Question about NetGear DG834G Router
ROUTER NOT SWITCHED ON - NetGear DG834G Router
  • 55 Answers
All you should have to do to turn this router on is plug the power in. Check to make sure any power strips or UPS's that you (the router) are plugged into are turned on as well.
Posted on Mar 17, 2009
The protocol has been switched to 802.11 and needs to be returned to 802.11b. How can we do this with none of our computers able to talk to the router without internet access?
I assume you mean your router has been switched to 802.11G ONLY traffic and your network cards only support B. Only solutions that come to mind is either try using a ethernet cable to directly connect to the router and then change settings. Or try resetting the router by removing power cable then holding down reset button.. I don't recall but some software revision might have wireless on by default. The router would be named WRT54G by default with no encryption. Keep in mind resetting the router will turn all the settings to default including admin password.
Nov 16, 2011 | Linksys Wireless-G WRT54G Router
Thomson 585 router - internet light is red when router is switched on and will not allow access to the internet. Router must be switched off and on several times before light becomes green and allows...
First of all, can you confirm that you get internet access continuously when connected to the Modem directly? If No, I would suggest you talk to the ISP else lets try the steps below, .
So try power cycling the entire setup
1. Power off your modem 2. Power off your router
Now Switch on your modem, leave it for a minute and then switch on the router. Usually a power drain will help. I noticed that you have been switching off your router several times. Lets try this once
Alternatively, I would suggest you reset the router once and set it up again.
Aug 10, 2011 | Computers & Internet
I switched off my router suddenly and found that it was out of order. all lights of Lan and Wan are on when the router is switched on. I have tried to reset the router by holding on the reset switch but it...
Base from the description of your problem and from the status of lights on your router it seems it already encounter a hardware failure and you already did a reset but still the same so sorry to say but your router is already bad and needs a replacement , so if its still under warranty have it replace from the manufacturer.
Mar 06, 2011 | ASUS WL-500W Router (WL500W)
D-link dir-130 was in the process of saving settings for port forwarding, I did not receive a settings saved screen. Now I have no internet, and the router will not let me back in
Reset the router.
Push something small in the reset hole on the back, some routers need to be switched off, then push the reset and keep it pushed for about 20 seconds after you have switched it back on
Jul 26, 2010 | D-Link (DIR-130) Router
I've switched from DSL to cable. Can I still use this router?
Yes you can use this router. Plug the modem in the WAN/Internet port of the d-link router and your computer into one of the 4 LAN ports. then follow this
Jun 09, 2010 | D-Link DI 514 Wireless Router (DI-514)
How do I connect a replacement desktop cable connected PC to the existing wireless router
The wireless router and Cable Modem need to be switched off for approx 3 mins.
new PC is switched off and connected by network cable to the router.
The wireless router and Cable Modem are switched on and left until their start up routines are finished (approx 5 mins).
New PC is swithched on.
Nov 12, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Switched from DSL modem to Cable modem. Linksys
If you had your linksys router controlling the DSL connection, it was most likely a PPPoe connection requiring a username and password. Most cable companies have dynamic IP address and do not require a username or password.
Open your internet browser, IE, Firefox etc and go to 192.168.1.1 >
Enter your router username and password, typically admin and admin
In the setup tab, change your connection FROM whatever is listed there and make sure it is Autumatic DHCP Save your settings, and restart the router.
You should be fine.
Oct 27, 2009 | Linksys Wireless-G WRT54GS Router...
Switched from dsl to cable, cannot get roter to
Cableshould be directly plugged into the computer.Router not required for cable connection.
Jul 17, 2009 | Computers & Internet
Virtual server keeps resetting
U should overwrite or refresh by firmware v2 ,<tool> <system>and find firmwareV2.00B01T01.TH.20060809
Jan 15, 2009 | D-Link DSL-G604T Wireless Router
NetGear DG834G Router Logo
27 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
