Question about Fujitsu AMILO D-8820 Notebook
On switch on (FujitsuM1437G) loads normaly but then goes into horizontal and vertical lines much like interference but with a regular pattern. The desktop display is ok underneath these broken black thick and thin lines.Then it just goes black and sulks until the battery is disconned and refited. At first you could tap the keyboard and correct the fault. I removed the keyboard and washed it with soap and water,dried it then put it back. A lot of "mange"came out from the keys! This did nothing to correct the fault so I took the whole computer to bits and did a "graze" with my pyropen on all the joints I could see specialy the earth.One thing I did notice was that all the heat synch compound had dried up on the vga and driver chips.Having put it all back together again including new "chip chease"on switch on it now stays on but it still has parasitic linear lines. Any ideas? bamfordsnr@hotmail.com
So I have a 50 Lg ( LG 50LN5700). There is still a picture however about every 3 seconds it goes from regular to blurry and repeats. There seem to be about 3 black lines across the top horizontally about 3...
To clarify, are the 3 black lines horizontal (left to right across entire width of screen)? or are the 3 black lines vertical (top to bottom across entire height of screen)?
Horizontal lines are almost always the result of a failed panel, and no board replacement will fix the issue.
Vertical lines such as you have described (only 3) are probably also a bad panel. If the black lines were evenly spaced in a repeating pattern, it could be a mainboard or TCONN board.
Has this panel been cracked? or perhaps cleaned recently with too much water or cleaning solvent that has gotten the screen wet?
You may have to sell the TV for parts.
Oct 23, 2017 | LG Televison & Video
How do i re align the head on aMX432 cannon
  1. Open the printer driver setup window
  2. Click Custom Settings on the Maintenance tabThe Custom Settings dialog box opens.
  3. Switch head alignment to manual
    Check the Align heads manually check box.
  4. Apply the settings
    Click OK and when the confirmation message appears, click OK.
  5. Click Print Head Alignment on the Maintenance tab
    The Start Print Head Alignment dialog box opens.
  6. Load paper in the machine
    Load three sheets of A4 size or Letter size plain paper into the front tray.
  7. Execute head alignment
    Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  8. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Even if the patterns with the least amount of streaks are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    When you have entered all the necessary values, click OK.
    [img src="http://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/MX450%20series/1.0/EN/PPG/images/i_note.gif" alt="" >Note
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical streaks.
      (B) Most noticeable vertical streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal streaks.
      (A) Least noticeable horizontal streaks
      (B) Most noticeable horizontal streaks
  9. Confirm the displayed message and click OK
    The second pattern is printed.
  10. Check the printed pattern
  11. Confirm the displayed message and click OK
    The third pattern is printed.
  12. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Even if the patterns with the least noticeable horizontal stripes are clicked in the preview window, their numbers are automatically entered in the associated boxes.
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal stripes.
      (B) Most noticeable horizontal stripes
Jan 05, 2015 | Cannon Office Equipment & Supplies
How to adjust headlights, 05 ford 500
Headlamp Adjustment
Headlamp Aiming
  1. The headlamp aiming procedure depends on what type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical left (VOL), visual optical right (VOR) or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is 1 of the following:
    • SAE
    • VOL and SAE
    • VOR and SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using 1 of the following methods as applicable.
    • Photometric aimers can aim VOL-, VOR- and SAE-type headlamps only. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim VOL-, VOR- and SAE-type headlamps only.
    • Mechanical aimers cannot be used with VOR- or VOL-type headlamps. Aerodynamic lamps that can be aimed mechanically have 3 nibs molded into the lens of the lamp.
    • Photometric Aiming
      1. For the photometric aiming procedure, refer to the appropriate photometric headlamp aimer instruction manual.
      Screen Method Aiming
      All headlamp types NOTE: Horizontal aim is not necessary for VOL or VOR headlamps.
      NOTE: Consult your state vehicle inspection manual for recommended tolerance ranges for visual aiming.
      NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
      1. Before starting headlamp adjustment:
        • check the tire inflation.
        • check that no other load is in the vehicle other than a half tank of fuel.
        • check that the headlamps are clean.
        • check for correct headlamp operation.
