Question about HP LaserJet 4100n Printer
This 4100 has a static Ip address set in the unit, and the setup in the configure menu is locked. I am trying to set the unit back to factory settings to remove the static IP address, figure out how to unlock the setup in the menu. I am using DHCP.
    Genius:
  • 2,120 Answers
Turn off printer, hold down green button while turning back on.
Posted on Feb 26, 2009
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' sales@internetvoipphone.co.uk ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Jan 16, 2013 | Panasonic KXTPA50 Phone
Show me how to connect linksys wireless
Hi
The Router configuration is not that much difficult, only few thing you have sure,
1) Correct ADSL Connection User name & password,
2) Chose unique ip address in All host.
Follow the mention bellow instruction to configure and connect to Wifi Router,
  • Plug the network cable ( Mine was Blue ) which comes with the Router Box pack to your computer. The other end goes into any of the Router Ethernet Port ( 1 or 2 or 3 or 4 )
  • Now type in 192.168.1.1 in IE or Firefox or any browser. You will prompted for password which is admin. You must be logged into Linksys Router.
  • Now since your ADSL modem is also having the same IP , we will change the IP address for WRT54G2 Router to 192.168.5.1
  • Under Setup >Basic Setup look for Network Setup and Change Router IP. Change to 192.168.5.1 and Save changes.
  • Since the IP has changed you will need to close the Browser.
  • Sometimes the IP doesnt change automatically. Do a IPCONFIG / RELEASE and then IPCONFIG / Renew
Making WRT54G2 Router talk to ADSL broadband modem
  • Plugin the Ethernet cable which comes from the Modem into the port on Wrt54g2 router which says Internet.
  • Open Internet Explorer and Type in 192.168.5.1.
  • Type in same password ( admin )
  • You will be in Setup > Basic Setup
  • Take a look at Section , Internet Setup. The current selection should be Automatic Configuration DHCP. Select Static IP instead.
  • Add following details to it. In the first step we backed up All the IP configuration. Use them here
Internet IP Address: . . .
Subnet Mask: . . .
Gateway: . . .
Static DNS 1: . . .
Static DNS 2: . . .
Static DNS 3:
ADSL Modem Settings to Wrt54g2 Router
  • Once Done just save changes and you should be back at same page.
  • Now try to connect any application which talks to internet. You should be able to connect
Configuring for Wireless Connection :Now once your Router is talking with Modem, it is pretty easy to connect on Wireless. The only thing we need to setup here is Security. Lets get WIFI
  • Get to the Lynksys page again. Do all login and regualr stuff.
  • Now look for menu Wireless, click on it. You should land on Basic Wireless Settings.
  • Select wireless configuration to Manual .
  • Wireless network mode to Mixed.
  • Give a Wireless Network Name (SSID), make sure its unique.
  • Make Wireless channel selection 11 ( 11 - 2.463 GHZ)
  • Select Wireless SSID Broadcast to Enable
  • Save Settings and you will be back at the same page with changes you made.
Now Lets secure the Router :
  • Go to Wireless Security on the same page.
  • You will need to configure here Security Mode : WPA Personal, WPA Algorithms: TKIP
  • WPA Shared Key is what you will need when you connect to your router without wire. This key does the authentication and keep unwanted people away. Add 8 digit alphanumeric key.
  • As suggested in comments, there is a new mode which you can use : WPA2 with AES
  • Save changes.Just make sure you save that key to a notepad or remember it.
Wrt54g2 wireless security
  • Now last step, Move to next menu Security > Firewall .
  • Uncheck Block Anonymous Internet Requests .
  • Save Settings.
Wrt54g2 firewall settings
  • Remove the blue cable which you had connected with Router.
That's it. Now just turn on your WIFI and Search for the router. The name should be visible. Click to connect. At this stage it will ask you for the Password or Shared Key which we configures just above. It will connect and you will be able to connect to Internet.
That's all Folks. This is how you connect WRT54G2 Linksys router with Adsl Broadband Modem. If you have any questions feel free to comment.
Aug 03, 2011 | Linksys WRT54G2 Wireless Router
Is this unit (Tally 2265+) possible for LAN interface? If that so, can you give me a step by step method to do. Thanks!
The 2265+ has a LAN interface as standard, you do not need to install any options.
You can set the IP Address Via the control panel, go to the I/F section then select "Eth".
Set the IP Method to STATIC if you manually want to set an IP address.
By default the 2265+ has DHCP enabled so if you have a DHCP server the printer will obtain an IP address.
You can confirm the IP Address by printing out a configuration menu page;
Start with the printer Powered OFF
-Press and HOLD DOWN the SETUP button, and power the printer on.
-When the printer finishes initialising release the SETUP button. (this unlocks the menu)
-Ensure the printer is OFFLINE
-Press the SETUP button
-Press the BUTTON under MENU on the LCD display(Button 1)
-Press the BUTTON under PRINT on the LCD display (Button 2)
-The printer will print a menu configuration.
May 03, 2011 | TallyGenicom 2265+ Matrix Printer
How do I changed the IP address on Zebra 105SL Thermal printer? I need the steps on how to do it.
To enter Setup Mode, press SETUP/EXIT.
Press (+) or (-) until you get to IP RESOLUTION and then press NEXT/SAVE
Press the (+) or (-) key to display Dynamic or Permanent.
Select Permanent to give set it up for Static.
Go back to the previous menu and go into IP ADDRESS.
Press the (-) key to move the next digital position.
Press the (+) key to increase the value of the digit.
**The IP will not take if it is set to Dynamic**
To leave Setup Mode, press SETUP/EXIT.
"SAVE CHANGES" will display.
Select PERMANENT by using the (+) and (-) keys and then hit NEXT/SAVE.
