Question about Dell 3010cn Laser Printer
Printer error message 004-321 restart printer took out toner compartment and put back in and it stil doesn't work any other ideas?
  • 49 Answers
Remove the drum. turn the printer off and on. when it asks for the drum, install it. if that does not help, call support (1-877-459-7298) and they will probably replace the drum.
Posted on Feb 27, 2009
Dell Printer problem
Generic toners often cause this error. Was the cyan you purchased a aftermarket compatible?
Jul 26, 2012 | Dell 5100cn Laser Printer
I'm getting the following error: Dell 3100cn Laser Printer error 004 332 problems
Try restarting your printer, if this does not help make sure that the toner cartridges are set in properly and locked in place.
Mar 28, 2011 | Dell 3100cn Laser Printer
Fairly new toner and display reads "Install black cardtricge"
I have just resolved the "Install black cartrige" issue on my printer I am not sure if it will solve everyone's problem but these are the steps I took to solve the problem.
1. removed the black cartrige.
2. removed all the paper from the tray and noticed that one of the pages was a little jammed.
3. I then turned the printer on and off again and still encountered the "Install black cartrige" error message.
4. I then put the black cartrige back in the the printer and restarted the printer.
5. When the printer restarted it started to initialize correctly and I perform some test prints to confirm that it was back up and running.
Apr 07, 2009 | HP LaserJet M1522nf Multifunction Printer...
17H Service Required
Please follow the solution in the link below. Also as you putting in the cartridge always check for loose toner in the area and on the cartridge itself as this can block the sensors.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=74,E=0000000001343666831,K=8485,Sxi=0,Case=obj(3510)
Niallbt
Mar 29, 2009 | Xerox Phaser™ 6115MFP/D All-In-One Printer
RESTART Printer
The new magenta cartridge you put in is bad. If you put the old one back in then you get the low toner message. Take the new cartridge back and get another new one.  I found the answer on the dell troubleshoot website
Feb 03, 2009 | Dell 5100cn Laser Printer
Keep Getting Error Message "(Colour) Toner Not Installed"
I think in the menu you have to select replace cartride.. then new or same with new toner...
each toner cartridge has connections and you must make sure all are tight... or you get alot of errors.
Sep 10, 2008 | Konica Minolta magicolor 2300DL Laser...
Dell 3010cn Laser Printer Logo
525 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
