Question about HP LaserJet 3050 All-In-One Printer
Remote fax retrieval
Can i retrieve faxes remotely from my hp 3050
Yes, go to menu and find "reprint last faxes" than press ok
Posted on Feb 25, 2009
Fax memory full
To gain extra memory, you can turn off Fax Storage OR Print fax messages in memory (See Setting Fax Storage, page 48.) OR Expand the machines memory.
Retrieve or Erase a Fax
Press 9 6
then to
Retrieve all faxes Press 2, then enter the number of remote fax machine and then press # #. After
the beep, hang up and wait.
Erase all fax messages Press 3. If the data stored in the memory has not been printed before, it will be printed first and then erased.
Setting Fax Storage
If you set Fax Storage to ON, you will be able to retrieve fax messages from another location, using Fax Forwarding or Remote Retrieval functions. The screen will indicate when you have a fax stored
in memory.
1 Press Menu, 2, 5, 2.
2 Press left arrow or right arrow to select ON (or OFF), and press Set when the screen displays your selection.
3 Press Stop/Exit.
If there are faxes in memory when you turn the Fax Storage OFF, the screen prompts you to erase any faxes in memory.
If you press 1, all fax data is erased and Fax Storage is turned OFF. If the fax data in memory has not been printed before, it will be printed first, and then erased. If you press 2, data is not erased, and Fax Storage remains ON.
Feb 07, 2012 | Brother FAX-8360P Plain Paper Laser
I need to reprint the last inoming fax. HELP!!!
Printing a Fax in Memory If you have Fax Storage ON for remote retrieval, you can still print a fax in the memory when you are at your machine: 1 Press Menu/Set, 8, 4. 2 Press Fax Start. 3 Press Stop/Exit. (See Turning On Fax Storage, page R-2.) Polling For details about the Polling feature, call our Brother fax-back system 1-800-521-2846 (in USA), 1-800-681-9838 (in Canada) and request at the Index. (See Features That Are Not in the Manual, page 6-6 for details.) Polling is the process of retrieving faxes from another fax machine. You can use your fax machine to "poll" other machines, or you can have someone poll your machine. All parties involved in polling need to set up their fax machines to accommodate polling. When someone polls your machine to receive a fax, they pay for the call; if you poll someone's fax machine to receive a fax, you pay for the call. (See Canceling a Scheduled Job, page 6-5.) Some fax machines do not respond to the Polling feature.
Jun 24, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Comm error 232
This is the common cause and solution: A communication failure has occurred between the two machines. On the other hand, the user at the remote machine may have pressed the Stop button. Alternatively: the power at the remote machine has been interrupted, or deliberately turned off causing the fax session to be interrupted.
Solution:
1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, and error correction is in use for the fax session, disable ECM . (See Error 222)
Good luck
Jun 12, 2010 | HP LaserJet 3050 All-In-One Printer
OUR FAX SAYS 98% MEMORY FULL SOMETIMES WHEN THEY TRY TO FAX SOMETHING. HOW DO I CLEAR THE MEMORY? NATALIE
Press Menu, 2, 5, 2. The screen prompts you to choose a fax setting. Press <-- or --> to select OFF then press SET. If there are faxes in memory when you turn Fax Storage to OFF, the LCD prompts you to erase faxes in memory. If you press 1, all fax data is erased and Fax Storage is turned OFF.
You may want to enable Real Time TX so you can send fax without using memory. (Under FAX-SETUP SEND-REAL TIME TX)
You may also disable Fax Storage if you don't want to store incoming faxes in memory for remote retrieval (Under FAX- REMOTE FAX OPT-FAX STORAGE)
For effective use of the memory, you may also clear the caller IDs stored in the memory. Press MENU, 2, 0, 2 Press the arrow keys to display # then press CLEAR.
Hope this helps!
Jul 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax error 344 - HP officejet 4255 all-in-one
fax error is remote machine not responding to your fax.the other fax has stopped communicating.this is a comms error.
Jun 29, 2009 | HP LaserJet 3050 All-In-One Printer
Fax connection
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
May 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
HOW DO I SEND A FAX ON THE BROTHER MFC-5440CN? LOST MY MANUAL
Remote Fax Options;
5. Press Stop/Exit.
Setting Fax Storage
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
these faxes.
PC Fax Receive.
Press Menu/Set.
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
the CD-ROM.)
Apr 22, 2009 | Office Equipment & Supplies
Panasonic KXFP145
when I sent a fax via Satellite communication, I got error 503 for few customer - it seems I need to change ECM at the remote site .. any advice
Mar 20, 2008 | Office Equipment & Supplies
Error 344- Fax Function
Comm Error 344 is: (Note that this is on the receivers end)
The remote machine has failed to respond to a fax command from the product because the connection is interrupted.
The remote user has pressed the Stop button while the remote machine was receiving.
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
This website will show you what the error codes are.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00062808#A5
Feb 26, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
127 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
