Question about Toshiba Satellite Pro 4600 Notebook
What does each LED light (5) stand for in the front of the unit?
I have a Sat. Pro 4600 laptop with no manual. It has 5 led lights infront of the unit. 1st one is "plugged in, what are the other 4 for?
  • Toshiba Master
  • 1,314 Answers
Hello. Your user's manual can be found here, click on user's guide.
The system indicator panel lights indicate the following:
AC power
Hard disk drive
Diskette/Cd/DVD drive
Thanks and please if you could take a moment to give this solution a rating of fixya, I'd greatly appreciate it.
Posted on Feb 25, 2009
  • 33 Answers
Hi deankayla,
here is the link to the product's support site:|PS460U
When opened please click on User's Guide and it will be downloaded...
Greetings from Germany,
PS: Please don't forget to rate this solution after you've tested it out! Thanks in advance and have a nice day!
Thought I should add more detail about what the laptop is doing. The laptop sat for a long time with a dead battery, because the power supply low voltage wire got chewed by one of our puppy's when it was...
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
Oct 30, 2013 | Toshiba Satellite C655D-S5084 Laptop
I need to connect the switch leads for power,reset, and HDD LED activity to my front panel LED to the corresponding connectors on the motherboard for the Gateway DX4300-03.
PinSignal NameIn/OutDescriptionPinSignal NameIn/OutDescription1HD_PWROutHard disk LED pullup (5 V, 15 mA max)2HD_BLNK_GRN+BLNKOutFront panel green LED3HD Active#OutHard disk active LED4HD_BLNK_YLW_BLNKOutFront panel yellow LED5GND Ground6SW_ON#InFront panel On/Off button7FP_RESET#InFront panel Reset button8GND Ground9+5 VOut 10FPSLP#InFront panel Sleep button11IRRXInIrDA serial input12GND Ground13GND Ground14Key Not connected15IRTXOutIrDA serial output16+5 VOutIR power
Nov 29, 2011 | Gateway DX4300-03 Desktop PC
No pic or sound. the stand by light blinks green then the lamp light blinks red untill it turns off all toghther. the lamp is broken i just want to know if that is the only problem or if the driver may...
Flashing green standby led light at the front panel is an indication that the unit waiting for the lamp to turn on. Since the lamp led light flashes, the unit sensed it already burned out.
Faulty lamp driver has a different error code which is "flashing of the standby light 5 times".
Your unit will back to normal operation again after the lamp replacement.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Jul 22, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Dell case 4600 replaced mother board with gigabyte but front power wiring needs different connection plz show diagram
Pinout (Wiring diagram) for the GigaByte GA-8I865GVME motherboard's Front Panel header,
(Looks like a 1 but it is an 'Eye'. GA-8 i 865GVME ),
{The plastic front of your computer is the Front Panel.
The area of pins on the motherboard, that the Front Panel cables (Wires) connect to, is the Front Panel header }
;Motherboard Manual download page,
Look under the heading - English
Look across from English, and click on the country name nearest yours.
This is a PDF file. After you click on the server country it may take 30 seconds or more, to see the first page come up.
It may also take additional time for the file to fully download.
(Took approximately 30 seconds just now for me. Medium speed DSL connection)
At the top of the PDF file is the page number box. It is to the right of the Down Arrow.
Go to Page 6.
Processor to the top, Ram Memory slots to the right, the Front Panel header is at the bottom right corner.
It is two rows of pins that are laid out horizontally. It is parallel to the bottom outside edge of the motherboard.
Go to Page 22.
F_PANEL (Front Panel Jumper)
The pins are numbered Even on the top, and Odd on the bottom.
Starting at the Left side of the motherboard going to the Right, for the TOP row of pins;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20
Starting at the Left side of the motherboard going to the Right, for the BOTTOM row of pins;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19
A) Pins 2 and 4 are for the Power On LED light. (On the computer case. Not on the motherboard)
(Pin 2 is for the Positive { + } wire.
If the LED light is dim, switch the wires around )
B) Pins 6 and 8 are for the Power On switch. (Plastic - Power On button assembly has the Power On switch inside it)
C) Pins 10 and 12 are not used. In fact there probably isn't any pins.
D) Pins 14, 16, 18, and 20 are used for an internal 'speaker'. The 'speaker' is used so you can hear any BIOS Error Codes. (The computers way of telling you something is wrong, and an area to look into for it)
E) Pins 1 and 3 are for the HarDDrive activity LED light.
The LED light that blinks when the harddrive is active in use.
(Pin 1 is for the Positive wire)
F) Pins 5 and 7 are for a Reset switch, IF USED.
G) Pin 9 is NC. Not Connected
To Add:
1) If the Dell Dimension 4600 power on LED light has 3 wires, it is a dual color LED.
Only use two of the wires, and one color.
(Follow the wires to the LED light. One is a Ground wire { - }, and the other two are positive wires for the dual colors of the LED )
2) The Front USB headers are on Page 24
Make sure your Power Supply has a 4-pin ATX +12 volt power cable. Plugs into the square connector on the motherboard, to the bottom Left corner of the Processor socket.
It is power for the Processor.
For a time period Dell was really @nal about being a Proprietary computer manufacturer.
This means they wanted THEIR parts used in THEIR computers.
I don't know if your Dimension 4600 falls into this category, or not.
They switched the pins around in the ATX main power cable connector, on the motherboard.
Go to Page 18.
Look at the connector that has 20 socket holes. (Two columns of 10 socket holes)
The Dell Dimension 4600 also has a 20-pin ATX main power cable connector, on the motherboard,
Scroll the page down a little, look at the illustration for the DC Power Connector P1
See how the power and color of the wires are labeled for each pin in the connector?
