Question about Canon imageRUNNER 5020i Copier
Imagerunner 5070 starts but does not print
The machine is an imagerunner 5070. Works great as a copier. Tried to use it as a printer by connecting it to a Windows XP computer through a usb printer cable. Tried all the latest Canon drivers (from their website). Problem: When sending a test page, machine starts, data light flashes, sorter adjusts, and then the machine turns off without any output. Have read network guide and setup the machine as recommended and drivers seemed to install properly. Have done web searches and tried everything I can think of in terms of settings, both on the machine and the print preferences on the computer with no luck. Would be greatly appreciative if you have any ideas for a solution.Thanks,William CD
  • wcd_disp Feb 25, 2009
    Thanks Sunilratlam for the thought. I believe using the lan cable involves a network setup. For other reasons, this becomes a bit complicated. A bit ironic, but I was trying to keep it very simple with a direct connection to the computer.
    Sergeant:
  • 199 Answers
Try with lan cable
Posted on Feb 25, 2009
    New Friend:
Same problem here: i already installed Canon iR6020 printer driver using lan network, but failed to print. Please help, thank you!
Posted on Jan 14, 2013
PCL Start Page Print print every time when power on zerox machine
You need to set the start-up options to not print the this page. You have posted in the Canon ImageRunner section but say it is a xerox.....
Feb 23, 2011 | Canon imageRUNNER 400 Printer
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
Canon ImageRunner 1025if won't fax to #s, only email
Try to connect simple phone to fax line and try to dial a number of fax that you are calling from machine.If the line is ok then do the next:
press MENU and # ( service mode) with cursors go to clear, ok, clear all and ok.Turn off and on.
If that doesnt help call service.
Be carefull: the tel. line to fax machine must be connected in L slot, not in small picture of telephone.
Jun 15, 2010 | Canon Imagerunner 1025IF Grayscale Copier
Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Apr 20, 2009 | Canon imageRUNNER 5000 Copier
Canon ImageRunner 3200
there are several steps before reaching the laser i-- clear dc con then take machine off remove plug from outlet then power up machine 2--clean the itb assembly thoroughly 3---change the transfer belt 4 --- change the itb assy. if nothing works then we will go to the laser
Jan 06, 2009 | Canon imageRUNNER C3200 Copier
Canon ImageRunner 2200 printing
the parrellel port is used also to updated machine soft ware.... if you do not have the print bootrom installed it will not print sorry
Dec 22, 2008 | Canon imageRUNNER 2200
Canon imagerunner 330S
Did you need to connect the machine for printing? Sounds like you have installed an incorrect driver. You can go to canonusa.com and find the correct driver. Make sure you specify for the correct machine.
Feb 20, 2008 | Canon ImageRUNNER 330s Copier
Error message : E000025-0002 on my canon imagerunner 5070
It has been found that if the toner bottle is not installed properly E025-0002 may occur.
rep
Nov 26, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRunner 1023iF won't print--offline
change the cable, there is a bad connection once you put a new one it should say ready
Oct 09, 2007 | Canon imageRUNNER 1023iF Black and White...
Canon imageRUNNER 5020i Copier Logo
285 people viewed this question
old marine
old marine
