Well, you'll want to get under your car and locate the oil pan. It should look something like a metal box and you'll find it in the middle of the engine area. There will be a nut, probably 9/16th size, so you';ll need a wrench or socket. When this becomes loose enough, use your fingers to twist it off. Be warned! Once this nut is off oil will immediatly become rushing out. You'll probably want to have a bucket or something to catch the oil. Once the oil has drained, tighten the nut back onto the oilpan. The oil filter shouldn't be far from the oilpan, probably a little bit upwards, you'll should be able to see it from where you drained your oil, but you can also sometimes spot it when leaning over your engine. Be sure to wet the lip of your new oil filter with clean/new oil before replacing it!
The oil filter is located at the front of the engine on 1.4 & 1.6 engines and at the rear on 1.8 & 2.0 On the diesel it is located at the rear above the drive shaft
SOURCE: what torque for rear wheel bearing Ford Focus 2000
Can only find out that the hub needs to be tightened to
235 nm Dunno if this helps
SOURCE: Locating oil filter
If you're under your car, right at the oil pan, look straight up from
the pan (if your head is toward the back and your legs toward the
front). It is up about a foot, and the filter should be jutting out to
the back. If it's the first time you're changing the filter, I believe
it will be white, for motorcraft. About the diameter of a chunky soup
can.
Thanks.
I have the same problem with a Ford Ranger truck 2005... How much oil do I put back into the engine? And I understand that this new model takes a different oil number...
Thanks for your help.
R. Cusack
