Question about Xerox Phaser 6360 Laser Printer
Phaser 6360 laser failure code 07
We have a Phaser 6360 that is networked and recently came up with a "laser failure" and error code 07 and error code 11. I went to XEROX support site, but all it said to do was turn it off, wait 30 seconds and turn it back on, which I have done several times already. Any suggestions?
  • Anonymous Mar 25, 2014
    will not collate
    Scholar:
  • 49 Answers
Yeah I had a look at the website there too, try powering down again and plugging it out for a longer period of time. You need to get the whole machine to reset and loose all saved info in the bios. Also cleaning it out of all loose toner on any contacts might help!
Niallbt
Posted on Mar 30, 2009
Xerox phaser 6360 laser failure code 10
You may have to replace the laser unit. Code 10 is a warmup failure. You need to reseat the connector to the ROS Harness first. If the issue persists, replace the laser unit. Issue persists, check continuity between pins J15 and J151. If there is continuity, replace the Engine Control Board, if not, replace the ROS Harness
Feb 03, 2014 | Office Equipment & Supplies
I have a Xerox Phaser 6360 with a ram error what could the problem be?
Are you sure it is not a NVRAM error you are recieving?
If yes, remove the IMAGING UNIT.
Close the door and Power On.
Msg gone? If yes, replace IMAGING UNIT.
If no, remove the FUSER unit.
Close the door and Power On,
Msg gone? If yes, replace FUSER.
If not, it is the ENGINE BOARD.
Oct 24, 2012 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 imaging unit stuck
The lid lifts a lever on the right side of the printer that moves a set of gears that releases the imaging unit. If the lever is broken or disconnected, it will not release. You may have to remove the right side panel to resolve it. You have to release the top, by removing 4 screws, and then the panel will release.
May 18, 2012 | Xerox Phaser 6360 Laser Printer
Phaser 6360 white lines in the print
Looks like you need to replace the imaging unit. Unfortunately, this an expensive consumable
May 13, 2012 | Xerox Phaser 6360 Laser Printer
Phaser 6360 printer as a error code 07
Unplug the printer from power for at least half an hour. Overnight would be better.
Jul 07, 2011 | Xerox Phaser 6360 Laser Printer
Xerox phaser 6360 laser failure code 07
The most likely cause here is the laser unit, check all connections to the laser unit and cycle the power (turn the machine off and on) if error continues replace the laser unit. You can buy a replacement for $350 new or $225 refurb. Part# 062K17233. Installation isn't very simple, so if you aren't a technician you may want to bring it to one. Good luck
Apr 22, 2011 | Xerox Phaser 6360 Laser Printer
I am getting a Laser failure error. I have turned the power off then on again but it keeps coming up with the error. What do I have to do? My serial number is DBY192064
Contact Xerox -- the laser is used to put electrostatic charges onto a drum. Then, the toner ink sticks to the charged spots on the drum, and then the paper is pushed against the drum,
and then the fuser melts the ink into the paper.
So, no laser means nothing gets printed.
Repair or replace the printer -- whicheve is cheaper.
Aug 25, 2010 | Xerox Phaser 6360 Laser Printer
Priter prints garbage after a few pages
well your printer is a piece throw it out and get a new one
Mar 09, 2010 | Xerox Phaser 6360 Laser Printer
Cannot install Xerox Phaser 6360 Laser Printer" on vista
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=6360&ripId=&Xtype=download
open the above link.it takes you to the download page
Nov 03, 2009 | Xerox Phaser 6360 Laser Printer
Market projection and price of of this product Xerox phaser 6360
50,000 pages a month and depending on features, $1400 to 3000.
Feb 02, 2008 | Xerox Phaser 6360 Laser Printer
Xerox Phaser  6360 Laser Printer Logo
2,844 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
