Question about HP Photosmart E217 Digital Camera
ON/OFF SWITCH LIGHT DOES NOT STAY ON FOR PICTURE TAKING SO NO P
PHOTOSMART E 337 ON/OFF LIGHT GOES OFF AS SOON AS BUTTON PRESSED SO NO PICTURES TAKEN, HAVE INSTALLED NEW BATTERIES
  • 4 Answers
Battery problems seem to plague HP cameras! Mine did the same thing, and resetting the battery (not just replacing) seems to have done the trick. See if these directions apply to your particular model. If not, go to the HP website and check the FAQ's for your model. That is how I was able to solve my HP Photosmart battery problem.
Posted on Dec 21, 2009
Brake light stay on went the car is cut off
This problem is caused by a defective brake light switch or a switch that is not adjusted correctly, when the brake pedal is not being pressed the button in the center of the switch should be depressed, if it isn't screw the switch clockwise to adjust it., the switch is located under the dash at near the top of the arm the brake pedal is attached to, it is easy to replace and fairly cheap here is a price and picture of the brake light switch in your Honda. If you have cruise control the switch is slightly different, so i have included both pictures and part numbers.
AIRTEX / WELLS Part # 1S5431
With Cruise Control $16.33
emissionwiz_168.jpg AIRTEX / WELLS Part # 1S5681 Without Cruise Control
$14.37
May 04, 2011 | 1998 Honda Accord
When reviewing pictures, by pushing the arrow, a screen comes up over the picture, detailing Camera, date, time, etc. How do I make it go away and STAY away? If I hit the Enter button, it will go away,...
You cannot make it STAY AWAY. THat buttn, the multi-selector switch, is useful. If while viewing your shots it is pressed to the right, then the shot info comes up. Push it once back to the left and that info goes away. If pushed left once again, you get a histogram of the phoro. Push it once to the right and that histogram will go away. without the histogram or information on the screen, you are in normal viewing mode and pressing that multi0selector switch up or down will cycle through your photos.
Oct 31, 2010 | Nikon D50 Digital Camera
2000 Buick LeSabre's cruise control button won't stay engaged
We had the same problem and ended up replacing the switch. We used a small flat-tip screwdriver and lifted along the edge of the switch. With the switch removed from the steering wheel, we disconnected the wire connector and installed the new switch by reversing the order.
Jun 17, 2010 | 2000 Buick LeSabre
Broken button for taking pictures
You need to replace Switch Control Block as shown in below picture.
Let me know color of your camera cabinet to provide you part number info..
Dec 12, 2008 | Sony Cybershot DSC-T200 Digital Camera
Blank screen in picture mode
press the DISP button, your picture should come back up.
Nov 26, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
Sep 08, 2008 | Nikon D40x Digital Camera
Camera still possessed
There is something wrong with the settings of the camera.
When it is on setting or view mode is fine. It is not supposed to take pictures.
Go thru the Menu and pick the way you want your pictures, size and all those details, switch them take pictures and keep switching the settings until you get it right.
My camera was taking 3 pictures at the time, and it was because of the setting was set to do that. Don't be afraid of changing the setting for pictures, you can always change and try different things, digital pictures can be erased right away. So you can try as much as you want.
Try all options in the setting for taking a picture, change a setting, try to take a picture and see what happens. Then try on another setting and so on.
Artgirl
Jul 08, 2008 | Nikon Coolpix 2100 Digital Camera
There is a long delay taking pictures
Check to see if the self-timer is on. You can set the timer to 0, 2, or 10 sec. A 2 sec. delay will help to prevent blurry pictures. But setting the self-timer to 0 will take the picture as soon as you push the button.
May 26, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
HP Photosmart 735 "unsupported image file"
You might want to try a different memory card.
Jan 21, 2007 | HP Photosmart 735 Digital Camera
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
HP Photosmart E217 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
