Question about Saws
400volt 3-phase drive motor details
Hi has anyone got a manual/catalogue for a Wadkin Bursgreen Bandsaw C6? What I really need from the manual is the kW rating or horse power for the 400volt 3-phase motor the UK spec machine has
  • 22 Answers
If you want to find the HP of an electric motor you can calculate it if you know the amps and it's efficiency rating, which should be on the metal tag attached to the motor. hp=volts*amps*efficiency/746
If the motor efficiency is say 82% then you would use .82 in the formula.
Posted on May 20, 2009
What would be a good replacement for a FLYGT 3152 3 phase grinder pump that uses guide rails?
you can still buy them
FLYGT 3152 3 phase grinder pump Google Search
Ads
  1. Grinder Pumps - saniflo.ca‎
    Adwww.saniflo.ca/
  • Grinder Pump Solutions, Ideal for Home Installation. Easy Install!
    Install Anywhere · No Maintenance Required
  • What's the Best Grinder Pump? - E/One Pumps Lead the Industry.‎
    Adwww.eone.com/grinder-pumps/sales-contacts
    1. Find Your Local Distributor & Get a Quote on Grinder Pumps for Your Next Project
      Proven & Reliable Pumps · Distributors Across USA · Industry Leader 45+ Years
    Search Results
    Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump 208/230V 3 ...
    https://www.sumppumpsdirect.com > Shop by Brand > Liberty Pumps US$1,363.60 - ‎In stock
    Buy Liberty Pumps LSG203M Direct. Free Shipping. Tax-Free. Check the Liberty Pumps LSG203M - 2 HP Omnivore Grinder Pump (208/230V 3-Phase) w/ 25' ...
    Grinder Pumps - Sump, Effluent and Sewage Pumps - Grainger ...
    https://www.grainger.com/category/grinder-pumps/sump...pumps/pumps/.../N-hv1 6 results - When it comes to Grinder Pumps, Grainger's got your back. ... 208/230VAC(3) .... Phase AC, Discharge NPT, Max Head - Pumps, Pump Body Material ...
    [PDF]3 Phase Simplex Control Panel Grinder & Vortex Pumps - Hydromatic
    www.hydromatic.com/resources/images/27454.pdf 3 Phase Simplex. Control Panel. Grinder & Vortex Pumps. Owner and Operational Manual. Your pump has 5 colored wires. White, Black, Red, Blue and Orange.
    Faggiolati 3 Phase Grinder Pump - Water Pumps from Pedrollo
    www.pedrollo.co.uk/pump.../Faggiolati_Three_Phase_Grinder_Pump_G271T6T1-_J... Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0. Online Catalogue ' Grinder Pumps ' Faggiolati Three Phase Grinder Pump G271T6T1- J6AA0 ...
    Vertix 3 Phase 400T Grinder Pump - Pedrollo Distribution Ltd
    www.pedrollo.co.uk/pump-shop/.../Vertix_Three_Phase_400TGrinder_Pump.html
    Vertix Three Phase FTR400T Grinder Pump. Online Catalogue ' Grinder Pumps ' Vertix Three Phase FTR400T Grinder Pump ...
    images of other pumps that might suit you.
    Jul 04, 2017 | Grinders
    Can you give me the # for the Start Capacitor for Coleman mach AC Model # 8333-8664
    These capacitors are the normal types used for single phase motors, this can be about 20- 30 mfd/400Volt .
    Sep 25, 2010 | Dometic Rooftop RV Air Conditioner
    I just purchased a used Rockwell bandsaw. I need
    Ok so you understand that Rockwell became Delta, or was it the other way round?? Either case the best source of manuals for these much loved machines is over at Old Wood Working Machines:
    http://www.owwm.com/mfgindex/detail.aspx?id=698&tab=3
    You should find your model.. 14" Delta doesn't really pin it down too exactly. The model number should be on the warning plate.
    Feb 26, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
    Reduce bandsaw speed to cut metal
    My old delta has the transmission on the back for cutting metal, and it is geared way down for power, 1140 would be way to fast, It is more like 40 rpm. I don't know if even a set of step pulleys would slow you down enough. Depends on the metal. I have the step pulleys too, but never bother to change them. The transmission, you just pull out the lock in the center of the pulley and it throws it into back gears. real nice, has an oil filled gear box on the bottom. Everybody wants my band saw!
    Feb 23, 2010 | Delta Woodworking Delta Rockwell 14 Inch...
    My 750 elec pressure washer startes for a moment and then immedietly quit running.Has current going to it. Can't find a reset switch mentioned in the manual. Water passes through the machine fine. No motor...
    the motor on these power washers is a split phase type with a phase shift capacitor in circuit all the time. it is a common fault for the capacitor to fail leaving power to the motor but no rotation. new capacitors are available from maplin the size is usually 8mf 400volt but check before buying
    Aug 27, 2009 | Garden
    Wadkin Bursgreen Blade Knife
    I don't know if they can help you out, but I see that there's a British company that sells a lot of used woodworking machinery, has some manuals available, and might just be willing to take a couple of digital photos and email them to you, considering the fact you're in a school. I figure it's worth a shot!
    http://www.wadkinmachinery.com/Wadkin-Manuals.html
    http://www.wadkinmachinery.com/Machinery-Manuals.html
    http://www.wadkinmachinery.com/rip-saws/wadkin-bursgreen-10-ags-tilt-arbor-saw-bench-10-/prod_5.html
    I hope this proves to be of some help. If not, well, good luck!
    Mar 24, 2009 | Saws
    Jet model jwbs-14cs bandsaw purchased used, need manual
    http://www.cpojettools.com/products/708115k.html
    Scroll down and click the "Manuals" tab. Your free PDF awaits...
    Dec 28, 2008 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
    Saws Logo
    291 people viewed this question
    Top Saws Experts
    Tom Chichester
    ray gallant
    Are you a Saw Expert? Answer questions, earn points and help others