        • check that the vehicle is on level ground.
        • if the vehicle is equipped with air suspension, make sure that the switch is on.
      1. NOTE: The vertical wall or screen must be a minimum of 2.4-m (8-ft) wide.
        Park the vehicle on a level surface approximately 7.6-m (25-ft) from the vertical wall or screen directly in front of it.
      1. NOTE: The center of the lamp is marked either on the lens (circle, crosshair or other mark) or on the bulb shield internal to the lamp (crosshair or other mark).
        Mark a horizontal reference line on the vertical wall or screen.
        1. Measure the center of the headlamp height to ground and record the measurement.
        1. Make a 2.4-meter (8-ft) horizontal mark (using masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
      1. NOTE: This procedure should be done in a dark environment to effectively see the headlamp beam pattern.
        Turn on the low beam headlamps to illuminate the wall or screen and open the hood.
      1. NOTE: For SAE-type headlamps, the appearance of the beam pattern may vary between vehicles.
        On the wall or screen, locate the high intensity area of the beam pattern. Place the top edge of the high intensity zone even with the horizontal reference line.
      2. SAE-type headlamps
        1. In addition to the horizontal line marked in Step 3, a pair of vertical lines must be marked at the center line of the headlamps on the wall or screen.
          1. Mark the center line of the vehicle on the wall or screen.
          1. Measure from the center of the headlamp to the center line of the vehicle.
          1. Make two 1.5-meter (5-ft) vertical marks (using masking tape) on the wall or screen at the same distance from the vehicle center line as previously recorded.
        1. On the wall or screen, locate the high intensity area of the beam pattern. Place the left edge of the high intensity zone even with the vertical line corresponding to the headlamp being adjusted.
How To Aim Headlights EricTheCarGuy
Jan 15, 2011 | 2005 Ford Five Hundred
Im seeing duble words,how can i fix it?
There should be a convergence adjustment on this set. It will have a "cross hair" type pattern
You adjust the beams so that the cross hairs turn white. I believe Green is not adjustable intentionally. The procedure is to adjust the vertical Red line until it alligns with the Green line. Then adjust the vertical Blue line until it lines up with the Red and Green. The line should turn White.
Repeat the procedure for the horizontal lines. When you return to regular viewing mode the double
images should be greatly reduced or eliminated..
Hope I've helped you,
Best Regards,
Mark
Dec 30, 2010 | Panasonic Televison & Video
How do you ajust head light aim on a ford f-150 2008 truck?
  1. NOTE: The vertical wall or screen must be a minimum of 2.4 m (8 ft) wide.
    Park the vehicle on a level surface approximately 7.6 m (25 ft) from the vertical wall or screen directly in front of it.
  1. NOTE: The center of the lamp is marked either on the lens (circle, crosshair or other mark) or on the bulb shield integrated into the lamp (crosshair or other mark).
    1. Make a 2.4 m (8 ft) horizontal mark (using masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
VOR-type headlamps
  1. NOTE: The appearance of the VOR beam pattern may vary between vehicles.
    Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam needs to be adjusted using the headlamp adjusting screw.
VOL-type headlamps
Apr 09, 2010 | 2008 Ford F-150
I have a 2000 ford mustang can you adjust the headlights and how do you do it
SECTION 417-01: Exterior Lighting 2000 Mustang Workshop Manual GENERAL PROCEDURES Procedure revision date: 12/09/2002 Headlamp Adjustment Headlamp Aiming
  1. The headlamp aiming procedure depends on the type of beam pattern the headlamp is equipped with. Vehicles may come equipped with visual optical right (VOR), visual optical left (VOL), or SAE only (includes sealed beam type) headlamps. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOR or SAE
    • VOL or SAE
  1. Once the headlamp beam pattern is identified, aim the headlamps using one of the following methods as applicable.
    • Photometric aimers can aim SAE, VOR and VOL type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOR and VOL type headlamps.
    • Mechanical aimers can be used only with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
All headlamp types
NOTE: Horizontal aim is not necessary for VOR or VOL headlamps.
    • Check the tire inflation.
    • Check that no other load is in the vehicle other than a half tank of fuel.
