Question about Sony Playstation 3 (PS3) Console
No Picture?? ok so i switched from HDMI to component cables and i have done this process many times before but this time my picture turned black and stayed black.   It asked for the ps3 button to be pressed but when i pressed it the lights just kept blanking for ever. so i turned off the ps3 and tried again and all i got was blinking controller lights and a black ps3 screen. i have tried 3 different cables on three different tvs. still no luck.  I hope someone can help me because i think that 150 price tag sony charging is ridiculous
    President:
  • 2,653 Answers
Check out my common PS3 problem and repair guide for tips and suggestions for more details about your problem.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 25, 2009
Tv picture ok but alot of times if channel is hd it will break up and shows a black screen with weak or no signal
This could be an issue of not enough signal from your HDMI cable, make sure that cable is ok, if possible hook another TV up and see if it works ok
Another issue is a bad main or mother board, the one the HDMI plugs into, there is an IC on that board that does nothing but process the high def signal, that isn't a part you can change yourself you would need a replacement board.
Nov 11, 2017 | Televison & Video
Monitor goes black - green light stays on
My screen is black, why do I not have a picture?
Answer Antenna is not hooked up to television.
  • Make sure that the antenna cable is correctly connected to the television. If it doesn't work there appears to be no signal.
Problem is caused by television broadcast
  1. Push 'INFO' button.
  2. If the screen shows channel number (1, 2, 3, etc) try another channel. Not all channels broadcast at all times.
  3. You may have a signal problem. Contact cable provider or local broadcaster regarding the specific channel.
Television is in EXT or SIDE mode, and there is no external source provided, so screen mute (black screen) is activated.
  1. Push NEXT SOURCE button on the remote.
  2. On the screen appears all sorces.
  3. Press the UP button to switch to the TV mode.
If you are using an accessory device (DVD, DVR, or VCR), be sure the device is on and running.
Blank screen when connecting to the accessory (DVD, STB, PC) device via HDMI to HDMI.
Answer
  • Make sure the cable is well connected .
  • To check which connection is selected, Press the i+ button on the remote control.
  1. When you see Blue mute / blank screen and the i+ display does not indicate any video resolution indication then there is no valid signal detected.
    • Make sure the HDMI output of the accessory is valid by changing the video output resolution to a resolution which the TV can handle.
  2. When you see a blank screen and the i+ display shows a video resolution indication then the connection is correct.
    • The blank screen is caused by the accessory device and not by the TV.
    • To detect and remedy the problem caused by the accessory device, check the instruction manual of this device.
  3. If the problem remains : reselect the HDMI external source input by changing to the other HDMI input and back to the connected HDMI :
    1. Press AV on the remote
    2. Press up and then ok
    3. Press AV again
    4. Press down and ok
    5. The compatibility check process between TV and accessory device will start over again.
  4. Reset (switch off and back on) the TV and also reset the accessory device.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sound delay when using a hdmi cable
It is normal and real stupid---either ignore it (I won't) or go component as in a blind test done at our shop people could not tell on identical sets on HD program which was HDMI and which was Component---most of the time they thought the component was the HDMI picture
Apr 02, 2012 | Westinghouse 26" LCD Flat-Panel HDTV
My DirecTV is connected via HDMI and also Component. Picture and sound blanks out. If I switch from HDMI to Component, it will come in. And vise versa. It seems to be getting worse. Is there anything that...
can you be more specific
it is normal for the picture and sound to go out when switching from HDMI to component - it takes tv some time to resync when you switch inputs
if this is not issue please be more specific and write me back and i can help more
Mar 27, 2011 | Sansui HDLCD3210 32 in. LCD TV
Flashing / ghosting with Bose Lifestyle V30
I recommend you switch from using HDMI cables to using component (R/G/B RCA-style) cables. HD picture is superior through component cabling, and solves several HD picture issues. Component cabling from your devices should eliminate your problems.
I hope that helps.
____________________________________________
Download Bose LifeStyle V30 User Manual
Mar 15, 2009 | Bose Lifestyle V30 Home Theater System -...
I have issues with my unit. Sync problems
Are you sure it's the TV and not the video source ? Have you tried other video sources ? You can also try to switch over to component cable. The red/green/blue colored cable. You only need HDMI for blu-ray to get the 1080p. If your TV is only 1080i then you don't even need to use HDMI. Also, some sources actually look better with a component cable compared to HDMI. Give it shot.
Mar 14, 2009 | Samsung LN52A550 LCD TV
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
When The HDMI cables are connected, I use Directv, I have just recently started to have the picture come on and then start flickering and various color bars pop up on screen, then the screen will go black...
It is possible that the HDMI cable is defective. Did you try another cable?
It is also possible that the HDMI port on the TV is failing.
This can be determined by the process of elimination.
Jerry G.
Jun 06, 2008 | JVC Televison & Video
Blue tint to picture
cheak projecter mode your in under hdmi mode blue cool settings on hi ? eash input setup is differt use warm colers not cool 1 2 3 so on u know what i mean sum sterio have hard time with hdmi out to dvi might wann use coumpuont out from reciver to 15 pin vga sum projecter in 720 p mode have gard time 1080i so on u relly need dvi out from setrio to dvi more less for monister cable best use compunt cable projecter only 16 millon colers anyays ok not 529 billon like samsung plmasa would be were u would wann use hdmi to get all those colers but coumpunt is more then worthy wiyth projecters output ok
Jan 23, 2008 | Onkyo TX-SR674S 7.1 Channel Up-Converting...
Sony Playstation 3 (PS3) Console Logo
55 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