Orient the connector by the lock tab on the side of it. Now compare the color chart here for the wires in a standard 20-pin ATX main power cable,
A) Orange colored wires are 3.3 Volts
B) Red wires are 5 Volts
C) Yellow wires are 12 Volts
D) ALL Black wires are Ground wires
(ALL are DC voltage)
Guess what would happen if a 12 volt wire is connected to a pin that uses 3.3 Volts, or 5 Volts?
Yep, lets the 'Smoke' out of the motherboard.
Guess what would happen if a 3.3 , 5, or 12 volt wire is plugged into a pin that is a Ground wire?
Same thing. Will fry the motherboard. Possibly the Processor, Ram Memory, Harddrive, and so on, also.
Check before you plug in, and turn the computer on.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page. Our site is constantly undergoing changes)
Jul 18, 2011 | Gigabyte GA-8I865GVME Motherboard
I ahve a beeping sound that is coming from my garage door opener.
If you have an opener with battery backup this may help. BBU stands for 'battery back up.'
This is battery related. On top of your unit is a battery pack with three colored led lights. You can tell what is going on by looking at these. This information is in your manual or here it is.
GREEN LED: All systems are normal. A solid LED light indicates the batteries are fully charged. A flashing LED indicates the batteries are being charged. NOTE: Batteries do not have to be fully charged to operate the motor unit. YELLOW LED: The motor unit has lost power and is operating off of the BBU. A solid LED with beep, sounding approximately every 2 seconds, indicates the motor unit is activating the door and is operating off of the BBU. A flashing LED with beep, sounding every 30 seconds, indicates batteries are low. Once the power is restored the BBU will recharge. This is indicated by a flashing GREEN LED. RED LED: An error has been detected and the BBU will automatically shut off. The BBU will attempt to restart by reconnecting to the batteries. If the error is still present it will shut itself off again. This process will repeat every 5 minutes or until the error has been resolved. This is used to prevent further draining of the batteries. If a red LED remains on when the power is restored, and is accompanied by a beep sounding every 30 seconds, please call for service.
Jul 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
Don't know how to setup wireless toshiba satellite pro 6100 pc notebook
Most Toshiba 6100s come standard with wireless cards installed. If you're unsure, just turn on the WiFI antenna switch (near its SD card slot) and see if the WiFi access LED lights up (the WiFi LED is the rightmost LED on the front of the unit) -- if it lights up, then you've got a stock Wireless card in your system.
Email me if you can't determine which card you have.
Jan 15, 2011 | Toshiba Satellite Pro 6100 Notebook
Need codes for rcr 460 remote
1. Manually turn on the component
you want the remote to control
(TV, VCR, DVD, satellite receiver
or cable box).
Note: If you press an invalid key
during the Manual Code Search,
the remote does not respond and
the LED indicator light does not
blink. If you do not press a valid
Manual Code Search key (TV,
GO BACK), the search times out
after two minutes. When the
search times out, the LED
indicator light blinks four times
and turns off. The last
programmed code under that
component key is retained.
2. Press and hold the component key
wish to program. The LED indicator
light turns on and remains on.
3. While holding the component
key down, press and hold the
ON·OFF key. The LED indicator
light turns off.
4. After holding down both keys
for three seconds, the LED
indicator light turns back on.
5. Release both keys. The LED
indicator light remains on.
Throughout the
programming of each key, be sure
to keep the remote pointed at the
IR sensor of the component you
are currently programming the
remote to control.
6. Press and release the ON·OFF key
repeatedly until your component
turns off. Each time you press the
ON·OFF key, the LED indicator
light blinks, and the next code in
the list is sent. This process
continues until all of the codes in
the Code Lists have been searched.
If your component turns off, you
have found the correct code. (If it
cycles through and the LED
and turns off, all codes have been
searched. The Manual Code Search
method is exited.)
Press Stop when TV turns off.
Mar 06, 2010 | RCA Universal Remote Control
I have a digistat scr with a flashing red light and no heating there is nothing wrong with the batteries, this only occured after a poweer cut.
Try this first before condeming the unit.
1. Turn off the power supply to the Digistat SCR (receiver unit)
and leave for 5 seconds.
2. Turn on power to SCR unit and check red light is on.
3. Press override button No.2 and check the green light comes
on and boiler fires.
4. Press & hold down button No.1 (Keep depressed), then
press No.2 and keep depressed. {The Red LED light will flash
a couple of times and then it will go out}
5. Now release both the buttons – {the two LED lights should
come back on}
6. Get the Digistat+2RF/+3RF unit and stand two metres away
from the SCR unit with the Digistat+2RF/+3RF unit in your hand.
7. Remove the battery cover and fit the batteries.
8. The Red LED light on the SCR will now flash for approx. 7
9. This confirms that the radio signal is being sent and
10. The Digistat+2RF/+3RF and the SCR are now successfully
linked by a dedicated RF address.
Mar 21, 2009 | Water Heaters
I don't have any power to my laptop? light on front blinks yellow.
is your battery fully charged or enough to start it
try with another battery of the same model if u can get it.
is it showing the battery charging status LED infront .
Aug 15, 2008 | Toshiba Computers & Internet
Technics SUV500 problem in stand-by
The problem is not the relay. The unit is trying to start, but detecting a problem and shuting down again. Check the output transistors for a shorted condition.
Jan 31, 2008 | Technics SUV500 2-Channel Amplifier
Toshiba Satellite Pro 4600 Notebook Logo
1,701 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