    • Check that the headlamps are clean.
    • Check for correct headlamp operation.
    • Check that the vehicle is on level ground.
    • If the vehicle is equipped with air suspension, make sure that the switch is on.
  1. NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
    Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
  1. NOTE: The center of the lamp is marked by a 3 mm (0.12 in) circle on the headlamp lens.
    1. Measure the center of the headlamp height to ground and record.
    1. Make a 2.4 meter (8 foot) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: For SAE type headlamps, the appearance of the beam pattern may vary between vehicles.
VOR type headlamps
    Identify at the top edge of this high intensity area a distinct horizontal cutoff in the beam pattern. If the top edge of this cutoff is not even with the horizontal reference line, the headlamp beam will need to be adjusted.
VOL type headlamps
  1. For VOL type headlamps, there will be a distinct cutoff in the left portion of the beam pattern. The edge of this cutoff should be positioned 50.2 mm (2 in) below the horizontal reference line.
    1. Horizontal reference line.
    1. Top edge of the beam pattern.
    1. High intensity zone.
Mechanical Aiming
  1. For the mechanical aiming procedure, refer to the appropriate mechanical headlamp aimer instruction manual.
2010&c18=modelyear&c20=n304745&c35=wsm%2cheadlamp%20adjustment%2csyb%2c417-01%2cgeneral%20procedures&pid=wsm%2ctitle%20page%202000%20mustang%2csyb&pidt=1&oid=functiononclick%28%29%7bdosearch%28%29%3b%7d&oidt=2&ot=img&oi=27&s=1600x900&c=32&j=1.3&v=y&k=y&bw=1171&bh=582&ct=lan&hp=n&[aqe]
Apr 07, 2010 | 2000 Ford Mustang
I just installed the right head light on a 2000 f250. I'm trying to find the specifications on distance and height of the light beams, L &R when adjusting the lights.
Headlamp Adjustment —Screen Method Aiming NOTE: Horizontal aim is not necessary for this vehicle and is not adjustable.
NOTE: Consult your state's vehicle inspection manual for recommended tolerance ranges for visual aiming.
  1. NOTE: The sight shield may need to be positioned or removed for access to the adjusters.
    Before starting headlamp assembly adjustment:
    • Check that no other load is in the vehicle other than a half tank of gas.
    • If the vehicle is equipped with air suspension, make sure the switch is on.
    • NOTE: The vertical wall or screen must be a minimum of 2.4 meters (8 feet) wide.
  2. Park the vehicle on a level surface approximately 7.6 meters (25 feet) from the vertical wall or screen directly in front of it.
    1. Make a 2.4 meters (8 feet) horizontal mark (masking tape) on the vertical wall or screen at the same distance from the ground as previously recorded.
  1. NOTE: The appearance of the beam pattern may vary between vehicles.
7ced4e6.gif NOTE: The appearance of the beam pattern may vary between vehicles.
Apr 06, 2010 | 2000 Ford F250 Super Duty Crew Cabs
Need to adjusted headlights how do you do it on a
there are little screws with hex head or torz head. one for lateral, one for up/down.
shine on garage door.
Headlamp Aiming
  1. The headlamp aiming procedure depends on what type of beam pattern the headlamp is equipped with. To identify the headlamp beam pattern, look on the headlamp lens. Molded in small letters on the headlamp lens is one of the following:
    • SAE
    • VOL
    • VOR
    • Photometric aimers can aim SAE, VOL and VOR type headlamps. This is the preferred method of headlamp aiming.
    • Visual or screen method aiming can be used to aim SAE, VOL and VOR type headlamps.
    • Mechanical aimers can only be used with SAE type headlamps. Lamps that can be aimed mechanically will have three nibs molded into the lens of the lamp.
Photometric Aiming
All headlamp types
VOR type headlamps
VOL type headlamps
Mechanical Aiming
Jan 18, 2010 | 2000 Mercury Grand Marquis
No horizondal oscilation.
no line flyback transformer
vertical line horizontal out put circuit
horizontal line vertical output circuit
at fault
Sep 14, 2009 | Televison & Video
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean.
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Fujitsu AMILO D-8820 Notebook Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
