Question about Brother HL-2070N Laser Printer
Toner light stays on
My printer toner light will not go off even though I've put a new toner cartridge into it.
I've shanken the new cartridge (and the old one) and still the toner light will not go out?
  • 1 more comment
  • Anonymous Apr 29, 2009
    I have an OEM toner cartridge and still having the toner light on? Help!!!
  • Anonymous May 01, 2009
    toner cartridge was replace and the light is still on and will not print.
  • alma35 May 14, 2009
    I have the same proglem. Does anyone know how to reset the page counter? I am using a Brother toner cartridge and called Brother tech support and the insist that I provide them with a proof of purchase of the toner cartridge before they will tell me how to reset the page counter!
    Sergeant:
    Champion:
  • 357 Answers
Have you removed the tape?
Try OEM toner from the manufacturer.
Good Luck.
Posted on Mar 16, 2009
How do i reset toshiba estudio 181 printer if the replace toner light keeps staying lid even when i put a new toner
Is nothing to reset, you must verify if the toner sensor is not dirt with toner. Best regards,
Dec 06, 2014 | Toshiba OEM ESTUDIO181 18 CPM/PPM...
Toner light stays on after I changed cartridge
These are defects of Brother cartridges, even you put a new cartridge the toner empty still not reset. What we are doing is re-positioning the toner end cam on the side of the cartridge. You have to be knowledgeable with the machine to to that.
Apr 14, 2013 | Brother HL-2170W Laser Printer
Error toner is empty replce the toner even though the toner is new
Toner cartridge original or refill?
In the refill toner cartridges sometimes no replace the chip on it,put a new one chip.
Aug 14, 2011 | Samsung SCX-4828FN All-In-One Laser...
When I print a page black lines appear on the page making. Its like the toner is leaking or something. I don't know how to fix this issue. I've cleaned the inside of the printer several times and...
The toner is leaking. The toner cartridge has two compartments, one for new toner & another for waste toner. When the waste toner compartment is becoming full to its capacity it starts throwing extra toner outside of it. That is what is called toner leaking. If you can empty the contents of the waste toner compartment, your problem will be solved. One more thing if wiping blade for waste toner is worn out, it also leads to toner leaking.
Aug 02, 2011 | Samsung ML 2151N Laser Printer
"Toner not set" persists, even though new
Hey!This happens a lot!Take out all of the paper,Open the cover,take out toner,put it back and add paper!!If this does not work then the toner sensor might be faulty!Good Luck!!
Nov 03, 2010 | Canon imageCLASS® MF4150 All-In-One Laser...
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Toner light won't turn off
I print about 100 pages a day, and the toner light kept coming on after about 300 pages, even though I was buying brand new
$70.00 cartridges. Finally I looked at the cartridge carefully and put a piece of masking tape over the hole in the cartridge through which the printer shines a light that determines there is not enough toner. Now I get 1200 or more pages per cartridge. Brother assistance was no help at all, but they must have had complaints about this before. You have to keep an eye on the print quality and decide for yourself when the toner cartridge needs replacing! Good luck! I'll never buy another Brother, although the printer is terrific, but the design is flawed.
Feb 02, 2010 | Brother HL-2170W Laser Printer
Toner indicator light stays on even though it has been changed. There are no loose parts left in form the toner cartridge used before.
I just had the same problem. We have several of these in our office, but switching toner cartridges made no difference. Then I saw this site: http://www.oasis-imaging.com/images/pdf/cart_inst/TN580.pdf
I did steps 14-16, which takes 5-10 minutes. I put the toner back in the printer, turned it on, and it works perfectly now. Give that a try!
Apr 21, 2009 | Brother HL 5250DN Laser Printer
Brother MFC7440N Toner error message
It looks like the toner cartridge is not inserted correctly.
Turn of power. Remove cartridge and reinsert it in right position. Close the door correctly. Restart.
Mar 27, 2009 | Brother MFC-7440N Laser Printer
Hp laser 4500 says toner is low or out even after new cartridge
There is a toner sensor in this printer that shoots a beam of light through the toner cartridge. As long as the toner is full and blocks the light, it sees it as being full. If it were the sensor, it would tell you this for all the toners, though. The printer also calculates how much toner may have been used and gives warnings based on that. It could be that this isn't getting reset after you change toner. You can reset the toner gage by going into the reset menu and selecting "New xxxx cartridge" and changing it to YES.
Mar 17, 2009 | HP Color LaserJet 4550n Printer
Brother HL-2070N Laser Printer Logo
632 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