You should now have the IP you put in configured on the printer.
Mar 02, 2011 | Zebra 105SL Thermal Label Printer
Port forwarding for model number F7D5301
To setup port forwarding on this router your computer needs to have a static ip address. Or you can take alook at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below. Open a web browser like Internet Explorer or Firefox. Enter the internal IP address of your router in the address bar of your browser. If you do not know your routers internal IP address please read our How To Find Your Routers IP Address guide.
The address bar has http://www.fixya.com/AnswerQuestions.aspx#top in it. Just replace all of that with the internal IP address of your router. By default the IP address should be set to 10.1.1.1.
We do not currently know the default username and password for your router.
Click the NAT button near the left of the page.
You should now see a new menu. In this new menu, click Port Forwarding.
Enter the name of the program into the Description box. It doesn't really matter what you put into this box, but something that will remind you why these ports are being forwarded would be a good idea.
Enter the port to forward into the Public Port and the LAN Port boxes.
Use the Protocol Type drop down box to select the protocol type of the ports you are forwarding.
Enter the ip address to forward these ports to into the LAN IP Address box. If you are forwarding ports so you can run a program on your computer, you should enter your computer's ip address into that box.
Put a checkmark in the Enable checkbox.
When you're finished, click Save Setting near the top of the screen to save your changes.
And that's it! You're done!
Feb 05, 2011 | Belkin Basic Wireless Router
Wireless printer
  1. Print a Network Configuration Page from the product.
  2. On the front panel of the product, press Setup .
  3. Press the arrow buttons to select Network and then press OK .
  4. Press the arrow buttons to select Network Settings and then press OK .
  5. Press the arrow buttons to select Network Configuration page and then press OK . NOTE: If the page does not print, unplug the power cable from the back of the product, wait a few seconds and then plug it back in. Repeat the previous steps, a-d, to print the configuration page.
  6. Change the IP settings to Manual from the printer:
  7. On the front panel of the product, press Setup .
  8. Press the arrow buttons to select Network and then press OK .
  9. Press the arrow buttons to select Advanced Settings and then press OK .
  10. Press the arrow buttons to select IP Settings and then press OK .
  11. Press the arrow buttons to select Manual and then press OK .
    1. Set the IP settings from the Manual IP Settings Menu using the following instructions:
      For this item...
    Do the following: IP Address Type in a static IP address on the same subnet. Select an IP address outside of the Dynamic Host Configuration Protocol (DHCP) range. Choose an IP address with the same first three digits as the assigned IP but a much higher fourth digit (between 1 and 254). For example, if the original IP was 192.168.0.1, assign the static IP to 192.168.0.200. Subnet Mask Do not change the Subnet Mask. Default Gateway Do not change the Default Gateway
  • tahnks
    TTYAGI
    Apr 30, 2009 | HP DeskJet 6988 Printer
    Wireless repeater
    Hi there
    Getting Started
    Setting up a Wireless Infrastructure Network
    Pleaseremember that D-Link AirPlus G wireless devices are pre-configured toconnect together, right out of the box, with their default settings.Fora typical wireless setup at home (as shown above), please do thefollowing:
    1) You will need broadband Internet access (a Cable or DSL-subscriber line into
    your home or office)
    2) Consult with your Cable or DSL provider for proper installation of the modem
    3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
    (see the printed Quick Installation Guide included with your router.)
    4)If you are connecting a desktop computer to your network, install theD-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCIslot on your desktop computer. You may also install the DWL-G520, orthe DWL-520. (See the printed Quick Installation Guide included withthe network adapter.)
    5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
    (See the printed Quick Installation Guide included with the DWL-G630.)
    6)Install the D-Link DFE-530TX+ adapter into a desktop computer. The fourEthernet LAN ports of the DI-524 are Auto MDI/MDIX and will work withboth Straight-Through and Cross-Over cable. (See the printed QuickInstallation Guide included with the DFE-530TX+.)
    Using the Configuration Menu
    Whenever you want to configure your network or the
    DI-524, you can access the Configuration Menu by
    opening the web-browser and typing in the IP Address
    of the DI-524. The DI-524 default IP Address is shown
    bellow:
    -Open the web browser
    -Type in the IP Address of
    the Router (http://192.168.0.1)
    Note: if you have changed the default IP Address assigned
    to the DI-524, make sure to enter the correct IP Address.
    -Type admin in the User
    Name field
    -Leave the Password blank
    -Click OK
    TheHome>Wizard screen will appear. Please refer to the QuickInstallation Guide for more information regarding the Setup Wizard.
    Home > Wizard
    Thesebuttons appear on most of the configuration screens in this section.Please click on the appropriate button at the bottom of each screenafter you have made a configuration change.
    Home > Wireless
    SSID-Service Set Identifier (SSID) is the name designated for a specificwireless local area network (WLAN). The SSID’s factory default settingis default. The SSID can be easily changed to connect to an existingwireless network or to establish a new wireless network.
    Channel-6 is the default channel. All devices on the network must share thesame channel. (Note: The wireless adapters will automatically scan andmatch the wireless setting.)
    WEP- Wired Equivalent Privacy (WEP)is a wireless security protocol for Wireless Local Area Networks(WLAN). WEP provides security by encrypting the data that is sent overthe WLAN. Select Enabled or Disabled. Disabled is the default setting.(Note: If you enable encryption on the DI-524 make sure to also enableencryption on all the wireless clients or wireless connection will notbe established.)
    WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
    Key Type- Select HEX or ASCII
    Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
    Home > WAN > Dynamic IP Address
    Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
    HP LaserJet 4100n Printer Logo
    570 people viewed this question
    Seeker5211
    Seeker5211
    mukhtar21 shaikh
    mukhtar21 shaikh
