Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Bobbin thread not feeding properly
Bobbin thead all jammed on bottom of seam
  • 23 Answers
The tension used to wind the bobbin is not wright, remove all the thread and rewind the bobbin. Make sure that you put the bobbin in place exactly as shown on the image, I didn't in the beginning and couldnt figure it out, now I now IT IS VERY IMPORTANT TO PLACE THE BOBBIN CORRECTLY.
Posted on Feb 26, 2009
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Thread jams up under fabric. could the machine be out of time
No, Check the theading of the bobbin and the bobbin thread tension. The thread should double back on itself coming out of the bobbin holder.
Jan 24, 2011 | Singer 2263 Mechanical Sewing Machine
I have a 9420 the bottom thead is bunching up and then stopping the machine
change the needle
clean under the needle plate where the feed dogs for lint
clean the bobbin area for lint or loose threads
rethread the machine--make sure to get every thread guide
Nov 22, 2010 | Sewing Machines
Bobbin trouble
Remove the needle plate for better access and try using a seam ripper to gently cut the threads and continue to remove with the tweezers.
The needle plate is the metal plate under the presser foot and is held into place with at least two screws.
The bobbin fits into the bobbin case.
The bobbin case fits into the bobbin shuttle.
Once you get the jam cleaned away, raise the needle to it's highest position and remove the bobbin case and/or replace the bobbin case.
Jamming can cause the machine to be out of time.
If you thead the machine with the presser foot up, have the bobbin inserted into the bobbin case correctly and the stiching is loose and loopy the machine may need to go into the shop for service.
May 01, 2010 | PfaFF Hobby 4260
Thread jams in bobbin case
Open the bobbin area and make sure it is clean.
Change to a new needle.
Thread the machine with the presser foot up.
Make sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the guide on the bobbin case.
Take hold of the end of the top thread and lower, then raise the needle to pull the bobbin thread up.
Take hold of both thead ends and pull them under the presser foot and to the back of the machine.
Place fabric under the presser foot. Lower and hand walk the first couple of stitches.
When sewing, and you need to stop to adjust the fabric, make sure the needle is down into the fabric. This will keep the stitch from malformation and causing a possible tangle.
If you need a manual, you can download one free at the Brother website.
Mar 20, 2010 | Singer 3116 Simple
The machine sews on top but not on bottom
Check the manual, if you do not have one, you may find one at Singer or sewusa websites.
Make sure the bobbin in installed correctly so the thead is feeding from the bobbin spool in the proper direction and through the correct guide(s).
Always thread the top thread with the presser foot up.
Use a new needle and make sure the flat side of the needle shaft is facing toward the back of the machine.
By hand, lower and then raise the needle as you hold onto the thread tail at the needle. This should pull the bobbin thread up through the needle plate. Take both threads under the presser foot and to the back of the machine.
Lower the presser foot onto the fabric and hold onto the thread tails or just hand walk the first stitch.
Feb 25, 2010 | Singer Sewing Machines
The bobbin thread is sewing loose stitches and jamming the machine. I have re-threaded everything, brushed out the bobbin casing, changed needles, adjusted thread and bobbin tension, and am stuck and...
Always have the presser foot up when you thead any sewing machine.
Make sure the flat side of the needle shaft is facing to the back of the machine.
Don't do anything to the bobbin tension. Set the top thread tension to what is recommended by the mfg.
Make sure the thread from the bobbin is feeding from the bobbin in the correct direction and through the correct guides.
After inserting the bobbin and threading the machine, lower the needle (hold on to the thread tail) and then raise it by turning the hand wheel by hand to pull up the bobbin thread.
Gently pull the two threads under the presser foot and to the back of the sewing machine before you begin to sew.
Feb 19, 2010 | Singer 3116 Simple
My sewing machine will not pick up the bobbin thread. It sounds normal and pulls the fabric through, but the threads do not intertwine. I had been having problems with the bottom thread clogging and...
when the needle pulls the fabric into the feed dog you dont have enough fabric behund the neelde when you srart, and the fabric gets caught in the feed and the bobbin case underneath clean it out anf change the needle they often get bent after they get tangled in the thread and fabric
Dec 10, 2009 | Bernina Sewing Machines
My bobbin wont feed through
take the bobbin out check for debris (pieces of thread, lint, etc.) that may be jamming the bobbin. check under the feed plate for a thread jam or debris. check if your bobbin is wound too tightly. it can happen! then it will keep breaking. the other adjustments are mainly for thread tension- the spool on top. if they're too tight, the thread will keep breaking. you can tell- once they're properly adjusted- by the quality of the stitch. check the bobbin first! if it's too tightly wound, you can probably adjust the winding tension on top. try a different bobbin. if that works then 'rinse and repeat!'.
good luck!
Sep 24, 2009 | White Sewing 1418 Mechanical Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
116 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
