Question about GE JBP24 QuickClean Electric Kitchen Range
JBP24G broiler stuck on
If the range is plugged in, the broiler is on regardless of the oven setting. Sounds like a wiring problem or maybe something with the knob. Any advice as to what to check first and how?
  • 2 more comments
  • jmb6905 Feb 25, 2009
    The model number reads "J BP24G W1WH".
    Two more nuggets of data:
    - Prior to this happening, the broiler would not turn on (for about the past 6 months).
    - I just flipped the circuit breaker back on to cook something on the stove and now the range is back to being off all the time. I do not, however, trust that it will stay off, so I will flip the breaker when it's not in use until I understand what's going on.
    Is there a relay that gets closed to turn on the broiler? If there is I'm starting to think that's the culprit.
  • jmb6905 Feb 28, 2009
    I bought the control timer assembly new on Ebay for $65. Installed in about an hour, which includes time to clean behind the stove (which hasn't seen the light of day in at least nine years). It was a breeze. For those who like detail, here's a blow by blow of what I did (and what tools I used):
    1. Removed power at circuit breaker and pulled stove away from wall.
    2. Removed back panel (adjustable crescent wrench).
    3. Documented what wires went where (digital camera) and inspected all connections for loose/broken/shorted wires (didn't find any).
    4. Removed oven knob.
    5. Removed old control timer assembly, leaving the wires intact (adjustable crescent wrench).
    6. Removed overlay from old control timer assembly, cleaned it and applied it to the new one. I used a putty knife to pry the overlay. There was still enough adhesive for it to stick on the new assembly.
    7. Installed the new timer assembly.
    8. Moved wires one at a time from old assembly to new. I will note that some of the terminal locations had changed, but the labels were the same.
    9. Restored power at circuit breaker and tested everything on the range. No problems.
    10. Removed power again, re-installed back cover, pushed stove back to the wall.
    11. Restored power and re-tested everything. No problems.
    Thanks very much for the help MNTECH!
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Could you verify model number, using model number sticker from range, usually on the frame just behind the lower drawer, on the left side.
  • 1,543 Answers
I think you are right on with your relay comment. All the relays are an integral part of the control timer assembly (part number WB27X10215). Generally, you will be able to transfer the clock overlay from the old control to the new one, so no need to order the overlay. Not very difficult to replace.
Posted on Feb 26, 2009
Bosch oven HBL8450UC/07 broiler coil won't turn off
sounds like the broil relay stuck closed
need service relay board
Dec 02, 2017 | Bosch Kitchen Ranges
Oven does not heat
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Apr 18, 2014 | Frigidaire Ovens
Self clean works,broiler works, oven wont light
have you checked the light or maybe the oven door switch is stuck or bad
May 12, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
Oven and Broiler coils do not heat. Control works okay. The burners heat okay. Set oven to 325 degrees. Drops to 100 degrees. There is a click. and nothing happens beyond that. Try broiler. Set to HI. Does...
There is a relay in the back panel of the stove, this is probably the problem, there is also a temp thermostat in the back leading to the inside oven this cold be bad
Nov 26, 2009 | Washing Machines
Broiler does not work!
Oct 21, 2009 | Kitchen Ranges
Oven wont heat up.
after ignitor glows burners should fire within 30-60 seconds .if not your ignitors are weak (drawing less than 3.5 amps) and should be replaced Hope this helps ,please rate my solution :)
Jun 26, 2009 | KitchenAid KESC307 Electric Kitchen Range
GE gas oven won't heat
did you do it your self or did you have some one else do it for you? I ask the question because the electricity most be unplug before you do it, If any of those wires made contact or spark. Now the safety valve it's also bad, you can test that by putting a tester for the 2 wires that connets to the ignitor to see if you are getting any power when thermostat is on. if there is power replace ignitor, if not getting power replace safety valve. Or maybe your clock is set on automatic, Set it on manual.
Nov 20, 2008 | GE JGBP28 Gas Kitchen Range
Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
Dec 24, 2007 | Amana ARGS7650SS Gas Kitchen Range
GE JBP24 QuickClean Electric Kitchen Range Logo
467 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
