Question about Sony Grand WEGA KF60WE610 60" Rear Projection Television
Owner of Sony KDFE60A20 set. Worked great for 5 years, then picture started cutting in and out. Picture was clear as a bell when on, but would only stay on for a minute, then go off for a minute. Repairman replaced a lamp, don't know which one since my wife was at home when it was repaired. Now the picture has a heavy green tint that I can't change. Repairman indicated there was a Optical Blue Block recall by Sony. Has there been a recall on this set by Sony for any reason? Thanks, Jerry francis.simmons@navy,mil
Have you tried new composite or HDMI cables or a new input port on the TV? Sometimes a bad cable or connector will blemish a color signal.
Remove one of the 3 composite color cables at a time and see if it makes a difference,
Posted on Sep 05, 2009
Limited Extended Warranty for Certain 2003 and 2004 Televisions Exhibiting Warping of the Lamp Access Door Posted: 04/17/2008
  • 2003 Models: KF42WE610, KF50WE610, KF60WE610, KDF60XBR950, KDF70XBR950
  • 2004 Models: KF42WE620, KF50WE620, KDF42WE655, KDF50WE655
It has come to our attention that a limited number of Grand WEGA rear projection televisions (models listed above) may exhibit warping to the lamp access door. In rare cases, some additional components may also become damaged as a result.
Sony would like to assure its customers that this issue has been evaluated extensively and that there are no product safety concerns caused by this issue.
As part of our commitment to quality, Sony will reimburse owners of eligible models in the United States who paid out-of pocket expenses on or before May 9, 2008 for an estimate or repair service related to this specific lamp door issue. To receive reimbursement, please follow the exact directions on the claim form for reimbursement; all claims must be postmarked by August 31, 2008. See the claim form for complete terms and conditions.
Additionally, through March 31, 2009, Sony will repair the lamp access door and any other components damaged as a result at no charge for any of the covered televisions. Customers who experience this issue should contact Sony at (888) 649-7669 to schedule a repair. Sony will only provide free repair to covered televisions that exhibit this specific condition.
All other terms of the Sony limited warranty continue to apply. Sony utilizes a network of hundreds of qualified independent third-party servicers to perform in-home television warranty service. Sony, through its Authorized Servicer Network, will repair your set within 30 days of your initial contact. For diagnosis, warranty service, or if your set is not repaired within 30 days, please contact Sony at (888) 649-7669.
good luck though cause if its the blue blob they wont and as I have a kdf42we655 and just took it apart and cleaned it all out all I see wrong is something with the yellow prism lens so all I would need to fix my tv is the little snap on piece that has the blue, red and yellow prism on it.........not the whole optical engine that costs as much as a new tv............
Posted on Feb 25, 2009
I HAVE A SONY WEGA PROJECTOR TV KDFE60A20 I CHANGED THE LAMP AND THE PICTURE IS TOO DARK BEFORE I WATCHED THE TV FROM THE SIDE WITH THE WINDOWS OPEN AND NO PROBLEM NOW I HAVE TO CLOSE THE WINDOWS AND
my first thought would be new bulb needed but if you have changed bulb can't be that.
is the wall white?
is there a setting to say what colour you are projecting on?
good luck
Jan 20, 2013 | Sony Lamp For Sony KDFE60A20...
Sony wega 51" standby light is blinking 5 times repeatedly. what is this code for?
The picture tube is getting close to failure. Has the picture tube been replaced before? If it hasn't it is probably about due the Vegas were great long lasting T.V. sets but after about 15 years need a new picture tube.
Jan 15, 2013 | Sony Grand WEGA KDP-51WS550 51" Rear...
Sony Bravia model #KDL52WL130 worked fine for first year then picture went very dark for the 1st 30 minutes it was on but eventually cleared up. Now it takes longer and screen is completely blank. Sound...
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years, some sooner, because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KDFE60a20 picture is not bright. We are losing sight of the picture due to it being so dark. Is this the lamp assembly or could it also be something else. TV is 5 years old.
It is lamp that need to be replaced.
Lamp is not generating enough light to present bright picture on tv screen.
Lamp replacement is easy and written in user manual of tv.
Please buy Sony original lamp for good picture result in tv.
Let me know if you have additional question.
Thanks.
May 23, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony tv model KV32S42 picture taking forever to come in
Speaking as a retired SONY dealer, the short answer is probably yes. There are some repairs an authorized SONY repair center can do but if the tube is displaying a soft picture, it may not be wise to spend a couple hundred on repairs when a new medium quality TV is three hundred to five hundred for a SONY. I applaud your devotion to a set that has served you well.
Dec 05, 2009 | Televison & Video
Green screen with sound from cable, but picture is fine with Wii
That would be my solution. The trouble is either in the box or your connecting cables. Verify this by connecting the cable directly to the set. Then try a new set of connecting cables, or call the cable provider to replace the box.
Feb 07, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
BOWED IN SCREEN/PICTURE
the problem is called pincushion
usually fixable not by anyone without electronics background
guessing around $150 you have to decide
as long as it has a good clear sharp picture its worth it
Dec 20, 2008 | Sony FD Trinitron WEGA KV-24FS100 24" TV
Problems at start
Please email me the model number for the tv so i can better assist you.
Thanks,
Tim Nolan
Experttv@comcast.net
Oct 09, 2008 | Sony KP-53HS30 53" Rear Projection...
Sony Grand WEGA KF60WE610 60" Rear Projection Television Logo
322 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
