Question about IBM Lenovo Mouse 76H6618
Mouse scrolling probalem
Unable to scroll through mouse in ms-excel after pressed CTRL button on key board its working fine
I believe you and I had the same problem. I just figured it out, actually by accident!
In MS-Excel, on the top tool bar (File, Edit, View etc etc.) there should be a tab next to the Help tab, called Window.
Click Window, then look through the drop down until you see UnFreeze Panes (Note that the problem will be fixed if you click UnFreeze Panes, if indeed our problem was the same.)
If you do not see that option "UnFreeze Panes" and instead see Freeze Panes... then I haven't the foggiest how to help. -___-;;
Good Luck!
Posted on Mar 02, 2009
Release the scroll key
    • 1 Open and power on the laptop.
    • 2 Wait for the laptop to fully boot.
    • 3 Locate the "Scroll" button at the top-left of the keyboard. It is under the volume panel and between the "F12" and "Pause" keys.
    • 4 Press the "Scroll" button.
    • 5 Test it by opening a spreadsheet and using the arrow keys to move around on it. You can open your Microsoft Excel program or create a spreadsheet online by using Google Docs (free online productivity software). The "Scroll Lock" function will keep the current cell selected while the screen moves.
    • 6 Press "Scroll Lock" again to turn it off.
Apr 17, 2012 | Logitech Cordless Desktop MX3200 Keyboard...
E mail page is very small unable to read due to minute size
You can use the zoom function in browser to increase text size. Press Ctrl (keep it pressed) and tap + key to increase font to your desired size. To reduce size tap - (minus)key and to restore to default size press "Ctrl and 0" together.
May 18, 2011 | Yahoo Mail
Cant get the font to change on a web page that I somehow made smaller
Hello
OK, all you need to do is to hold down the "Ctrl" button on your keyboard. While you hold down the key, you need to scroll with your mouse button, If you have an external mouse plugged in, you just need to scroll with the middle mouse button. If you use the mouse pad on the laptop, the left side on the pad is usually the scroll function.
So...Just to be clear. Open your web browser. Hold down the "Ctrl" key on scroll up or down with your scroll function.
Hope this can be of help. Also, please do not hesitate to let me know if you need any further assistance.
Kind regards
Andrea
Sep 19, 2010 | Samsung N310-13GO Netbook
HOW DO YOU INCREASE PRINT SIZE ON PC SCREEN?
You did not stated what is your operating system, if this is any flavour of windows and you have scroll mouse:
1. press and hold "ctrl" button on left side of the keyboard
2. scroll mouse forward/reverse till required size of print is enquired
If you do not have scroll mouse, not everything is lost:
2. tap plus or minus key on numerical keypad till required magnification is achieved.
Other method is to tap right mouse button on your desktop, select "properties" or "display properties" depending which windows and adjust display size settings til yo are satisfied.
Hope this little tips will help you achieve desired result, please leave note which method work best for you.
Aug 18, 2010 | Gateway Essential 400 PC Desktop
How do I increase the text size on incoming e-mail or stuff I want to print. larry
The easiest way to increase the text size on screen of your e-mails and browser contents is to simply hold the "Ctrl" key and scroll up with your mouse to zoom in and scroll down with your mouse to zoom out. If you don't have a scrolling mouse, hold the "Ctrl" key while pressing the "+" and "-" sign to adjust the text size.
If you want to increase the size of the font on documents you are printing from web-sites, you have to look for the "Printer Friendly" button, or the "Print" button on the actual web-page. The developers of the article you are seeking to print have to manually do this themselves.
If it's in a text document or something similar, you can highlight all of the text at once by pressing "Ctrl+A" (The control key and the A button, not the plus button) and increasing the font size in the program you are using.
Jul 15, 2010 | Dell Inspiron 530 Desktop Computer
Scroll lock in excel 2007
When SCROLL LOCK is on, "SCRL" appears on the Excel status bar. If you press the arrow keys when SCROLL LOCK is on, you scroll one row up or one row down. Or, you scroll one column to the left or one column to the right. To use the arrow keys to move between cells, you must turn SCROLL LOCK off.
Sep 18, 2008 | Microsoft Office Professional 2007 Full...
Arrow Keys working as Scroll Keys in Excel
The key that activates thenumeric pad arrow keys it is called "num lock", and it is located on top of the numeric keypad.
Laptops may have additional function buttons to activate the arrow keys.
Sep 08, 2008 | Acer Aspire™ T180 PC Desktop
Two port kvm belkin
Switch to the First PC [Scroll Lock] [Scroll Lock] [1]
Switch to the Second PC [Scroll Lock] [Scroll Lock] [2]
Previous Active Port [Scroll Lock] [Scroll Lock] [Up Arrow]
Next Active Port [Scroll Lock] [Scroll Lock] [Down Arrow]
Switch Audio to the First PC [Scroll Lock] [Scroll Lock] [F1]
Switch Audio to the Second PC [Scroll Lock] [Scroll Lock] [F2]
AutoScan Mode [Scroll Lock] [Scroll Lock] [0]
Change All to the First PC [Scroll Lock] [Scroll Lock] [A] [1]
Change All to the Second PC [Scroll Lock] [Scroll Lock] [A] [2]
Other information:
In AutoScan mode, the switch remains on one port for 10 seconds before switching to the next. This time interval cannot be changed. To exit autoscan mode press [Spacebar].
When in AutoScan mode, no mouse or keyboard controls. If the user moves the mouse or uses the keyboard while switching the connection between computer and the switch might be interrupted and cause erratic mouse movement and errant display when using the keyboard.
Maximum resolution supported is 2048 x 1536 @ 75Hz.
If mouse movement is erratic:
make sure you do not have more than one mosue driver installed. Make sure that the driver is either for a standar PS/2 mouse or a Microsoft compatible PS/2 mouse. Make sure you do not have any mouse drivers loaded in your CONFIG.SYS or AUTOEXEC.BAT files. Avoid moving the mouse or pressing the mouse button when switching ports on the switch. You can reset the mouse and resume porper mouse movement simply by unplugging the mouse from the switch and allowing 2-3 seconds before plugging it back in.
Company information:
www.kaiweitech.com
Nov 03, 2007 | Computers & Internet
Computers & Internet Logo
358 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
