Question about Kenmore 95822 / 95824 / 95829 Electric Kitchen Range
I have a Kenmore self cleaning electric range # 95014. When I try to start the cleaning feature it seems as if it is going to start then it beeps and E1 F5 comes on. What do I need to do.
  • 15,935 Answers
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.DGF$^%&*
Posted on Oct 01, 2010
Kenmore self cleaning electric range issue with F10 error during self cleaning mode
You most likely have a failed oven sensor or the control / clock has failed. Self clean mode lets the oven get extremely hot and sometimes causes electronics to fail.
Nov 18, 2017 | Kenmore 30" Slide-In Electric Range...
My Kenmore Range Model #95014 is displaying an E1 F5 error and will NOT unlock!
This error code has to do with the oven door lock assembly.
What is the complete model number listed on the unit? Look in the door area or the storage area on the bottom if you have one.
Dec 08, 2012 | Kenmore 95012 / 95014 Electric Kitchen...
I have a Kenmore Range Model 95012102. After canceling the self cleaning oven process the code E1-F5 appeared on the display panel and the oven remains locked.
The F5-E1 error code means that one of the switches on the door latch hasn't fully set itself to the door open(non clean) mode. One thing to try is to open the oven door and push the light switch in by hand while pushing the clean button on the control and see if the latch will open just a little more thusly the switch will open a bit more into the normal mode.
If by pushing the clean button...waiting 5 minutes (whith the door open)then push cancel and see if the latch fully opens..the door latch switch would need to be replaced.
The part number for the latch asm. which includes the switch is W10107820
GENE
Sep 05, 2011 | Kenmore 95012 / 95014 Electric Kitchen...
My electric range sens-a-clean button will turn on and then start? comes up and i hit start. then E1 F5 comes up. the door will not lock nor will it start cleaning. none of the other buttons will work...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 26, 2010 | Kenmore Kitchen Ranges
When i try to set the clean cycle the button just beeps and the hour ect.. will not come up?
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Aug 07, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
When I put oven on clean, it starts beeping to
heatman101
May 05, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Self-cleaning oven doesn't work on Kenmore electric oven
I suspect the timer is involved in this process. It can be set to clean automatically. You need to set the complete time at least 2 hours after start.
Aug 27, 2009 | Kenmore Kitchen Ranges
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Oven gives me an -F3- message and stops working
F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse
May 21, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 95822 / 95824 / 95829 Electric Kitchen Range Logo
155 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
