Question about GE WBSR3140DW Top Load Washer
No hot water into washer
Hot water is getting to the washer, but when the dial is set for hot water, the water coming into the machine is lukewarm. New GE toploader
  • 26 Answers
In your problem you describe that you are getting hot water are you getting cold water too?. Make sure on the water valves are on the full open setting to eliminate a water pressure diffrence and any other valves connected to those water lines. If that checks out check for clogs in the hoses and filters that could be backed up. If that dosent fix the problem then its in the washer either the hot/ cold regulators or the timer.
This is for GE WBSR3140DW Top Load Washer
Heres a link to help to find the correct parts.
http://www.partstore.com/Model/General+Electric/General+Electric/WBSR3140DW.aspx
Hope this info helps to anyone who reads it.
Posted on Feb 25, 2009
Not heating
Hi Pam:
The water enters the washer via hot and cold hoses.
Either your hot water heater is not working, or the hot water solenoid control on the washer is not working.
There may be a dial with settings for wash temperature.
I'd be checking that control unit.
Nov 21, 2015 | Washing Machines
Lack of hot water
washing machines are a hgigh demand water usage sytem anyway..I would use the regular water heater with the washer as it holds 40 gallons and most washers pump in a minimum 20 gallonson the low side..
Mar 08, 2014 | LG WM0642H
Cold Pulses when set to HOT only
if you want only hot water, shut off the cold.. its only really used during the rinse anyway..
Feb 02, 2014 | GE Spacemaker Washer and Dryer Electric...
We have both hot and cold hoses going into washing machine but cannot get anything but cold or lukewarm water no matter what setting we choose. The pipe leading into the hot water hose feels warm and we...
sounds like the mix valve on the washer is broken and not opening properly -- the mix valve is the valve that both hot and cold water are connected to on the back of the machine.. turn off water valves and remove the hoses,, remove the back panel from the washer -- the mixer is held in place by one little screw,, also mark the wires going to the mixer ( hot/cold ) --- remove the mixer valve and take it down to your local appliance repair shop and match it up to a new one -- install the new mixer and connect wires and panel and then hoses and all will be working good as new.
c...
Feb 01, 2011 | Hotpoint Washing Machines
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Warm water filling up washer, with no hot water hooked up to wash
exactly
it will maintain 60 degrees but cycling hot cold
thermistor
Sep 29, 2009 | Maytag Performa PAV2200
Washer wont allow cold water
Mixing valve should lock out the hot water when on the cold water setting. Either your hoses are crossed, or the mixing valve is flipped. To see if one of these is true, try it on a hot water setting to see if cold water comes in, or try just swapping the water hoses.
Jul 05, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Wash cycle water is not hot for Speed Queen AWS53NW
Possibly a stupid answer..most water supplies at the hose connection have valves...turn off or at least reduce the amount of cold water with valve closed or partially open.
Apr 21, 2008 | Star Speed Queen AWS53NW 26" Top-Load...
GE WBSR3140DW Top Load Washer Logo
315 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
