Question about Apple iPhone Smartphone
Iphone problem my dialing number is not working
  • fbrett320 Apr 29, 2009
    My iphone dial pad doesn't work... hit Phone button, I see the dial pad, but can't use it. I can still make calls via the contact list, I can recieve calls - so it's an iphone problem not an ATT problem
  • OnlyOneN
    OnlyOneN May 11, 2010
    Have you tried rebooting or restoring the phone?
SHOULD BUY IPHONE OR NOT JUST TELL MR & WHT IS THE LATEST PRICE IN USA
Posted on Feb 27, 2009
Increase the number of rings on iphone
http://www.fixya.com/support/r8598373-set_iphone_others_many_rings_before
By default, the iPhone rings 15 seconds before going to voicemail.
1. Figure out your voicemail access number. Dial *#61# and then press Call on your iPhone's keypad. The first block of text you'll see on the screen that comes up will be:
Setting Interrogation Succeeded
Voice Call Forwarding
When Unanswered
Forwards to +1XXXXXXXXXX Enabled
Where +1XXXXXXXXXX is shown as an actual number - write this number down because you'll need it in the next steps.
2. Dial *61*+1XXXXXXXXXX*11*tt# where +1XXXXXXXXXX is the number you wrote down from the first step above and tt is the length of time in seconds for which you want your iPhone to ring. To get the + sign to show up, hold down the 0 key for a couple of seconds and release it when it turns into the + sign in the readout above. Then press Call.
Jan 20, 2012 | Apple iPhone 3G
Tip
Set iPhone+Others for how many rings before voicemail picks up
When Unanswered
on Mar 08, 2011 | Cell Phones
Apple iphone 3g 16gb i foreget my password
TRY THESE STEPS:
Type in and dial the following numbers. In case the first doesn't work, try the succeeding suggestions and so on and so forth:
1. 00000(4 or 5 or even 8 depending on your phone model.
2. 11111, 22222, 33333, etc.
3. If it does not work still, try this one: 12345, 09876, etc.
4. In some cases, the last 4 or 5 numbers of your SIM is the number code.
5. If it doesn't work still, contact your cellphone technician.
I hope it helps. Thanks.
Jul 23, 2011 | Apple iPhone 3G
How to delet an individual dialed or received number on iphone4
Apple does not allow you to delete individual dialed or received numbers in your call history.
It is possible however, if you jailbreak your iPhone. For instructions on how to do this, visit this link
Mar 03, 2011 | Apple iPhone 3G
Set number of rings before voicemail iphone
This procedure allows your iPhone to ring for longer or shorter periods than the default setting of 20 seconds before voicemail answers. *** Attempt at your own risk but if you pay attention to the keys you input and follow the directions you should have no problems.
1. On your phone, dial *#61# and click Call
The screen will display:
When Unanswered
Forwards to +1xxxYYYzzzz
Enabled
2. Write down the xxxYYYzzz number (including +1) - this is the number to your voicemail.
3. In order to make the + appear on the keypad in the next step you'll have to hold Zero down for a few seconds, then it will become a Plus (+). Dial **61*+1xxxYYYzzzz**30# and hit Call. +1xxxYYYzzzz is the number you wrote down previously, 30 is the delay in seconds. The delay can be set in 5 second increments, 30 is maximum.
4. Dial *#61# to verify that the new settings are active.
5. Verify working voice mail.
If you find you or your contacts are not being forwarded to your voice mail you have incorrectly altered your voice mail forward number.
To find out what it is and try again:
Dial ##002# and send. This will reset that forward number to factory defaults.
By then Dialing *#61# you will again display the your current (default) voice mail forwarding number.
Return to step [2] and continue.
*** Use this tutorial at your own risk ***...and if you have the time you can always give AT&T a call to have them change the number of rings on an incoming call before Visual Voicemail kicks in. I was able to quickly change the duration on my own, using these diagnostic iPhone GSM codes. The default time duration before Visual Voicemail intercepts the call is set by AT&T to 20 seconds. You will be able to add another 10 seconds yourself, but if you want your callers to wait more than 30 seconds before voicemail picks up then you'll need to contact AT&T technical support - they can change the duration to 45 seconds upon request.
Dec 19, 2010 | Apple iPhone 3G
Numbers won't stay that i dial
did you by chance update to the iPhone 3.0 Beta?
if so your issue is a bug in the software.
if you didn;t update yet,
press and hold the home and the sleep button until the iPhone reboots.
then give it a try.
Jun 05, 2009 | Apple iPhone 3G Black Smartphone
My phone has been working but today it will not let me dial out any phone numbers on my keypad
Hold the power button and the menu button down until the phone reboots.
You should be good to go
Jun 01, 2009 | Apple iPhone Smartphone
Touch screen of phone on my iphone isnt working
Looks like your iPhone may be damaged.
Have you dropped it?
What kind is it the IPhone-iPhone 3G?
If you can give us your serial number we at Apple will see what we can do.
To obtain your serial number go to settings click general and go to about the first part o the iPhone.  Thank You. Steve A
Dec 22, 2008 | Apple iPhone Smartphone
Keypad problem
try restoring or reset settings
Mar 11, 2008 | Apple iPhone Smartphone
Can't make calls
Plug into itunes,and click the restore button when the iphone pops up.
Jan 09, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
32 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
