Question about Pentax Photography
Pentax p30, had to replace the batteries, have them in correct as manual indicated. Using Energizer 357 batteries. They worked until I had to put new roll of film in the camera, then I could not get the film wind lever to move to advance the film?? Anyone with ideas?? thanks
  • lostn50s Mar 01, 2009
    Kaylanting, what is the problem with your pentax p30t?
Hey sorry i dont have an answer but i have the same camera can you help me?
Posted on Feb 27, 2009
Camera says batteries low, replace
Make sure you are using fresh batteries when you are replacing them. If you are using rechargeable batteries, let them charge until the indicator light on the base unit turns green. If the indicator light on the base unit flashes red, the batteries are no longer good.
Cheap batteries form dollar stores (Sunbeam, or store brand name) do not last long, and digital point and shoots eat up those types in a few uses. Best to use Duracell or Energizer batteries for Cameras. They dont have to be Lithium, or digi camera specific batteries. Those are expensive and unnecessary. Basic Duracell or Energizer will do.
Feb 03, 2015 | Sanyo Vpc-s1414 14 Mp Digital Camera Vpc S...
Light meter underexposed
The K1000 were designed to use Mercury batteries. After those were banned in the USA folks moved to other types of batteries as in Alkaline, those start out strong, then fade fast. This change in voltage causes errant light meter readings. Batteries I use in my K1000, K1000 SE, and K2 are Silver Oxide 357/303 1.55 volt 0% Hg, by Energizer. Use any brand you want.
Nov 14, 2013 | Pentax K1000 35mm SLR Camera
Hello I have Pentax IST DL just took out of case put new batteries in did not work battery light came on. Tried again came on but did not take photo. Then turned of again, tried lots of new battery. ...
The early ist cameras had a battery indicator problem which Pentax never addressed. Most owners learned to live with it by turning it off and on several times until it showed full power.
Dec 15, 2010 | Pentax Cameras
Replacing batteries on Energizer Hard Case Lantern
If you have the Energizer Hard Case Lantern TUF4D1, simply grasp the whole front of the lamp piece (including the rubber cover), and twist in a counter-clockwise direction to remove. Then squeeze together the two black tabs and pull the battery compartment out to replace the batteries.
Jul 05, 2010 | Energizer Eveready TUF4D1E 4D Cell Lantern
The LED's on my Energizer charger flash red and green constantly.
If your charging 2 batteries only they must be palced in the following poistions on the charger
1. both side by side in the 2 left slots
or
2. one each in the two right slots.
Otherwise the batteries will not charge.
The users manual can be downloaded here:
http://www.energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Thanks for using FixYa.
Kelly
If the batteries are charging the battery indicators
Mar 24, 2010 | Energizer Rechargable Battery with Charger
Pentax P30 - shutter jammed after flat batteries, no lights
Common problem.
Shutter motor needs replacement.
Mar 19, 2009 | Photography
Camera will not accept the new batteries.
I called pentax and they told me only use Energizer batteries. I did not think it would make a differance but the "cheap" batteries do not deliver steady power even that there new the power flux is enough to throw these new cameras off. there that sinistive. Energizer's deliver a very even power and that is the only battery that pentax recamends. All outhers even dualcell delivers uneven power and that will cause the camera to think the batteries are dead.
Jan 04, 2009 | Pentax K200D Body only Digital Camera
Pentax p30 camera
Hi - You can download the manual by clicking the link underlined in blue below:
Pentax P30
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 10, 2008 | Photography
I have two Pentax p30 35mm cameras but both wind on mechanisms have stopped
Double check which way the batteries are installed, you may have them reversed. The cap should be marked positive, meaning the negative side go toward to contact in the camera body
Jan 10, 2008 | Photography
Photography Logo
318 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
