Question about Brother BRTPT65 PT-65 Label Maker Printer
How to load the tape in the label maker - Brother BRTPT65 PT-65 Label Maker Printer
    Problem Solver:
  • 7 Answers
Www.ptouchdirect.com/ptouch/umpt65.html - 30k -
Posted on Apr 09, 2009
5 Suggested Answers
SOURCE: How do I load the tape into this old dymo label
http://www.dymo.com/media/UserGuides/Hobbyist1895.pdf
Posted on Jun 24, 2009
  • 2976 Answers
SOURCE: How do I change the tape in my dymo QX50 label maker?
Where the cartridge has a hole in it, make sure the tape is IN the print head, not over or under it. Also, check the type & color of the tape. They have some strange combinations that are only visible under certain conditions.
Posted on May 23, 2009
Democritus
  • 120 Answers
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Manual is here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Your cassette appears empty or otherwise non-functional. Please see page 2 of the above manual.
Posted on Jul 11, 2008
  • 566 Answers
SOURCE: How do I load the tape into my Brother PT 65
Download the manual for instructions and images of how to change the tape cassette (this should be a simple operation, unless something is wrong with your machine):
http://pub.brother.com/pub/com/ptouch-pdf/UM_PT65.pdf
For FAQs and troubleshooting:
http://welcome.solutions.brother.com/bsc/public/us/us/en/model_top/p-touch/65eus.html?reg=us&c=us&lang=en&prod=65eus
Posted on Aug 03, 2009
My Brother PT65 label maker powers up and when I push print...the rollers turn but the label does not print or come out.
Take out your label cart and pull the tape a bit. If it is hard to pull, it is jammed inside. Just keep gently pulling until it frees up. If this is the problem, it should work when you replace the tape cart. Had the same problem with mine yesterday - it now works.
May 20, 2015 | Brother BRTPT65 PT-65 Label Maker Printer
Where can I find the 1/2 inch wife labeling tapes used in Scotch brand (model EA-450) label maker? Label maker is over 20 years Old.
If you can get an accurate measurement of the label, you might be able to find another label series that might work. Other than that, I don't know. Maybe Ebay?
Jul 24, 2014 | Office Equipment & Supplies
P-Touch Model PT-65 Home and Hobby Label Maker - Loaded a new cartridge and it will not feed through
Sir/Madam
Its Very Easy To Fix This Issue,Just Follow Few Simple Step and You Solve Your Problem By Your Own,
Read Below Instruction,
1Turn off the label maker before installing the tape.
2Press the part marked as "<<" and lift the cassette cover.
3 Position the tape into the slot. Make sure to feed the end of the tape under the tape guides.
4Check that the lever is up before closing the cover; the cover will not close if the lever is pressed down.
5Close the cassette cover.
6 Press the power key to turn on the device. If using an AC adapter, plug the adapter into the wall then press the power key.
7Type a sample to test if your installation was successful.
Read more: http://www.ehow.com/how_7526530_install-tape-ptouch-label-maker.html#ixzz2pMqUU0oU
Jan 02, 2014 | Brother BRTPT65 PT-65 Label Maker Printer
My ps 1100 label maker prints only on black side of tape
This depends on the TAPE CARTRIDGE you have in your label printer. Apparenlty, you have a TRANSPARENT TAPE on it, and the printer prints in BLACK only.
Just replace the tape cartridge
Apr 01, 2010 | Brother P-Touch (PT1100SBVP) Label...
Too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Jan 04, 2010 | Brother P-Touch 1180 Label Printer
May 22, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Need help loading cartridge for brother label maker
when you have the label maker upside down...
place the cartridge so the WHITE 12mm ect sign is on top.
pull the tape out a bit and pull it up so that it stick out where the tape would print out of.
place the cover back on tightly and turn on..
push CODE, SPACE, it will feed though and you'll be all set.
Dec 08, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Once you snap in the catridge you have to put the back of the p-touch back on. After that you can feed through the tape by pressing Code Space. If the back of your P-touch is not on it will not advance through.... I learned the hard way :) Hope it helps you all.
Jul 11, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Label Maker HELP!! Brother ptouch 1180
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Computers & Internet
Brother BRTPT65 PT-65 Label Maker Printer Logo
1,601 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
