Tv goes dark Grey with vertical distortion
I can watch set for awhile then it loses something and goes Grey I can still see picture but only hear snow or static can anyone help me solve this problem?
  • manstoblame Feb 27, 2009
    Hey thanks for your response its appreciated that's not the problem I have to say. Since the Grey screen has disappeared and been replace by a black one have any ideas about this problem? Still has sound of course!
  • 790 Answers
Hi
make sure your antenna is in correct intallation or maybe you have loose contact to antenna..
Thanks!
Posted on Feb 25, 2009
Why is the picture on my RCA tv goes slowly darker as i watch it?
Contact any service technician. Its CRT base connector socket, or, LOT is faulty. This is not a user repairable fault. Replacement to any one among component stated above, or both, might need replacement. Gopakumar Gopalan Google
Mar 05, 2014 | RCA Televison & Video
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
Loss of sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...thank u!!!
rate me
Jun 12, 2009 | GE 27GT271 TV
Distorted picture on my 32" Proscan TV...(about 15 years old)
The RCA GE sets have a problem with bad solder connections in the tuner unit which also causes numerous symptoms including poor regulation, no vertical deflection, low audio or dead set.
Pulling in from the sides is either poor regulation or a bad eeprom/solder join issue
Mar 13, 2009 | Proscan PS36123 TV
Tv pictures suddenly goes dark blue
the tube could be going out. Do you have a warranty on that?
Nov 01, 2008 | Televison & Video
Looses video
There are so many thing that can cause this to happen. If you answer some questions we can narrow it down some. 1) when the picture goes black if you hit the menu button on the mitsubishi remote or on the front of the tv itself does the menu show up? 2) After it goes dark how do you get it back? do you turn it off and let it sit for awhile or can you turn it off and then right back on to get a picture? 3) what is the model number? this can be found on the back of the set. If you can answer these questions we can go forward.
Thanks!
Tim Nolan
Sep 11, 2008 | Mitsubishi WS-55807 TV
Samsung TXN3071WHF Problem
When the set is on, the red light should be off, not on...
Apr 07, 2008 | Samsung TXN3071WHF 30" TV
Won't turn on - comes on and goes right back off
Is the picture good or is it dull and dark?
A dull aka weak picture tube will cause low beam current and blank the screen. Last set I had do this I turned up the screen control to make it brighter. Use caution and don't turn it up too high were you see vertical retrace lines in the picture.
Feb 22, 2008 | Sony KV-27S42 27" TV
HD distortion Problems
have a tech change your your vertical ic.there is also 1mf 50v cap that is located in the vertical circuit that usually goes bad have it change.good luck.
Aug 02, 2007 | Samsung TXM3296HF 32" TV
The TV turns on and you can hear the sound but the picture is dark except for a thin line of blue dots in the center of the screen.
You have whats known in the biz as a cold solder connection on the vertical output IC or on the associated components. Not a job for the handi-man unless you know the issues with safty, and precautions to take with Hi voltage inside of tv sets. Shouldnrt cost much for the local shop to find your problem . Now on rare occations the poor connections are inside the IC and the IC has to be replaced. Good Luck
Jun 17, 2006 | Panasonic CT-25G6 25" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
