Question about Moen 2919 Chateau Two Handle Tub and Shower Faucet With Standard Valve In C
Moen Tub Faucet.. Water won't stop running.
The hot water, when turned on, won't turn off. Had to take a wrench and turn the handle very tightly to stop flow.
Do we need a new faucet or can this be repaired?
  • Anonymous Mar 30, 2014
    this is a brand new faucet and the hot water handle spins around without stopping and water comes out the bottom and the top of handle.
  • 547 Answers
Change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Posted on Feb 26, 2009
My cold bath tap wont turn off it just keeps spinning round can it be fixed with out changing taps its a double with shower connected.
Posted on Apr 19, 2010
My classmate
Moen Monticello 4-inch centerset bath faucets can be repair easily with only a screwdriver and adjustable wrench. Turn the water off to the both sides of the faucets under the sink. Open both the hot and cold-water valves to alleviate any remaining pressure. Remove the handles by grasping the base of the handle and turning it counterclockwise.( This works for both lever and cross handles). Loosen the Moen faucet cartridge bonnet nut with an adjustable wrench by turning it counterclockwise to the left. Pull the stem from the faucet by hand and replace. Reinstall the bonnet nuts and handles. Turn the water back on and test the faucet for leaks. The Moen Monticello faucet comes with a limited lifetime warranty. Try calling Moen to get your replacement parts free.
Dec 09, 2010 | Moen Bathroom Sink Faucet - 4-inch...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Moen T910 Kingsley two handle, whirlpool tub faucet. The hot water handle only puts out lukewarm water. The water heater is turned up and all the other faucets in the house put out scalding hot water.
if you remove the hot water handle on the faucet you can adjust the stop. if it is a newer faucet it has a built in scold guard. the directions should tell you which direction to move the stop to get hotter water
Oct 22, 2009 | Moen T910 Kingsley Deck Mount Whirlpool...
Water will not turn off
are the handle extensions on the cartridges all the way. i know sometimes the moens are a pain after you put the trim on to get them on and seated right so it actually spins the cartridge. also check the cartridge alignment the cartridges have little white tabs on the sides that correspond with a slot in the valve body if they aren't aligned it won't shut off either
Jul 31, 2009 | Moen 2919 Chateau Two Handle Tub and...
Moen shower handle keeps turning it wont come to a stop
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Mar 29, 2009 | Moen 2919 Chateau Two Handle Tub and...
Moen 2919 Chateau Two Handle Tub and Shower Faucet With Standard Valve In C Logo
1,309 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
