Question about KitchenAid Ovens
Need instructions on how to remove microwave to fix oven latch...
Already have the part #4451424 kitchen aid
model #kemc308ksso have to remove wall microwave to replace the latch dont know how to get microwave out!!!!!!!!!!!!!!!!!!!!....
  • KitchenAid Master
  • 3,361 Answers
In the cabinet above the microwave there wil be 2 to 4 screws that have to be removed.
You need 2 people to remove this unit.
Posted on Feb 25, 2009
My convection oven ring does not work
These tend to crack and "unzip" because they are such a tight circle... Kill the power, and meter the ring element for ohm's resistance. If the element tests ok, check the wires to the element for overheating, and if those look fine, remove the control board and look for burnt solder joints where the relays are mounted. Multimeter DM10T
Feb 22, 2015 | KitchenAid Kitchen Aid KEBS177SBL Single...
Kitchen aid torsion spring
I looked up the parts break down for this model there are 7 different ones your last 2 digits are missing this unit dos not use torsion springs the MW door should have a brown arm riveted to the door that goes into the frame this activates a switch
Feb 18, 2015 | KitchenAid Kitchen Aid 30 In. Stainless...
Needd to change kitchen aid wall oven from celsius to fahrenheit
Press and hold the Broil Max Econo button for 5 seconds.
Only this button and without turning on oven.
Feb 17, 2013 | KitchenAid Kitchen Aid KEBS177SBL Single...
I need a user manual for a kitchen aid convection/ microwave oven combo ser # kems307dbs6
Hello & Welcome to FixYa
Please click on this link to download the manual for your Kitchen Aid. Please get back to me if you have any other questions.
Kevin
Dec 26, 2010 | KitchenAid Ovens
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Will not come on after self cleaning
this is a common occurance with many self clean ranges, especially slide in and wall oven units. the kitchen aid ranges usually have a non reset hi-limit. meaning it opens one time and needs to be replaced, sadly.
to replace the thermostat can be tricky to do if you're not experienced, so if you have any reservations about taking you range apart, call a qualified tech in your area. if you decide to take a go at it, well first things first.
**FIRST unplug from the wall or shut off the breaker**
*the other issue is not knowing what model you have.
I can tell you most recent kitchen aid units made by whirlpool have a fixed hi-limit at the back outer oven wall. remove the rear panel, and the hi-limit should be easily accessed. that part # 8300802
hope that helps,
good luck
Sep 28, 2009 | KitchenAid Ovens
Need to replace light bulb in kitchen aid microwave
KitchenAid wants $58 for the replacement bulb. I bought it for $1.99 from www.lightbulbsdirect.com and it works just fine. The Item number is Q5G412V. It is a halogen 5-watt, 12-volt bipen G-4. Replacing the bulb requires some dismantling of the microwave. At first I was nervous about removing so many parts to get to the bulb but in the end it really wasn't so bad. The only tool I needed was a Phillips screwdriver. I surfed the net a eventually found instructions left by a friendly Blogger that guided me through the whole process. KitchenAid engineers were so STUPID when they designed this microwave. It takes two hours to replace a bulb that should take 5 minutes. Oddly enough, replacing the bulb in the normal oven below the microwave oven is a piece of cake.
Jan 19, 2009 | KitchenAid KEMC308 Electric Double Oven
Ovens Logo
195 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
