Question about Samsung 226BW Monitor
BLUE LINE DOWN MIDDLE OF SCREEN. - Samsung 226BW Monitor
  • 203 Answers
That sounds like it is a pixel line. possibly from leaking lcd.
try running a pixel test on your screen.
Posted on Feb 25, 2009
Jonsnell electronic do you no about the blue line that comes and go down middle of screen pc
Probably a faulty screen, check by plugging in an external monitor. If the external monitor has no line, your screen needs replacing, if the line is still there and the line is not caused by a windows picture, the GPU is possibly in need of reballing or replacing.
Hope that helps.
Jan 04, 2016 | HP Computers & Internet
Blue line down right side
The blue line came on to the tv LCD screen panel by itself,not caues by u or an object by hitting the tv LCD screen panel itself wright,if yes this problems can't be repair because the LCD screen panel itself dead.Blue line happen by itself,the tv board that call the T-CON board it is dying and the causes.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish T-CON board for the replacemrnt.
Jun 22, 2011 | Polaroid TLX-01511C LCD TV
Blue line down middle of screen and every time we hit exit it takes us back to main home screen.
if the blue line is always there, than your screen is damaged and will need to be replaced... just time before it'll get worse.
Apr 23, 2011 | Toshiba Satellite Pro L300 Notebook
When i turn it on it has an horizontal blue line in middle of screen then comes on, when shut down it has the colors in the middle in tight formation then suts off. is it the picture tube
the set having blue scteen when the nosignal condition so blue horizontal line due to failure in vertical deflection section and system control detect the vertical delection failure . so system control farce to set to shut down pls repair the vertical section and system should be ok
Aug 26, 2010 | Samsung SlimFit TX-S3082WH 30" TV
Top, middle of screen there is a constant flicker. The flicker starts at the top, middle and goes about half way down the screen.
I have a blue line about 3/4 inch wide from the top right to the middle bottom. ( not a straight line ) I replced thr projection lamp with no fix to the problem. I added an additipnal fan and cleared up the problem. On furthe investigation I replaced the air filter and kept only the original fan and the problem was solved. Can you explain this.
Dec 06, 2009 | Zenith D52WLCD 52" Rear Projection...
Verticle line down the middle of lcd monitor.
This is a common problem with LCD screens. It is pixel line damage and the screen is permanently damaged and is not repairable. It will probably get worse. The only answer is to replace it
Oct 01, 2008 | Toshiba Satellite P30 P35 Series Notebook
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
use menu and h/v then change then move to higher level and it will take it away.
Oct 09, 2007 | Vizio Gallevia GV42LF 42 in. LCD...
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
149 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
