Question about RCA P52926 52" Rear Projection Television
I have a Akai 55 inch rear projection tv that the horizontal appears to be out. I have had a technician look at it but he advised me that he cannot get the replacement part. I do not want to part with it so can you help. The Model number is 38003CEX60156IJ and the Serial number is PT5598HD
  • 4,234 Answers
Can you post the part that is supposedly not available? Update this with any details from the tech's visit. This will give us the info we need to assist further. Also, any description of the original problem would be helpful.
Thanks,
Dan
Posted on Feb 25, 2009
Akai PT5598HD 55 in. Rear Projection HDTV-Ready Television tv looks like it is now 3d model with red out by about a half inch. will not adjust on converage settings
sounds like your convergence board has failed ...there may be a kit at tvrepairparts.com..there you can search your model number for a convergence repair kit...you will need to have someone with electronics repair experience install the parts if you do not know how yourself...these kits range from 40.00 to 100.00 and usually come with a cd or dvd to aide in installing these components.
Dec 20, 2010 | Akai PT5598HD 55" Rear Projection...
Color distortion in an Akai ( Cheaper model Rear Projection tv) I
Ur convergence is dead.Try Tv repair World.com.
Buy a whole convergence board replaced it.
Jan 01, 2010 | Akai PT4799HD Rear Projection Television
Color seperation but still have a picture
Problem with tv is convergence-unit is made by samsung.You can eithor replace the convergence board or trouble-shoot it yourself.
gonna need to replace both ics STK392-040-then check all the 3.9 ohm resistors
Sep 10, 2009 | Akai PT5598HD 55" Rear Projection...
I have a 55 inch Akai rear projection tv.When I turnit on,the red timer light blink,and that is all.I've heard about this problem on here before.No pic and no sound
on the main board of the tv there is a fuse located if that is faulty this can happen,there are also many other possibilities but check out the fuse first many a times replacing the fuse solves the problem as its very negligible to replace the fuse the cost of fuse is under $1.
Mar 03, 2009 | Akai PT5598HD 55" Rear Projection...
AKAI PT5598HDI 55" PROJECTION TV HAS POWER AND SOUND, NO PICTURE
Open the back of the tv and check Fuses, sound like the high volt over loaded
Jan 11, 2009 | Akai PT5598HD 55" Rear Projection...
Picture on AKAI 54 inch HD ready tv is not square.
akai is not a good brand of tv to start with they seem to have alot of problems and finding parts is impossible to do
Oct 16, 2008 | Akai PT5598HD 55" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Horizontal lines
check all caps in power suppy and vertical. but i would point to the power supply first. the last tv i seen with this problem, i ran it for 20 minutes, and turned it off and felt the tops of all caps, found one or more that was hot. there was the bad caps, without the headache of checking all of them on the cap checker. this might not work for you. not all bad caps get hot.
Apr 09, 2008 | Akai PT5598HD 55" Rear Projection...
Something like this Id have someone who knows there way around electronics, a qualified tech or someone you trust really well :-) Does the crackling affect the TV picture at all ? My first guess would be dust and or dampness on the audio components. Sometimes this can conduct electricity across small pc chips and reak all sorts of havoc. I had an old Tomas electric organ once, and it actually caught fire because two speaker wires were rubbing together and eventually wore thru the insulation and shorted out, but it was also making alot of crackling and static noises. Try raising and lowering the volume low to high and high to low and see if the crackling noises gets worse. Some audio amplifiers put out quite a bit of power, so I wouldnt trust leaving the TV on without a fire extinguisher handy.
Nov 06, 2007 | Akai PT5598HD 55" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
