Cannot connect wireless as of this monring
Hi, I cannot connect wireless, since this morning. Checked 2 wireless networks that I am on. Please help
  • 203 Answers
Have you recently done a windows update?
if so, try rolling back wireless drivers.
Posted on Feb 25, 2009
Cant hook into the network with a secondary wireless computer
Follow the steps below to configure settings:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the router's wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new Password and click apply. You will then have to use the same Password for all the wireless devices connecting to the network.
Perform the below steps if your wireless computer has windows XP:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' astab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
If the computer has windows Vista then perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side
menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 03, 2009 | NetGear RangeMax WPN824 Router
Limited connectivity with my wireless connection on my laptop--my wife's computer connects fine
HI, Follow the steps below to configure the settings:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Now please perform the steps below on your wireless computer:
8. Go to the 'Wireless Networks' tab .
3. Click on the 'wireless network' tab.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
Regards
Anand
Sep 27, 2009 | NetGear WGR614 Wireless Router
Can not get conected to wire less router on virgin
HI, follow the steps below to configure settings:
Now if your computer has windows XP then perform the steps below:
For Windows Vista on wireless computer perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
I hope the steps above will help resolve the issue. If you need any further help please email us back so that we can continue to work on a solution.
Regards
Anand
Sep 25, 2009 | NetGear WGR614 Wireless Router
I have netgear router mr814, my friends can connect to the router with 2 pc, but i cant, i am ably to connect to other wireless networks but not to mine... when there is no password on i can conncet but...
If you have windows XP then perform the steps below:
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
4. Highlight the SSID from the list that you want to connect to.
You can visit the link below to follow the steps in case the issue occurs
Regards
Anand
Sep 10, 2009 | NetGear MR814 Wireless Router
Please help me get my wireless settings
If you have windows XP on the laptop then perform the steps below:
4. In the preferred network box, Select all SSID and remove the name from the list. Once the list is empty, Click OK.
For Vista on the laptop:
6. Click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
Regards
Anand
Aug 30, 2009 | Acer Aspire 3000 Notebook
I have Sky Broadband withe netgear router. Bought a netgear wireless adapter to use with my Advent PC. Installed everything. Good connection, but won't connect to internet. Keeps flicking from connected to...
HI,
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as sky (unless you have changed it).
scan for the wireless network on the computer with the adapter and connect to the network.
Regards
Anand
Aug 03, 2009 | NetGear WG111 802.11g/b Wireless Adapter
Losing connection to wireless router everytime rebooting
It seems that you have windows XP on this computer. Follow the steps below;
Regards
Anand
Jul 14, 2009 | Zyxel (91-004-361002) Wireless Router
Wg511 v2 'sees' the network but just won't connect just keeps scanning, updated to latest driver but still no go. Pulled out old WG111 v2 USB wireless card and it connects straight away. Pull the Wg111v2...
Follow the step below to configure wireless connection.
Jun 30, 2009 | NetGear WG511T 802.11g/b Wireless Adapter
My laptop cannot locate my network
I can not open my labtop on my wireless, it ask me for my password, I give it and it tells me it is the wrong one. I have 2 computers on it with know problems..
Feb 25, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
I am no longer able to connect my wireless router...why?
Hi canuck07,
Here's how to remove the ad-hoc setting (I'm assuming you're running Windows XP):
1) Right-click on the wireless icon on your system tray (right end of taskbar) and choose "Open Network Connections,"
OR go to Start Menu > Control Panel > Network and Internet Connections > Network Connections.
2) Right-click the wireless connection and choose Properties.
3) Select the Wireless Networks tab.
4) Under "preferred networks," select your network and click "Properties."
5) On the Association Tab, the bottom check-box corresponds to ad-hoc networks - uncheck it.
Hopefully this will make your adapter able to find your network. Please let me know if this doesn't work, or if I can be of any further assistance.
H2H
Dec 26, 2007 | Linksys (WMP54GS) 802.11g/b Wireless...
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
