Question about RCA 20F511T TV
My rca television gos off and on and channel surfs all on its own ..i took the back off and used a can of air to blow any dust off but it still does it. The television is only 3 years old.
  • sunterrie9 Feb 25, 2009
    do u know approximently how much that costs? and where is the control panel at in the tv? I assuming that its where the buttons are for the channel change..on off..am i right or wrong?
  • 790 Answers
Hi
you need to replace all tact switches at the control panel
Thanks!
Posted on Feb 25, 2009
On RCA HDTV wh74xy1 lamp blows out every three months
fan has a lot of dust on it.get a can of air take lamp housing and hold fan fins and blow off dist also there is a nothe fan on dlp chip.in front. take of lower back cover easry to do.good luck
Nov 17, 2013 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv has sound but no picture.
Yes, dust is the number one cause to all electronics, i recommend using compressed air to clean the inside every month or so.
Jul 19, 2010 | Mitsubishi WD65737 65" DLP TV
My Sony KP-51WS500 television video shuts off audio keeps going
Blowing dust out? cough!! cough!!
If it was with a standard vacuum I would suggest that you have knocked or blown a wire off somewhere.
The normal vacs are usually too strong and can blow wires slightly off or completely off. A hand held should be used because they do not over **** or blow.
I doubt that the tube is bad,But the lamps may be compromised by overheating by virtue of blowing dust on them. Only a visual inspection will tell.
Please rate my help++++Thanks for using Fixya
May 29, 2010 | Sony KP-51WS500 51" Rear Projection...
My tv won't stop changing channels by itself
I just fixed the problem very easy... The RCA have a front cabinet which is very easy to remove. I took it out and the only thing that is expose is the speakers and the sensor control. Is a little panel about 5" just spray it with dust spray and that what I did Is not changing channels by itself anymore. I save $3,000 I was about to trash it. Im happy I did that...
Dec 05, 2009 | RCA P52926 52" Rear Projection Television
The tv turns on and turns right back off.
Yes thats the RCA box capacitor. You can get the replacement at www.tvrepairworld.com its listed under the RCA repair kits category and it has a picture of the Box capacitor.
Aug 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Continues to channel surf wont stop on ant station
When i had the same issue, i used VCR or VCR Combo to set the channels,
May 14, 2009 | RCA R52WM24 52" HDTV Projection Television
1995 ford windstar overheat after replacing the thermostat
I had the same problem and it was the water pump, loosen the belt and check the pump for excessive play.
Dec 19, 2008 | 1995 Ford Windstar
Want to dust bulbs and screen on inside. how do i take apart?
don't remove anything use a clean lense cleaning cloth that's all dust the mirror.
we us compressed air to blow out the dust
Oct 06, 2008 | RCA R52WM24 52" HDTV Projection Television
I have a old rca tv. today when I turned the tv on the stations just keep changing and its a static. What could make that happen?
there are a few possibilities. Only two of which you can correct.
First, blow some pressurized air into the remote control, especially around the channel up and down buttons.
Second, see if the channel changing stops when you remove the remote battery.
third, blow compressed air into the channel up and down buttons on the tv.
If you are still have the problem then you have an internal part to replace and we recommend you use our premium service for that.
Good luck.
CH
Jul 29, 2008 | Televison & Video
Every channel is static, no sound
Unplug the tv set for 30 seconds, plug back in and turn set on. if this does not return your audio you need and you're NOT still under warrantee you should at least open the TV and check the board where the components are mounted and resoled any that look bad. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint. All can be replaced at a local electronic or hardware store and they're easy to replace good luck
Jan 03, 2006 | RCA F27645 27" TV
RCA 20F511T TV Logo
148 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
