Question about ASUS Eee 900 Notebook
I put 2gb of DD2 ram in 800 mhz it wont show a screen? To fast of
What is the Max spped of DDR2 ram the EEEPC 900 can use?
Brad
  • ASUS Master
  • 19,396 Answers
Currently it is up to 2GB DDR2 SDRAM 667 MHz.
Posted on Feb 25, 2009
  • 31 Answers
Eee PC models use 533/667 MHz DDR2 RAM via a standard SO-DIMM module.
The hardware supports up to 4GB (2GB for the 1000 series, and some of the 900 series).
I have motherboard Mercury PVM7P, i installed 2 GB DDR2 RAM 800 MHS but its showing only 448 MB what is the solution for that anybody can solve it, how much maximum RAM can support this motherboard
Hello you can find info here:
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=677
The mainboard supports:
2 x 240-pin DDR2 DIMM socket support up to 2 GB DDR2 533
Maximum: 2GB
533 mhz is probably limited speed by the CPU and the FSB settings.
So you have to try with another type of ram module, the 533 module, because 800 mhz is probably to fast for this mainboard.
Good luck
Aug 22, 2013 | Mercury Computers & Internet
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I bought a new 1GB ram(DD2) when i insert it it nt work bt whenever i insert it with old 512MB ram then its work bt in bios setting only show the 1GB ram
Maybe 1GB is the maximum amount of memory that your system will hold. And maybe your system likes memory to be in pairs, so when you put the 1GB in by itself it didn't work, but when you put it in with a 512MB it works.
May 18, 2012 | Computers & Internet
I have NP-N150-JP01EE and on it DDR2-666 1GB Can i have put there DDR2-800 2GB or must be DDR2-666 2GB
Yes you can if the mainboard and cpu supports it.
But i will only run with 666 mhz at the system bus.
It does no harm to the mainboard to add a 800 mhz ram
Sep 10, 2011 | Computers & Internet
I have intel dg41rq motherboard with 2 gb kingston 667 mhz in one slot. can i put another 2 gb ram in other slot. if yes then should it have the same specification?
Intel DG41RQ Motherboard has two DDR2 (DIMM) sockets.
It Support DDR2 800 or DDR2 667 MHz DIMMs. Since you already have a 667 MHz RAM, it is recommended that you add another RAM of the same specification (DIMM DDR2 667 MHz)
However, if you add 800 MHz DIMM with 667 MHz, both would perform at 667 MHz. RAMs of different bus speed and latency usually work together but the performance is compromised.
It is always better to have RAM in pairs of same specification.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 16, 2011 | Computers & Internet
Can I upgrade my acer 5315 memory to 2GB with two 1GBs in two slots or I can put two 2GB slots adding up to 4GB? Thanks
You can upgrade it to 2GB (MAX) if icon_detail.gifMemory Type: DDR2 PC2-5300, DDR2 (non-ECC)
Maximum Memory: 2GB
Slots: 2
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Hope this helps.
Jun 17, 2011 | Acer Aspire 5315 Notebook
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Does intel desktop board d945gccr support DDR2 Ram 667 or 800 MHz
intel d945gccr supports ddr2 400 mhz & 533 mhz it maximum support ram is 2gb
Nov 22, 2009 | Intel D945GCCR Motherboard
DDR2 RAM ENQUIRY
Dear Sir
*********** Board is :Foxconn P4M800P7MA-RS2
Max Supported RAM : 2GB DDR2
Supported RAM speed: 533 MHz • 400 MHz • 333 MHz • 266 MHz. I think it deffinately solves your problem.If you have any problem post your comment with more information.
Good luck
thank you for choosing Fixya
MPN P4M800P7MA-RS2
Supported RAM speeds 533 MHz • 400 MHz • 333 MHz • 266 MHz
Aug 20, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Laptop memory
DDR2 800 MHz (PC2 6400)
the best
and 2gb or 4gb is up to you
Dec 25, 2008 | HP Pavilion dv6000z Notebook
ASUS Eee 900 Notebook Logo
228 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
