Question about Initial IDM-1731 Portable DVD Player with Screen
My portable dvd player shows no disc when i put my dvd in player
My portable dvd player shows no disc when you put cd in player
  • Anonymous Mar 22, 2014
    I have a etec dvd player model 2200 and i put a disc in it says no disc
    Genius:
  • 1,175 Answers
Hi....
Very lightly clean the laser lens ( looks like a very small eyepiece)
with 91% or better alcohol on a swab. Then very lightly dry it off.
Also..have you tried another DVD or CD in it?
Check for dust or debris in where the laser pickup is
Posted on Feb 25, 2009
SOURCE:
When I install disk, ' No disk' shows on display.
IS the disc on a CD-R or CD-RW (burnt disc) some portable players will not support those types of disc's.
It could also be a different region dvd that doesnt match the region codes of the dvd player. There are no known region hacks for your make and model of dvd player.
Sorry and thank you for choosing Fixya! Post back with more info for further help.
May 18, 2009 | Durabrand 8.5'' Portable DVD Player
Disc does not spin and shows on screen that there is no disc
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Mar 29, 2009 | Mintek MDP-1810 Portable DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
No disc
check ur cd/dvd into other drive if it reads properly then there is the problem dvd player, try cleaning the lens
if it does not work take to service center
Nov 23, 2008 | Curtis DVD8017 Portable DVD Player
Dvd plays cd's but not dvd's - gives no disc message
I have a durabrand portable dvd player we've owned for about 1yr and had just started messing up. When you put the dvd in it says it's loading and shows the blue dvd screen it just wont come on but you can hear it trying, please help what could be wrong?
Aug 12, 2008 | Durabrand DUR7 Portable DVD Player
Stopped playing...all DVD/CD
TRY CLEANING THE LENS WITH A SPECIAL CD LENS CLEANER.. YOU CAN BUY IT WALGREENS OR WALMART
Mar 07, 2008 | Mintek MDP-1020 Portable DVD Player
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
No valid disc
Hi, Try cleaning the lens. A CD cleaner for PC CD/DVD will also work with DVD players. If problem is not corrected, you may need to seek the services of a qualified professional. Good luck and kind regards.
Sep 28, 2007 | TruTech PVS12701 Portable DVD Player
Initial IDM-1731 Portable DVD Player with Screen Logo
621 people viewed this question
Top Initial Televison & Video Experts
Steve Allison
Steve Allison
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
