Question about GE Telephone pr521w
Model 28223series dect 6.0 answering system does record messages
    Genius:
  • 1,011 Answers
I searched information at net. all the phones answering machine does not record the incoming msg.....
click this link for some tips
For manual better go through manual it helped
Posted on Feb 25, 2009
How do I change the message on my answering machine?
Which Uniden phone do you have? for some models, you access the Answering System menu from the base; on others, you need to be holding the handset. The generic steps are below.
On the appropriate part of the unit, make sure that the phone system is in standby (no active calls on any handset). Then press Menu. Use the arrow keys to find the line for Answering System. Press OK. Navigate to a line about Greeting and press OK. You should see (and select a line) for Recording message. You'll be prompted to ensure that you want to record a new message. If you are using the handset, hold the unit about 6" away from your head. After confirming that you wish to record a new message, speak your new message clearly. When you are done, press End. The unit will cut off the recording if your message was too long. Make sure to save the message. Then go back up in the Menu system and look for a line for "Play back Greeting". If the message isn't clear, start over.
I hope this helps. Please add a comment with the model number of the phone for specifics for your manual. Some DECT phone manuals are available here: http://www.uniden.com.au/australia/cs_operating_manuals_phones.asp .
Nov 21, 2015 | Uniden DECT 6.0 Cordless Phone
How do I record an answering message
Since you didn\'t specify the model of your Uniden DECT 6.0 system, please select it from the list beginning at scat/dectphones_mnl">Select Product Category to download a copy of the manual.
Nov 07, 2014 | Uniden DECT 6.0 Cordless Phone ID
KXTG9341 Top light flashing and 'New Voicemail' message on handset display, but no new message recorded on the answering machine.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone.
Please contact your telephone company for instructions on accessing their voicemail system.
Feb 27, 2014 | Panasonic DECT 6.0 Expandable Cordless...
How to rerecord the answering message
What model Uniden DECT 6.0 phone/answering machine?
Are you sure the message in on your answering machine and not a voicemail system provided by your telephone company? Many telephone companies offer a voicemail system that takes messages if someone calls while you're already on the phone.
Nov 20, 2013 | Uniden DECT 6.0 Cordless Telephone...
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
I have lost my manual and i dont know how to record a personal message on my answering machine and how to enter the code to retrieve my messages from another phone.
From your handset, you just have to press the mute button, your phone should start telling you the time, date, ect. press the #5 key and then the #8 key and start recording your message. When finished press the # 8 key again. Hope this helps
Mar 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do I make it so the phone rings 6 times before the answering machine comes on? And... how do I record my own message?
Since you neglected to specify the model of your Uniden DECT 6.0 phone/answering system I can only suggest you select it from the list beginning here to download a copy of the manual.
Dec 04, 2010 | Uniden DECT 6.0 Cordless Phone ID
We have v tech phone after set answering system "A" sign on phone instead of "o" sign also not recording, please let me know how to solve this problem. Thanks
The "A" indicates announce mode, where the system plays an outgoing announcement but does not record incoming messages. You need to switch it to the record mode, where it will record incoming messages. Unfortunately, since you declined to specify the model of your VTech DECT 6.0 system, I cannot tell you how to do this. I can only direct you to enter the model number into the search box here to download a copy of the manual.
Dec 03, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
Lands Phones Logo
129 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
