours, this setting will allow the thermostat to lower the heat until your arrival back home.
5 Select the day and use arrows to select the time and temperature for Return. This is the time and temperature that you will choose for returning home from work and may want the heat on to warm the house for your arrival.
6 Select the day and use arrows to select the time and temperature for Sleep. Set the time you normally go to bed. The thermostat will automatically adjust itself to your selected temperature at that time.
Thanks
Apr 01, 2012 | Lakewood 2096ET Oil Filled Radiator Heater
How do I use the Delonghi trv0715 1500w Vento High speed convection heater
The owner's manual is available as a PDF here: http://www.delonghiusa.com/index.php?product&nid=107 .
Many recommend you plug the heater in and turn it on in a well-ventilated room (like a garage) for the few hours of use. If you are using the heater to warm a room, plug it in with the thermostat set to maximum and set the power selector to 3 until the room reaches the desired temperature. Then rotate the thermostat clockwise until you hear a click. You can set the power level to 1 or 2 to conserve energy while maintaining the current temperature settings.
If you are trying to avoid frozen pipes in an area, plug in the heater and set the power selector to 3 and thermostat to *.
Always remember to keep anything flammable away from the heater (loose drapes etc.) There is an overheating protection circuit built into the unit. To reset it, you need to call the DeLonghi service center.
I hope this helps.
Mar 05, 2011 | DeLonghi Heating & Cooling
How do you use the dial and what is it for
This heater has both a dial and a wattage selector. The dial is a thermostat, so it will turn the heater on and off as the temperature gets warmer and colder. Just like the thermostat on the wall in a house. The wattage selector switches let you pick how much heat goes in when the thermostat (the dial) tells the heater to turn on.
If you set the wattage at a higher level, the heater will use more power at once, but will turn on and off fewer times to keep the temperature determined by the dial setting.
If you set the wattage to a lower level, the heater will use less power at once, but will turn on more often and still use about the same amount of electricity.
So the dial really lets you pick how warm you want it to be in the room, and the wattage switches let you pick how often it turns on and gets hot. So this dial really determines how hot your room will be.
Feb 11, 2011 | DeLonghi EW0507 Oil Filled Radiator Heater
Feezer keeps defrosting itself
Try adjusting the thermostat (freezer setting). Crank it from lowest to highest to lowest a few times, and then leave it set on the lowest setting. That may get something unstuck. You could try putting a little light (low viscosity) silicone oil on the working parts of the thermostat. Silicone oil doesn't get thick at low temperatures.
Jul 31, 2008 | Refrigerators
Efficency with Oil Column heating
because it operates on room air temperature, if this is the only means of heat to this room, leaving it on would be more economical thus keeping the rise in air temp time less=less time it works hard to match what you desire. but if not only source of heat no. time to heat room would be almost the same thus you would save what you used during the day due to fluctuations in room temps between time your furnace would kick on and off.
Jun 08, 2008 | DeLonghi 6507L Oil Filled Radiator Heater
DeLonghi 6707E Oil Filled Radiator Heater Logo
635 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
