Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Dual Boot problem in Windows XP & VISTA
Hi i have two hard drives in my computer and one is 160GB and others is 110GB,on first one i have windows xp and on second one i have windows Vista Home
now i want that whenever i start my computer it shows me the selection for boot windows,i do not want switch my hard drives everytime when i start my pc
if u guys have any solution then please tell meit will be very helpful for me
My xp boot.ini setting is below:
[boot loader]
timeout=5
default=multi(0)disk(0)rdisk(0)partiti...
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WI... Windows XP Professional'' /noexecute=optin /fastdetect
C:CMDCONSBOOTSECT.DAT=''Microsoft Windows Recovery Console'' /cmdcons
multi(0)disk(1)rdisk(1)partition(1)WI... windows vista'' /noexecute=optin /fastdetect
And vista boot loader entry is below:
Windows Boot Loader
identifier {current}
device partition=C:
path Windowssystem32winload.exe
description Microsoft Windows Vista
locale en-US
inherit {bootloadersettings}
osdevice partition=C:
systemroot Windows
resumeobject {6d46ceb5-0313-11de-b974-a664572c7007}
nx OptIn
sos No
  • 565 Answers
Don't try to edit the xp boot.ini or the vista bootloader. It only leads to other problems and headaches.
Try this first: Take note as to which drive has vista on it, put your vista installation cd in the drive and let it boot to the "installation window", then choose "repair", then "startup repair." Make sure you choose the drive that already has vista on it. Let that run and when it re-boots you should then be given a choice to boot to vista or "other windows".
There is also a (free) program called EasyBCD. Download that, read the directions and have at it.
If none of that works, you'll have to do a clean install. Install XP on one drive first, then Vista on the second drive in that order. The Vista bootloader will pick up the XP. However, XP is NOT forward compatible and will not recognize the Vista bootloader. Make sure that you don't have any flashdrives or media cards plugged in before doing the install.
Another approach would be to shrink the Vista volume, creat a new partition, then install Linux Ubuntu that partition. Linux will detect all of the OS's and create a boot menu. Unfortunately, you'll lose about 5 gigs to the Linux OS and it's swap partition, but then, you get to goof around with Linux :-)
Posted on Feb 25, 2009
How to install xp on this unit from vista
You have to format the hard disk before you can insall XP on a Vista machine, or you can try to install a dual boot system. Go to Microsoft.com and search for dual boot system help
Jan 29, 2010 | Computers & Internet
How to: Dual Boot system with XP & Vista on separate hard drives
If XP where your primary OS this would not be a problem. Since Vista is the Primary you are going to need to get a boot loader that will start before either OS does and use that to choose OS at bootup.
Sep 12, 2009 | Dell Studio XPS Desktop Computer
How to uninstall Windows Vista
You must use a full retail or OEM version of XP (not the cd from your old computer) this makes life really easy and can usually be downloaded from the web.
You must also have a genuine XP key, which has not been used on another system.
Next you should know or find out the specifications of your system, to do this goto Manufactures website.
The most important step is to find out if your hardisk is using SATA interface (if so you will require the SATA XP drivers and a floppy disk, as this is the only way that XP can install these drivers.)
Install XP via cd rom by booting cdrom at system start (if you cannot do this then you must access your system bios at first boot by pressing F2 or Del keys(or whatever key your system uses) and change the boot option to cdrom as first drive.
If your system uses SATA press F6 when XP prompts “press F6 to install other” at very beginng of XP install and install sata drivers from floppy.
Jun 12, 2009 | Microsoft Windows Vista Home Premium SP1...
Trying too dual boot xp pro on toshiba tecra m5. conflict image of original xp pro, in slim select bay hdd. Need help with settings so as the same op system can be used on both drives.Any help would be...
in order to dual boot something.... you need to partition the hard disk... if there's only 1... you need a program that will create another partition from drive C...
for example the size of your Hard disk(drive C) is 160gb
you need a program that will split 160gb into 2 it should come out and you will have now two drives (C & D) with a size of 80gb each...(It depends on how large you want the other drives to have)...
the program is called Partition Magic 8.0 if you want that program.. i can send it to you... just contact me in my yahoo messenger... derick_10_02@yahoo.com
now it's time to install the Windows XP in each drive then you'll have a dual boot... or you can install Windows Vista on the other drive... so therefore you'll have Windows Xp and Windows Vista in one PC...
hope it will help you... tnx
Jun 07, 2009 | Computers & Internet
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Mar 25, 2009 | Acer Aspire 3680 Laptop
Xp & vista toghether
You will need to partition your hard drive into two bootable partitions. Install Vista on one partition and XP on the other. This will make your system a dual boot system. Hope this helps.
Dec 21, 2008 | Microsoft Windows Vista Home Premium with...
Use of vista theme at windows xp
u need luna 2 tools bars black nice blue best for xp
Oct 07, 2008 | Microsoft Windows Vista Ultimate Edition
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
Dual boot
Hi abc_19 ,
Before I answer your question , let me tell you that you need to back up your data.Also, make sure that your system hardware supports Vista.
You also need to have genuine windows XP and windows Vista disks handy with you.
1. Partition your hard drive. In Windows XP, using the $50 PartitionMagic or (according to one of our readers) the free GParted Live CD, create a new "primary" partition to install Vista on. Make it at least 20 gigabytes in size.
2. Install Vista on the new partition. Pop in the Vista CD and point it to your newly-created partition as the installation destination. Installation will restart your machine at various points.
3. Choose your operating system on boot. Once Vista is installed on your newly-created partition, on boot up, you'll get a choice to start XP or Vista. The default is Vista. However, this can be changed using Vista's boot manager.
When you're up and running with Windows Vista, be sure to check our our Vista upgrade power tips.
The original article appears below for posterity, and it's still got relevant screenshots and other info for those of you looking to dual-boot XP and Vista.
http://www.youtube.com/watch?v=nNZi5fLpqus
(WATCH THE ABOVE VIDEO FOR MORE HELP)
Cheers :-)
Jun 05, 2008 | Dell Latitude D600 Notebook
Occasional BOOT hang
Try using the event viewer and see if it comes up with anything
How To Use the Event Viewer Applet
http://www.bleepingcomputer.com/forums/topic40108.html
Jan 02, 2008 | ASUS P4S800D-X Motherboard
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
201 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
