Question about Hitachi CMT-2097 20" TV
POWER NEED TO CHANGE FROM GERMANY ELECTRICAL PLUG(240V)TO U.S. (110V)
  • 790 Answers
Hi
this needs to convert from 220 to 110volts but i think this unit is autovolt they can plug into 110 to 220 automatically..
Thanks!
Posted on Feb 25, 2009
I want to run this compressor "RITIN RT2012" 2HP 12L (1.5kW) compressor. It's a 110V AC drive unit and I have 240V. Can I run it or do I need to convert the Power supply.
You can't just run it on the 240 Volt supply. Check the motor nameplate. If it says it is rated for 110/220 or 115/230, or 120/240 Volts, then it is capable of running at 240V. This will require a wiring change, and you may need a larger size power cord.
The electrical diagram should be on the motor name plate or under the cover to the electrical terminals on the motor.
May 25, 2011 | Air Tools & Compressors
I bought an Acer netbook last week. Love it. Today, I am in Germany and it will not charge. I have an adaptor, but the charge light on the netbook does not come on at all. It boots up fine from the...
Most power adapters are able to run the Euro 220v @50/60hz but make sure. The "Input" side should say 110-240V and 50/60hz if it says only 110v and 60hz then you power supply will not work in Germany. Also check to see if the "output" on your power cord is the same as what is your laptop is. I have mixed up power adapters before and it will simply not work. If you try and plug it in it will fry it. If you have to grab a new power adapter the best store i can think of is a place called Saturn Electronik kinda like Germany's Best Buy. It has a hazard orange sign most times.
May 09, 2011 | Acer (56.04145.901) (5604145901) Power...
I have a GE Profile Harmony Dryer. No Power. 240v, 110v, 110v at the outlet but soon as I plug in the dryer I see 240v, 110v, 0v. Is the problem in the dryer or the power outlet on the wall?
Its not really clear to me where your measuring once you plug in the dryer, but all phases are measuring the correct voltage before, it appears you have an open circuit once you plug the dryer in. Now a dryer is 2 phase, so I would check all of your wiring connections, I would also check your circuit breaker and try swapping it out with a new one(as a last resort). Do some experimenting. In a dryer the heating elements are the only thing that runs on the 240V power. I would swap the hot leads in the dryer and see if any of the electrical components come on. Also try testing the continuity on your dryer plug wires to make sure there isn't a break in them (which can be proven by swapping the leads because now the same lead will read 0V on the other terminal).
Mar 31, 2010 | GE Profile Harmony DPGT750EC Electric...
Want to change my 110v plug on my dewalt radio to 240v
Your radio must be a import from the U.S.A. Your radio will not work on 240v YOU WILL BLOW IT UP!!! You need a step down transformer 240v to 110v to goto your radio, you will have to do a search on Ebay in Power tools. You sould notice the lead on your 110v radio is not like normal flex as its only single insulated for 110 volts.... Don't put a normal plug on or you may have to call the fire brigade!!
Nov 01, 2009 | Dewalt DC011 AM/FM Radio
Need to convert my 110 volt 15amp to 240 volt
You can buy a transformer which allows all 110v power tools to work from a 240v supply. You will also need to change the plug on the compressor to a yellow 110v type. You can buy transformers for around £25 and around £3 for the plug
Mar 29, 2009 | Craftsman Air Tools & Compressors
What voltage will a HP 6715b accept?
hi no need of transformers.. ur lappy is ready to accept 230v-240v...
Feb 07, 2009 | HP Compaq 6715b Notebook PC
Power conversion
Ram,
Good day mate, no problem you can plug your dvd direct to your outlet since it indicates 100 - 240V it only means your player is capable of having either 110V 0r 220V.
note: also try to check 1st if you will see a voltage selector at the back of your dvd player. it's either a slide switch indicating 110 or 220V. if no sign of this selector no problem you can plug your player straight to your socket.
cheers
mark
Jan 29, 2009 | Durabrand DVD-1002 DVD Player
Hitachi CMT-2097 20" TV Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
