Question about HP LaserJet 4700 Printer
Hp color laserjet 4700dn error code 59.30
What is this and how can I solve
Turn off the printer. remove the duplex device from the printer. turn on the printer. enter the diagnostic menu. enter the menu for sensor and motors. select the fuser motor and let it run. if you can hear it its ok (its not such a noicy one ... you have to listen very good) - follow up the next steps:
turn off the printer. turn on the printer. enter the service menu - pin code is: 09470005. set to 0 all counters for mono print, color print and the counter after service. leave the menu.
turn off the printer, reinstall the duplax device. turn on the printer.
result: the error msg is gone. its just HP wants to sell theyr service contracts.
Posted on Jul 20, 2009
  • marisa_kauli
    marisa_kauli Jul 27, 2012
    I need help for his is probleme because this printer arranged for tomorrow
    New Friend:
  • 52 Answers
A 59.30 error is a "Fuser Motor Start Up Error". You have a major problem and it could be the fuser, fuser motor, or a logic problem. More than likely you will have to take it in for service or call someone to come to you. I problely won't be cheap to fix.
Posted on Feb 27, 2009
Yeah ... right now got the offer from HP support for this error msg. 900 CHF inkluding all costs - aproximately 12% from the price of the whole printer - after 2.5 years. bad deal :-(
    Problem Solver:
  • 9 Answers
I wrote an article in regards to the 59.30 fuser error. Read more here. 59.30 Fuser Error Related to Fuser Motor Problem - 4700
Posted on Jul 17, 2012
  • 339 Answers
SOURCE: ours's a hp color laserjet
The 59.30 error means that the fuser (hot rollers) drive motor is not starting to rotate when the printer is powered on. Check the fuser unit for binding. Possibly due to a paper jam in that section. After checking this, turn the printer off and on to see if it works. This printer is not one of HP's better products. Good luck.
Posted on Feb 25, 2011
seeker5211
  • 1089 Answers
SOURCE: How can I solve the
The error says that "The transfer rollers in the ETB are not
engaged."
If replacing the ETB(electronic transfer belt) doesn't fix the problem, your printer is going to need a technician. Problem could be poor seating of the cables on the ETB motor or the 'transfer-roller separation solenoid or the DC Controller.
It could be a bad ETB motor or solenoid or DC Controller or high voltage power supply.
This isn't something that is going to be fixed by email.
I hope you have a service contract for your printer.
Posted on Feb 18, 2011
pdouglasss
  • 125 Answers
SOURCE: What is HP Laserjet 4700dn error code 57.01?
Hi deek768:
You are having a fan issue. Check all fans to insure that they are working properly and replace the one you are having the problem with.
Hope this helps
Posted on Jul 10, 2009
seeker5211
  • 1089 Answers
SOURCE: Problem Error Code 59.FO For HP Color LaserJet
If you haven't taken your printer apart, somehow the "cams" in the developer drive assembly worked their way out of alignment.
Somebody trained is going to have to align and calibrate the main drive assembly.
Posted on Mar 05, 2011
seeker5211
  • 1089 Answers
SOURCE: hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Posted on Apr 04, 2011
How to solve 57.01 error turn off then on in my hp color laserjet cp2025 printer
57.xxx codes almost always indicate a cooling fan problem. One of your cooling fans has probably ceased to function, the fan will most likely need to be replaced.
Sep 05, 2014 | HP Color Laserjet Cp2025 Printer Laserjet...
57.xxx codes almost always indicate a failed cooling fan. The fan will probably need to be replaced to get rid of the error code.
HP Laserjet 4700dn suddenly stops printing in color although the cartriges are new and were working well. What is the problem?
>Go to menu settings, select set as default setting, do color calibration.. try for the print..> take configuration page, verify the firmware version, if low, download from hp web site, up load as specified..
Feb 01, 2012 | HP LaserJet 4700DN Printer
I keep getting a 51.20 error on my 4700DN - any ideas where i should go next?
Laser beam error, caused by the "black" laser.(each color has it's own laser). !st go to www.hp.com and upgrade the firmware. You can do that yourself. If that doesn't fix the problem or you are uncomfortable doing the upgrade, call a technician.
Aug 11, 2011 | HP LaserJet 4700 Printer
I need to know how to print an envelope on and HP color laserjet 4700dn
Select envelope, after you hit print. Run one first on a sheet of regular paper, to see the orientation. Then, just put them in, the way you have it set up for.
Sep 03, 2009 | HP LaserJet color laser printer
Hi deek768:
Hope this helps
Jul 10, 2009 | HP Hewlett Packard LaserJet 4700dn Printer
I have a HP CLJ 4700dn printer which keeps on giving 49.2FCC
That error is a firmware error, you might try again to download and install the update, or try a new memory stick if you have additional memory installed.
Jun 22, 2009 | HP LaserJet 5550DN Printer
Generic Flash Memory for HP LaserJet 4700dn
Google "color lj4700 memory". I saw 512MB for $27.00
Jul 11, 2008 | HP LaserJet 4700 Printer
HP LaserJet 4700 Printer Logo
13,364 people viewed this question
Seeker5211
Seeker5211
