Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
I have a LaserJet M1522NF printer and it does not receive some faxes and gives me a error 79 message on the display screen? can some one tell me what this is? i usually have to turn it off and turn it back on and it works sometimes!
  • dhull Mar 09, 2009
    My HP M1522nf locks up. Sometimes I get the Error 79, most of the time it just locks.
    Turning off and on works sometimes to get one document to print or one fax out, but not much more than that.
    An expert whose answer gotĀ voted for 100 times.
  • 123 Answers
Hello KIM !
Try doing an NvRam (Hard reset)
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
Posted on Aug 17, 2010
I can not send and receive faxes and on it writes ,,eror 79" thanks, Sanja
79 Error Turn off then on
The product has experienced an internal firmware error.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If a surge protector is being used, remove it.
Plug the product directly into the wall socket.
Use the power switch to turn the product on.
If the error persists, contact HP.
See or the support flyer that came in the product box.
Sep 08, 2011 | HP LaserJet M1522nf Multifunction Printer...
I failed to receive any fax, which the error message is NO FAX DETECTED. Pleaes help
First your make sure that your telephone line is working properly, and check your Printer Mode, fix in FAX MODE....
May 19, 2011 | HP LaserJet M1522nf Multifunction Printer...
Will the machine saying 101000 memory error message make you not receive the faxes that are trying to come in.?
This error is a bad chip on the toner cartridge. Replace your cartridge and your printer should be fine again.
Feb 16, 2011 | HP LaserJet M1522nf Multifunction Printer...
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
Hi Vikas,
The easiest way to solve this issue is to do an nvram.
Turn the printer off, hold down the down arrow and cancel button, turn the printer on while still holding and wait for the permanent storage init message to be displayed. Let go of the buttons and you should be good to go, reconfigure the device.
Jun 03, 2010 | HP LaserJet M1522nf Multifunction Printer...
After I scan documents with the M1522, it will not receive faxes
Hi dbraaten,
This sounds like there is a problem with the scanner assembly. Are you getting any error messages? Like scanner error 5? If so call hp tech support 1800 334 5144.
Dec 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
HP Laser Jet 3200se fax machine
The service error refers to an hardware issue with the printer.. U can try the following step,if this didnt resolve the issue only option is servicing.
1. Unplug printer.
2. Press and hold SYMBOLS & ENTER/MENU.
3. Continue to hold down the buttons while you plug back in the printer, through the entire
power-on sequence.
Jan 09, 2009 | HP LaserJet 3200se Printer
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
2,056 people viewed this question
Ben Johnson
