Question about Aprilaire 700 Humidifier
Aprilaire 700 using too much water-------
My Aprilaire 700 is producing about 1 gallon of water/minute of operation-whats wrong?
    Novelist:
  • 189 Answers
There is a small oriface that is installed next to the solenoid valve. It sounds like this oriface is missing. It reduces the water flow through the humidifier when it is working properly. You should be able to disassemble the solenoid fittings to check and see if the oriface is in the water line. For a "temporary" fix regulate the water pressure down by closing down on the saddle valve.
Good luck
HVAC Teacher
Posted on Mar 08, 2009
I have an Aprilaire 700 unit it vibrates when the water solenoid turns on how do I fix it
You gotta remember that the 700 also has a fan that blows air through the water filter/grate. The fan could have a warped blade and thus vibrates when rotating. Although there could be nothing wrong with this unit at all as it is not unusual for any solenoid to vibrate when it's engaged. Could could replace it if you'd like. EBay is your best source. But your posture should really be 'if it ain't broke, don't fix it.
Jan 13, 2015 | Aprilaire Humidifiers
Aprilaire 700 water never shuts off
the float may be bad or sticking allowing water to run continusly even when unit is off.
Nov 06, 2013 | Aprilaire 700 Humidifier
Replaced water panel and the light keeps blinking to change it agai...model 700
Sorry to read about your problem, I hope this helps you out.
did you hit the reset
Digital Humidifier Control (Model 700): (Automatic or Manual mode) Check system operation and reset Change Water Panel indicator by setting the knob to "Test/Reset". With HVAC blower operating and HVAC calling for heat, humidifier will operate for one minute. DO NOT LEAVE IN TEST MODE AS HUMIDIFIER WILL NOT OPERATE.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 29, 2010 | Aprilaire 700 Humidifier
Not working
HI, Troubleshooting an Aprilaire Humidifier
Aprilaire, a manufacturer of indoor air quality products including thermostats, air cleaners and dehumidifiers, also offers a line of whole house humidifiers. Installed in your existing heating and cooling system, humidity is produced by a supplied water source that flows over a water panel before being distributed throughout your air through the heating and cooling system. Issues you may need to troubleshoot with your Aprilaire humidifier include error messages and the unit producing too little or too much humidity.
Things You'll Need:
Replacement water panel
Turn down the control dial by one setting if condensation appears on your windows or walls.
Turn up the control dial by one setting if there is a lack of humidity, often indicated by dry skin or peeling wallpaper or paint.
Turn the control dial to "Test/Reset" if the humidifier does not run. Verify the heating and air conditioning unit blower is operating. If the heating and air conditioning unit is not operating or you are unable to resolve the issue contact a heating contractor.
Contact a heating contractor if you turn the control dial to "Off" and the humidifier continues to run.
Contact your Aprilaire dealer (see Resources) if you notice an error code on the display and the "Call Dealer for Service" light flashes.
Turn the control dial to "Off" and turn off the water supply if the yellow "Change Water Panel" light flashes. Lift the front panel off of the humidifier. Slide out the water panel. Insert a new water panel. Replace the front cover. Turn the control dial to "Test/Reset" until the "Humidifier On" light flashes. If you feel uncomfortable changing the water panel, contact a heating contractor.
Tips & Warnings
Purchase replacement water panels through your Aprilaire dealer or a heating contractor.
You can get parts from the link below:
arnoldservice.com/humidifier_parts.htm
Hope it helps.
Thanks for using fixya....
Nov 17, 2010 | Aprilaire 700 Humidifier
Aprilaire 700. It works on fan on mode but not otherwise. It's never on and the humidity reading is always way below the setting. It should turn on automatically to bring the humidity up, right?
It appears your Aprilaire model 700 is wired to only operate when your HVAC fan is operated by your thermostat. Your HVAC installer can wire the humidifier control to operate the humidifier during a heat call, fan call or to turn on the fan when there is a need for humidification. Please contact your HVAC installer to have them change the wiring.
Thank you for giving us the opportunity to be of service
Sincerely,
Brad Uselmann
Technical Support
Research Products Corporation
www.aprilaire.com
Nov 01, 2010 | Aprilaire 700 Humidifier
Aprilaire 700 water panel light won't reset
the solinid may be stuck or the humistat is wired wrong
Jan 16, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 humidifier not adding any humidity
Thanks for your Question,
Sounds to me like you have a calcium build up in the Solenoid, which is restricting flow to the unit for proper operation, you might even have a bit of restriction in the copper line feeding the Solenoid, replacement of the solenoid would probably take care of your problem, one quick tip, in the spring and summer months, its a good idea to shut the water off to the unit, this should make the Solenoid last a little longer, hope this was helpful to ya, please let me know, thanks again,
mr.grzz
Jan 12, 2009 | Aprilaire 700 Humidifier
Aprilaire 700 operating at wrong time
You want the humidifier to run in heat mode which is the r-w1 terminal on the stat.
Nov 17, 2008 | Aprilaire 700 Humidifier
Water panel light
The reset is to place the controller in the "test/reset" position. The furnace must be in heat mode and operating at the time. The green light will blink for about 1 minute if operating properly, then cut off when placed in a normal setting.
Oct 19, 2008 | Aprilaire 700 Humidifier
Humidifier control .
if humidifier was wired into thermostat circuit for power instead of seperate transformer , this can happen. you need to see if you voltage going to the solenoid valve. if you do , and it isn't opening, the valve is bad . this is assuming that it is using a # 50 relay to come on only when the fan runs . . make sure the water valve is open
Dec 24, 2007 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
473 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
