Question about Panasonic PT-LB20U Multimedia Projector
Image turns green when switch to RGB signal on Panasonic PT-LB20U
The image is fine on video input but when the iput is changed to RGB, the image turns green.
  • 442 Answers
How much of the image turns green
Posted on Feb 28, 2011
Is Panasonic projector PT-LB20U compliant with HDCP?
Since the PT-LB20U only has VGA, S-video and composite video inputs, it isn't HDCP compliant. You would need a device with DVI (sometimes), HDMI, or DisplayPort inputs. See page 15 for the connections available on the projector.
Panasonic has the manual for the projector on the product page: http://shop.panasonic.com/support-only/PTLB20U-EC.html . The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/PTLB20NTU.PDF .
I wish that I had better news for you.
(the high definition copy protection details require the digital video signal capabilities of the newer inputs. Most digital to analog converters (HDMI to VGA, for example) do not support HDCP.)
Nov 26, 2015 | Panasonic Office Equipment & Supplies
WHY IMAGE BECOMES GREEN WHEN CONNECTED ON CABLE TV ?
If it's on HDMI input, then the wrong setting of RGB/YCrCb
Sep 06, 2014 | Panasonic PT-AE8000U Full HD 3D Home...
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
I can't get any red in my displayed image. I have
The red lcd has gone bad...change the lcd...and it will work..
Art
Jul 29, 2010 | Panasonic PT-LB20U Multimedia Projector
Distorted picture.
Is the menu text clear on the screen, when it's focused correctly. Or is that also distorted.
If the menu text is OK then the picture signal is dodgy. could be due to a bad earth lead on the video cable.
Is it distorted on all signal inputs
Oct 30, 2009 | Panasonic PT-LB20U Multimedia Projector
Panasonic Viera TH-37PX8B Green Screen When Turn On DVD Player
I had the same problem, after reading the forums and playing around for a while I cracked it. It was to do with the output from the DVD player, in the DVD player setup I changed the output from RGB to s-video and bingo! Hope that helps
Jun 10, 2008 | Televison & Video
Panasonic PT-AE900U
Very confusing posting !
RGB input for DVD Player ?
HDMI input missing ?
Apr 13, 2008 | Panasonic PT-AE900U Multimedia Projector
Green Picture
The problem sounds like one I had. If so, the cause is as follows.
The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
Possible solutions:
1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
Panasonic PT-LB20U Multimedia Projector Logo
1,118 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
