Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Cuisinart grind and brew--water does not come down
My 10 cup Cuisinart Grind and Brew- does not release the water to come down.
  • 1 more comment
  • christinalov Feb 28, 2009
    me too, its only one year old
  • rjmidwife Apr 15, 2009
    same thing, it's only 9 months old. The water goes down just a bit, then I get the beeping signal it's done, yet there's most of the water left. I ran vinegar in twice with no luck.
  • christinalov May 11, 2010
    to thamp3doctor--
    thanks for your help - the water wasnt coming over the basket, it just isnt moving at all. i called cuisinart since i only bought it in dec 07 but it is a REFURBISHED, they only guarantee if for 90 days instead of three years. bummer. i hadnt bought refurbished before, any thoughts on that?
  • 8,596 Answers
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Posted on Mar 05, 2009
  • Corey Knoettgen
    Corey Knoettgen Mar 08, 2009
    Some products, when refurbished, are almost BETTER than new. Coffeemakers and TV's, unfortunately, do not belong to that group. From what I have seen, refurbished Cusinarts are too expensive - there is usually at least one store that has a new Cuisinart for only $10 more than a refurbished one (although this may take some searching).
    Based on your symptoms, I have a couple more ideas:
    1) Let about 2 cups of distilled white vinegar sit in the water reservoir for about 20 minutes. Then press the on button - wait about 1 minute, and turn it off. Let the vinegar sit for another 20 minutes. Add 2 cups water. Then try brewing one more time.
    2) If that fails, you could actually have a busted hose inside. Since the unit is out of warranty, you could actually open it, see if there is a loose or damaged hose inside (most likely it won't be the original hose, since the unit was refurbished). You could go to a small appliance repair shop (or even Lowe's or Ace Hardware) and find a hose or other materials you need to replace the hose and/or get the loose hose to stay in place. You won't find this specific model #, but there are actually videos on YouTube that show you how to replace a hose.
    -Tha Mp3 Doctor
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here:
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
How do I clean the Cuisinart Automatic Grind and Brew Thermal coffee maker
I clean mine once a month with 6 cups vinegar and a couple cups of water. also replace the charcoal filter regularly.
Jan 14, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
My Cuisinart 10 cup Grind & Brew does not finish the brew cycle. After brewing 2 cups of coffee, it beeps 5 times as if the brew cycle has ended. Then it continues to drip very very slowly. It's only...
you need to run a few pots of straight white vinegar through the machine to clean out the lime build up in the tubes. the first time you do it, after it starts to pump the water, shut it off for a few hours and let the vinegar sit in the tubes. after doing this run a few pots of cold water through before making coffee.
Nov 07, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew beeps, but won't brew
we unplugged it for 10 minutes or so, plugged it in again, beeping stopped and it works again.
Nov 16, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart 10 cup auto grind and brew
Here is a link for the PDF version of the Instruction Booklet for the DGB-600BCC (from the name you provided I’m assuming this is the correct product).
If it’s not the right product, check out the website, you can select the product you are looking for and download the instruction booklet from the product page.
Hope that helps!
Oct 15, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 cup coffee maker warm water leaks from bottom during brewing.
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Oct 12, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a automatic grind and brew. It will only brew a full pot of coffee if I turn it on four cups. That wasn't to bad but now Ihave to unplug it to get it to come on.
Unplug for 20 minutes to fully reset, then:
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
2,055 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
